    remotecompliments disappeared - please help
    47 Posts 2 Posters 17.9k Views 2 Watching
      sdetweil @forjer
      @forjer and the pm2 log?
      F 2 Replies Last reply Reply Quote 0
      • F Offline
        forjer @sdetweil
        pi@raspberrypi:~ $ pm2 logs
        /home/pi/.pm2/pm2.log last 15 lines:
        PM2        | 2020-12-28T21:29:05: PM2 log: pid=22698 msg=process killed
        PM2        | 2020-12-28T21:29:05: PM2 log: App [MagicMirror:0] starting in -fork mode-
        PM2        | 2020-12-28T21:29:05: PM2 log: App [MagicMirror:0] online
        PM2        | 2020-12-28T21:29:50: PM2 log: Stopping app:MagicMirror id:0
        PM2        | 2020-12-28T21:29:51: PM2 log: pid=23236 msg=failed to kill - retrying in 100ms
        PM2        | 2020-12-28T21:29:51: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
        PM2        | 2020-12-28T21:29:51: PM2 log: pid=23236 msg=process killed
        PM2        | 2020-12-28T21:29:51: PM2 log: App [MagicMirror:0] starting in -fork mode-
        PM2        | 2020-12-28T21:29:51: PM2 log: App [MagicMirror:0] online
        PM2        | 2020-12-28T21:46:00: PM2 log: Stopping app:MagicMirror id:0
        PM2        | 2020-12-28T21:46:00: PM2 log: pid=23422 msg=failed to kill - retrying in 100ms
        PM2        | 2020-12-28T21:46:00: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
        PM2        | 2020-12-28T21:46:01: PM2 log: pid=23422 msg=process killed
        PM2        | 2020-12-28T21:46:01: PM2 log: App [MagicMirror:0] starting in -fork mode-
        PM2        | 2020-12-28T21:46:01: PM2 log: App [MagicMirror:0] online
        /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
        /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
        0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
        0|MagicMir |
        0|MagicMir | [2020-12-28 21:46:04.542] [LOG]    Starting MagicMirror: v2.13.0
        0|MagicMir | [2020-12-28 21:46:04.557] [LOG]    Loading config ...
        0|MagicMir | [2020-12-28 21:46:04.568] [LOG]    Loading module helpers ...
        0|MagicMir | [2020-12-28 21:46:04.571] [LOG]    No helper found for module: clock.
        0|MagicMir | [2020-12-28 21:46:07.600] [LOG]    Initializing new module helper ...
        0|MagicMir | [2020-12-28 21:46:07.601] [LOG]    Module helper loaded: MMM-RemoteCompliments
        0|MagicMir | [2020-12-28 21:46:07.602] [LOG]    All module helpers loaded.
        0|MagicMir | [2020-12-28 21:46:07.798] [LOG]    Starting server on port 8080 ...
        0|MagicMir | [2020-12-28 21:46:07.819] [LOG]    Server started ...
        0|MagicMir | [2020-12-28 21:46:07.821] [LOG]    Connecting socket for: MMM-RemoteCompliments
        0|MagicMir | [2020-12-28 21:46:07.825] [LOG]    Starting node helper for: MMM-RemoteCompliments
        0|MagicMir | [2020-12-28 21:46:07.826] [LOG]    Sockets connected & modules started ...
        0|MagicMir | [2020-12-28 21:46:07.960] [LOG]    Launching application.
          sdetweil @forjer
          @forjer sorry, I’ve run out of everything to look for. the error is gone now…
          • F Offline
            forjer @sdetweil
            @sdetweil In my developer log it mentions “RemoteCompliments: ‘MODULE_DOM_CREATED’ received: null” and “module.js:199 MMM-RemoteCompliments is suspended.” Is that a clue? It just doesn’t make sense. I tested it yesterday morning by putting in a really long compliment just to see how it looked on the screen. I then reverted it back to a short compliment. Later in the morning I did a sudo apt-get update and a sudo apt-get upgradejust before setting up remote desktop, VNC and pitunnel. Those are the only other things that I can think of where I changed some stuff.
            developers window
            Load script: modules/MMM-RemoteCompliments//MMM-RemoteCompliments.js
            module.js:513 Module registered: MMM-RemoteCompliments
            loader.js:148 Bootstrapping module: MMM-RemoteCompliments
            loader.js:176 Load script: modules/MMM-RemoteCompliments//scripts/jquery-3.3.1.min.js
            loader.js:153 Scripts loaded for: MMM-RemoteCompliments
            loader.js:155 Styles loaded for: MMM-RemoteCompliments
            loader.js:157 Translations loaded for: MMM-RemoteCompliments
            loader.js:195 Load stylesheet: css/custom.css
            :8080/modules/default/clock//clock.js:46 Starting module: clock
            main.js:508 All modules started!
            :8080/modules/MMM-RemoteCompliments//MMM-RemoteCompliments.js:222 MMM-RemoteCompliments: 'MODULE_DOM_CREATED' received:  null
            Are there any other (perhaps more stable) modules where I can display a custom message (compliment) depending on the time of day? I had about 10 compliments programmed to display at their specified time slots throughout the day. And I liked the ability to control / override them easily with my phone via Google Drive.
              sdetweil @forjer
              @forjer the code and comments
              // Hide module on startup.
