    MM only server version working due to issues with config file
    33 Posts 3 Posters 12.7k Views 3 Watching
      sdetweil @legan
      @legan weird, can u show results of
      ls ~/MagicMirror/config -laF
      • L Offline
        legan @sdetweil
        Of course, here you are :)
          sdetweil @legan
          @legan ok, on that error screen, ctrl-shift-i to open the developers window, then select the console tab and scroll up there should be an error at the top…
          the code does
          try {
          			fs.accessSync(configFilename, fs.F_OK);  // make sure we have permission to access file
          			var c = require(configFilename);    // load and parse config
          			checkDeprecatedOptions(c);
          			var config = Object.assign(defaults, c);   // overlay defaults with config
          			callback(config);   // send back the loaded config
          		} catch (e) {  // some error above
          			if (e.code === "ENOENT") {    // if file not found
          				Log.error(Utils.colors.error("WARNING! Could not find config file. Please create one. Starting with default configuration."));
          			} else if (e instanceof ReferenceError || e instanceof SyntaxError) {  // got a syntax error
          				Log.error(Utils.colors.error("WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: " + e.stack));
          			} else {  // everything else
          				Log.error(Utils.colors.error("WARNING! Could not load config file. Starting with default configuration. Error found: " + e));
          			callback(defaults);    // < this is sending back the module config that displays the error you see
          • L Offline
            legan
            @sdetweil thanks you very much! Ok, I opened the developer window as you suggested and attached the screenshots of the errors. Where exactly should I paste your code snippet?2.JPG 3.JPG 4.JPG
              sdetweil @legan
              @legan I was just showing what the code DOES…
              custom.css error is because its not there by default…
              • L Offline
                legan @sdetweil
                @sdetweil ok sorry, I am not very familiar with java script yet…
                  very weird… lets do this
                  npm run config:check
                  • L Offline
                    legan @sdetweil
                    @sdetweil no syntax errors…
                      sdetweil @legan
                      @legan said in MM only server version working due to issues with config file:
                      thx… as expected…
                      can u check the filename , rename config.js and make sure no leading/trailing space
                      also can u try with a browser on pi to open
                      file:///home/pi/MagicMirror/config/config.js
                      • L Offline
                        legan
                        Yes, I checked the filename several times, its fine. The config file is also accessible via file:///home/pi/MagicMirror/config/config.js
                          sdetweil @legan
                          @legan can I see the address: and ipWhitelist: settings from config.js
                            make them
                            address:"0.0.0.0",
                            ipWhitelist:[],
                            • L Offline
                              legan @sdetweil
                              @sdetweil I extended the whitelist and enabled all IP addresses. But still not working
                                sdetweil @legan
                                @legan if u set it to [] that is all
                                • L Offline
                                  legan @sdetweil
                                  @sdetweil said in MM only server version working due to issues with config file:
                                  all
                                  exactly, that’s what I did
                                    sdetweil @legan
                                    @legan and address is localhost or 0.0.0.0?
                                    • L Offline
                                      legan
                                      @sdetweil now it’s working! Thank you very much you saved my tech mood though! :D
                                      Have a good one! :)
                                        sdetweil @legan
                                        @legan what did you do ?
                                        • L Offline
                                          legan @sdetweil
                                          @sdetweil I followed your instructions, and after changing localhost to 0.0.0.0.
                                          I was able to start the mirror
                                            sdetweil @legan
                                            @legan weird
