    Full memory after update
    7 Posts 2 Posters 2.1k Views 2 Watching
    • saljokeS
      saljoke
      Hello
      I have a problem with full memory after updating of magic mirror.
      Maybe some file log been high after some days.
      How can found and delete it?
      Thanks a lot
      Saljoke
        sdetweil @saljoke
        @saljoke pm2 flush will clear the logs.
        pm2 logs --lines=100
        to see what’s there
        saljokeS 1 Reply Last reply
        • saljokeS
          saljoke @sdetweil
          The problem is…I don’t use pm2 😅😅
            sdetweil @saljoke
            @saljoke how fo u start mm?
            • saljokeS
              saljoke @sdetweil
              With npm start
                sdetweil @saljoke
                @saljoke there are utils that will show u disk usage
                du -k
                some other fancy parms will sort most used at top
                • saljokeS
                  saljoke @sdetweil
                  I solved searching on var/log files very big and I delete syslog.1 and kern.log.1
                  I don’t know really the cause but 40gb now are free.
                  Thanks again… Solved now but will check if happens again
                  Bye
