    Help with MMM-SleepWake
    11 Posts 2 Posters 6.1k Views 3 Watching
      chanster
      @sdetweil I’m hoping you can help me out with this. I have installed the Motion package and confirm that it works - I can view the livestream etc and it’s recording mkv files to the motion folder that I’ve defined when motion is detected.
      I see these entries in motion.log :
      [1:ml1] [NTC] [EVT] [Jan 09 01:19:36] event_newfile: File of type 8 saved to: /home/pi/Pictures/motion/01-20210109011936.mkv
      [1:ml1] [NTC] [ALL] [Jan 09 01:19:36] motion_detected: Motion detected - starting event 1
      [1:ml1] [NTC] [ALL] [Jan 09 01:21:26] mlp_actions: End of event 1
      [1:ml1] [NTC] [EVT] [Jan 09 01:21:28] event_newfile: File of type 8 saved to: /home/pi/Pictures/motion/02-20210109012128.mkv
      [1:ml1] [NTC] [ALL] [Jan 09 01:21:28] motion_detected: Motion detected - starting event 2
      [1:ml1] [NTC] [ALL] [Jan 09 01:24:01] mlp_actions: End of event 2
      [1:ml1] [NTC] [EVT] [Jan 09 01:24:18] event_newfile: File of type 8 saved to: /home/pi/Pictures/motion/03-20210109012418.mkv
      [1:ml1] [NTC] [ALL] [Jan 09 01:24:18] motion_detected: Motion detected - starting event 3
      [1:ml1] [NTC] [ALL] [Jan 09 01:33:05] mlp_actions: End of event 3
      Your module did put my display to sleep but it didn’t wake it up. I tested these commands manually and they work to turn the HDMI on and off :
      /opt/vc/bin/tvservice -p && sudo chvt 6 && sudo chvt 7
      /opt/vc/bin/tvservice -o
      I edited the motion.conf file to call your module when motion event starts / ends.
      I notice this however in the motion log after I added the event calls to your module :
      [30500488:motion] [NTC] [ALL] conf_load: Processing thread 0 - config file /home/pi/.motion/motion.conf
      [30500488:motion] [NTC] [ALL] motion_startup: Motion 4.1.1 Started
      [30500488:motion] [NTC] [ALL] motion_startup: Logging to file (/var/log/motion/motion.log)
       &: 1:  &: value: not found
       &: 1:  &: value: not found -> this keeps repeating until I stop motion
      I commented out the motion event calls and these messages stop. So they seem to be related to these two configuration entries :
      on_event_start /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion started
      on_event_start /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion ended
      I noticed you mention that there should be two files in the motion directory under MMM-SleepWake but in my case, I do not see any files in that directory.
      In my config.js, I just have this :
                  module: 'MMM-SleepWake',
                  config:{
                      delay: 15,
                      mode: 'PI'
      Sorry for the long message, I hope you can suggest what I may have done incorrectly.
      Thanks!
        sdetweil @chanster
        @chanster can u show me what u added to motion.conf?
          chanster
          These are the two lines I updated in motion.conf
          # Command to be executed when an event starts. (default: none)
          # An event starts at first motion detected after a period of no motion defined by event_gap
          on_event_start value /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion started
          # Command to be executed when an event ends after a period of no motion
          # (default: none). The period of no motion is defined by option event_gap.
          on_event_end value /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion ended
          I noticed something else. Last night, before I went to bed, I turned motion off (I was just running it from the command line, not as a service). This morning my display was in power saving mode again (yellow light) and I couldn’t get it to wake up. I had to manually run this command from the command line to get the screen to turn on again :
          It’s strange that your module had put my screen to sleep even though there was no motion even to trigger it.
          S 3 Replies Last reply
            sdetweil @chanster
            @chanster remove the word value from both lines in motion.conf
            C 1 Reply Last reply
              sdetweil @chanster
              @chanster motion wakes up. timer puts to sleep
                sdetweil @chanster
                @chanster u can run the exteral_motion started command from the command line to test getting the commands working.
                over ssh too. it’s just a command to tell module there was ‘motion’
                  chanster @sdetweil
                  @sdetweil Thank you !! I’m so stupid. Removing “value” did the trick ! Thank you for this module. Works perfectly.
                    sdetweil @chanster
                    @chanster glad u got it working.
                    help me fix the doc, what lead u to use value?
                      chanster @sdetweil
                      @sdetweil It was in the sample config file for Motion. It’s a rookie mistake that I should have replaced “value” and not merely append to this line :
                      ; on_event_start value
                      ; on_event_end value
                        sdetweil @chanster
                        @chanster ok, my module doc gives u the new lines for motion.conf
                          chanster @sdetweil
                          @sdetweil said in Help with MMM-SleepWake:
                          Yes, nothing wrong with your docs at all.
