MM only server version working due to issues with config file
very weird… lets do this
cd ~/MagicMirror npm run config:check
@sdetweil no syntax errors…
@legan said in MM only server version working due to issues with config file:
thx… as expected…
can u check the filename , rename config.js and make sure no leading/trailing space
also can u try with a browser on pi to open
file:///home/pi/MagicMirror/config/config.js
Yes, I checked the filename several times, its fine. The config file is also accessible via file:///home/pi/MagicMirror/config/config.js
@legan can I see the address: and ipWhitelist: settings from config.js
make them
address:"0.0.0.0", ipWhitelist:[],
@sdetweil I extended the whitelist and enabled all IP addresses. But still not working
@legan if u set it to [] that is all
@sdetweil said in MM only server version working due to issues with config file:
all
exactly, that’s what I did
@legan and address is localhost or 0.0.0.0?