              			// If the module receives data, the module will reveal itself.
              			self.hide(0);
              			self.hidden = true;
              which is reasonable, but it just reinforces no data.
              sorry no idea on another module that does this other than the default compliments module with remotefile
              • F Offline
                forjer @sdetweil
                @sdetweil Hmm…is there a simple way to hard code in a RemoteCompiment to force it to show? Just as a troubleshooting step to see it?
                I guess I could consider the default compliments with remote file. Can I run a second default compliment module at the same time? Is it as simple as copying the folders and renaming them “compliments2” or something?
                  sdetweil @forjer
                  @forjer the default compliments module can be used multiple times without problem. you either pass the compliments as config parms or in a remotefile as config parm
                  • F Offline
                    forjer @sdetweil
                    @sdetweil So are you saying I can run two instances of compliments at the same time, shown in two different locations on the same display? And is this done by copying the compliments.js to make a “compliments2.js”?
                      sdetweil @forjer
                      @forjer yes, two instances, no need to copy the module
                      • F Offline
                        forjer
                        @sdetweil I’m sorry, I’m a little slow. And this is making my brain hurt. I really appreciate your patience with me.
                        How would this look in config.js? And how does it know which compliments go in what position of the MM?
                        What I’m after is a normal compliments module running in lower_third, and a second compliments module sliced into 10 time slots with a different set of compliments running in upper_third. I’ve just finished modifying the default compliments.js to get my 10 time slots and that seems to work, so I’m getting closer.
                        S F 2 Replies Last reply Reply Quote 0
                          sdetweil @forjer
                          @forjer modifying?
                          no need to modify ( never modify module source code)
                          code two modules wherever u want.
                          put the compliments text in the config block in config.js
                          I am on my phone so everything but the actual compliments
                               module:"compliments",
                               position:"lower_third",
                               config:{
                                     compliments:{
                                           same as in defaults section of code
                                           whatever  compliments for module 1
                                     OR
                                      remotefile:"http://....... somefile on some server"
                               position:"upper_third",
                               config:{
                                     compliments:{
                                           whatever  compliments for module 2
                          • F Offline
                            forjer @forjer
                            @sdetweil Progress. So I saved a copy of my modified compliments.js into a compliments2 folder as compliments2.js and renamed module.register to compliments2. I then reverted my compliments.js back to original. I then added a compliments2 section into my config.js. And now I have two separate compliments running! I tried that a few hours ago but I must have done something wrong so it didn’t work.
                            In the way you coded it, would I be able to have the ability to run Module 1 with the default time slots (complimentArray) while Module 2 runs a different time slot schedule?
                            Now I think I’d like to get a remotefile set up but I’m guessing I’ll run into some issue with remotefile for my compliments2.
                            • F Offline
                              forjer @forjer
                              @sdetweil Also, is there a way to get my compliments2 to allow time splits at say 11:30 instead of just integer hours? Something like the following?
                              afternoonStartTime: 11:30,
                              afternoonEndTime: 13,
                              It would appear the complimentArray would need to be adjusted by changing “hour” to something else?
                              } else if (hour >= this.config.afternoonStartTime && hour < this.config.afternoonEndTime && this.config.compliments.hasOwnProperty("afternoon")) {
                              	compliments = this.config.compliments.afternoon.slice(0);
                              S 3 Replies Last reply Reply Quote 0
                                sdetweil @forjer
                                @forjer read the doc
                                u can have different remotefiles too
                                https://docs.magicmirror.builders/modules/compliments.html
                                  sdetweil @forjer
                                  @forjer if u need 10 time slots, then the compliments module would need changing as u might already have done. u should change your own copy, and then use that
                                  from the modules folder
                                  cp defaults/compliments mycompliments
                                  have to change the module register at the top to be the same as the folder name u create on the copy
                                    sdetweil @forjer
                                    @forjer looks like the default time slots are hour based. so another reason to make your own
                                    • F Offline
                                      forjer @sdetweil
                                      @sdetweil Thanks for all of you time and help. You are a wealth of knowledge.
                                      I’ve only been digging into this thing for a few weeks and I’ve seen so many of your posts helping others. Kudos!
                                      I like this kind of stuff, I just wish I had better core knowledge so I didn’t spend so much time looking stuff up and tinkering, but I guess that’s one way to learn.
                                      I have gotten my custom “compliments2” module to work, but still only with integers for time. There’s got to be a simple way to change that. I’ll keep looking.
                                        sdetweil @forjer
                                        @forjer said in remotecompliments disappeared - please help:
                                        what do u mean?
                                          sdetweil @forjer
                                          @forjer my son calls me all the time w questions. I don’t know much, but I know how to search, and can usually find an answer pretty quick.
                                          I do it here too, all the time, writing code, working on install issues. trying to help w modules I don’t know.
                                          I didn’t know we could run multiple compliments modules concurrently, but I figured it out looking at the code.
                                          • F Offline
                                            forjer @sdetweil
                                            @sdetweil said in remotecompliments disappeared - please help:
                                            what do u mean?
                                            I mean that by default, compliments only allows defining “morningStartTime” as 5, but I would like to be able to do is define it as 5:35.
                                            • 2 / 3
