    MM only server version working due to issues with config file
    33 Posts 3 Posters 12.0k Views 3 Watching
      sdetweil @legan
      @legan said in MM only server version working due to issues with config file:
      @sdetweil no syntax errors…
      thx… as expected…
      can u check the filename , rename config.js and make sure no leading/trailing space
      also can u try with a browser on pi to open
      file:///home/pi/MagicMirror/config/config.js
      • L Offline
        legan
        Yes, I checked the filename several times, its fine. The config file is also accessible via file:///home/pi/MagicMirror/config/config.js
          sdetweil @legan
          @legan can I see the address: and ipWhitelist: settings from config.js
            make them
            address:"0.0.0.0",
            ipWhitelist:[],
            • L Offline
              legan @sdetweil
              @sdetweil I extended the whitelist and enabled all IP addresses. But still not working
                sdetweil @legan
                @legan if u set it to [] that is all
                • L Offline
                  legan @sdetweil
                  @sdetweil said in MM only server version working due to issues with config file:
                  all
                  exactly, that’s what I did
                    sdetweil @legan
                    @legan and address is localhost or 0.0.0.0?
                    • L Offline
                      legan
                      @sdetweil now it’s working! Thank you very much you saved my tech mood though! :D
                      Have a good one! :)
                        sdetweil @legan
                        @legan what did you do ?
                        • L Offline
                          legan @sdetweil
                          @sdetweil I followed your instructions, and after changing localhost to 0.0.0.0.
                          I was able to start the mirror
                            sdetweil @legan
                            @legan weird
                              weird
                              You can’t make this stuff up. :-)
                                sdetweil @Mykle1
                                @Mykle1 that is what I hear!
