    MMM-TelegramBot : Control MM on Telegram
    47 Posts 20 Posters 27.9k Views 21 Watching
    • K
      kontranik
      can a bot send a notification to other module when a message recived?
        A Former User
        sure if you code it in a module
          A Former User
          TelegramBot in now on v1.3.3
          it can now display stickers, Gifs, play official telegram notification sound on message received
            bryan_1 @Guest
            @Sean Hi, is it possible to save some shown modules as default with Telegram, when magic mirror restarted?
              A Former User
              @bryan_1 said in MMM-TelegramBot : Control MM on Telegram:
              why @Sean this question ? He stops developing
              It’s me now
              after if you want a @Sean response it’s not a problem :)
                bryan_1 @Guest
                @Bugsounet Oh, sorry for that, I don’t know it. I’ll be glad to hear your response.
                • K
                  krisalexroberts
                  I’ve tried linking IFTTT with TelegramBot in a group chat, before learning bots cannot converse, which is annoying.
                  Can I control telecast with an API or outside of telegram, then I can use IFTTT Webhooks?
                    Bronno @DinoDog
                    @DinoDog Did you know the solution? I have the same problem…
                      robiv8 @DinoDog
                      @DinoDog said in MMM-TelegramBot : Control MM on Telegram:
                      hi
                      When i use /alert, i see the message on my MM, but /telecast don’t show any on my MM
                      How can i found, whats the error?
                      The IDs are all correct
                      Hallo,
                      any help is welcome.
                      I have the same problem. Any codes and numbers are correct.
                      No error in logs.
                      /alert is coming and displayed
                      but when I send a message like TEST123 nothing happens?
                      The Modul is on top_left~~
                      So now I understand! This is only with telecast possible!
                        A Former User
                          robiv8
                          Yes! You are right :-)
                          by the way, is it possible to clear the chat
                          or to delete a message
                          or to delete the message after a while -> telecastLife OK
                          so that when you have sent a few messages you can delete them so that this don’t stand there forever.
                          and
                          Videos are not going?
                          Robert
                            A Former User
                            And …
                            The ReadMe file says:
                            New Updates
                            **[1.3.7] 2020-09-11
                            • add TelegramBot Service (catch all Errors of Telegram)
                            [1.3.5-1.3.6] 2020-09-08
                            • add telecast directly on allowedUser
                            • add emojis (@eouia purpose)
                            • add telecastContainer feature
                            • add Play audio on received audio file
                            • add Video play… (if codec is there…)
                            • add Voice audio ! @MIRCO
                            [1.3.4] 2020-09-07
                            • add /clean command for clean telecast screen
                            • update fr translations
                            • add dateFormat feature
                            [1.3.3] 2020-09-05
                            • Add stickers support (not animated)
                            • Add gifs support
                            • Add native default sound on message received
                            Just little part of the file…
                              robiv8
                              :man_facepalming_light_skin_tone:
                              Thank you!
                              Send a video from iPhone is not display! are you now what kind of codec are necessary
                                A Former User
                                Need some modification in MagicMirror Core but i think send a video file for playing is actually optional, video cast is better
                                  robiv8
                                  • A
                                    alex1258
                                    • O
                                      OberfragGER
                                      i dont get this to work.
                                      I already have setup a bot for ioBroker. I want to have this Notifications also in the MagicMirror.
                                      Is that even possible to use the same token on 2 devices?- because when i enter the API Token in the MagicMirror-Config i get some warning in ioBroker and no chat or something in MM2.
                                      warn: telegram.0 (17441) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                                      My config looks like
                                        module: 'MMM-TelegramBot',
                                          telegramAPIKey : 'Api-Token',
                                          allowedUser : ['username']
                                      I use pages and i have fixed “MMM-TelegramBot”.
                                      • lavolp3L
                                        lavolp3 Module Developer @OberfragGER
                                        @oberfragger I’ve had a few issues getting i to work as well but eventually it works. Rebooted the RasPi on the way so that might help although I doubt it.
                                        And don’t forget to include your chatID as descripbed in the README.
                                        I think the error is not necessarily the problem. I got that as well when starting the mirror on the laptop as well, so having two front-end instances running. Module still worked
                                        How to troubleshoot modules
                                        MMM-soccer v2, MMM-AVStock
                                        • lavolp3L
                                          I’m astonished by the power of this module and the telegram bot. I am using it to send messages and pictures to the mirror. And it is so much fun, especially for the kids.
                                          What I am missing is:
                                          can the last messages of the chat be loaded at startup? Does anyone know?
                                          They do not in my case.
                                          It’s a shame that there’s apparently no support from the owner anymore here, so I might decide to work with a fork and publish it here again to have a support and troubleshooting base on this forum again.
                                          bugsounetB 1 Reply Last reply Reply Quote 0
                                          • bugsounetB
                                            bugsounet Banned @lavolp3
                                            @lavolp3 really? 😂
                                            • 2 / 3
