    MM only server version working due to issues with config file
    33 Posts 3 Posters 12.0k Views 3 Watching
    • L Offline
      legan @sdetweil
      @sdetweil no syntax errors…
        sdetweil @legan
        @legan said in MM only server version working due to issues with config file:
        thx… as expected…
        can u check the filename , rename config.js and make sure no leading/trailing space
        also can u try with a browser on pi to open
        file:///home/pi/MagicMirror/config/config.js
        • L Offline
          legan
          Yes, I checked the filename several times, its fine. The config file is also accessible via file:///home/pi/MagicMirror/config/config.js
            sdetweil @legan
            @legan can I see the address: and ipWhitelist: settings from config.js
              make them
              address:"0.0.0.0",
              ipWhitelist:[],
              • L Offline
                legan @sdetweil
                @sdetweil I extended the whitelist and enabled all IP addresses. But still not working
                  sdetweil @legan
                  @legan if u set it to [] that is all
                  • L Offline
                    legan @sdetweil
                    @sdetweil said in MM only server version working due to issues with config file:
                    all
                    exactly, that’s what I did
                      sdetweil @legan
                      @legan and address is localhost or 0.0.0.0?
                      • L Offline
                        legan
                        @sdetweil now it’s working! Thank you very much you saved my tech mood though! :D
                        Have a good one! :)
                          sdetweil @legan
                          @legan what did you do ?
                          • L Offline
                            legan @sdetweil
                            @sdetweil I followed your instructions, and after changing localhost to 0.0.0.0.
                            I was able to start the mirror
                              sdetweil @legan
                              @legan weird
                                weird
                                You can’t make this stuff up. :-)
                                  sdetweil @Mykle1
                                  @Mykle1 that is what I hear!
