    Help with MMM-SleepWake
    11 Posts 2 Posters 4.5k Views 3 Watching
      sdetweil @chanster
      @chanster can u show me what u added to motion.conf?
        chanster
        These are the two lines I updated in motion.conf
        # Command to be executed when an event starts. (default: none)
        # An event starts at first motion detected after a period of no motion defined by event_gap
        on_event_start value /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion started
        # Command to be executed when an event ends after a period of no motion
        # (default: none). The period of no motion is defined by option event_gap.
        on_event_end value /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion ended
        I noticed something else. Last night, before I went to bed, I turned motion off (I was just running it from the command line, not as a service). This morning my display was in power saving mode again (yellow light) and I couldn’t get it to wake up. I had to manually run this command from the command line to get the screen to turn on again :
        /opt/vc/bin/tvservice -p && sudo chvt 6 && sudo chvt 7
        It’s strange that your module had put my screen to sleep even though there was no motion even to trigger it.
        S 3 Replies Last reply Reply Quote 0
          sdetweil @chanster
          @chanster remove the word value from both lines in motion.conf
            sdetweil @chanster
            @chanster motion wakes up. timer puts to sleep
              sdetweil @chanster
              @chanster u can run the exteral_motion started command from the command line to test getting the commands working.
              over ssh too. it’s just a command to tell module there was ‘motion’
                chanster @sdetweil
                @sdetweil Thank you !! I’m so stupid. Removing “value” did the trick ! Thank you for this module. Works perfectly.
                  sdetweil @chanster
                  @chanster glad u got it working.
                  help me fix the doc, what lead u to use value?
                    chanster @sdetweil
                    @sdetweil It was in the sample config file for Motion. It’s a rookie mistake that I should have replaced “value” and not merely append to this line :
                    ; on_event_start value
                    ; on_event_end value
                      sdetweil @chanster
                      @chanster ok, my module doc gives u the new lines for motion.conf
                        chanster @sdetweil
                        @sdetweil said in Help with MMM-SleepWake:
                        Yes, nothing wrong with your docs at all.
