    Config modules from external file (JSON)
    config modulesjsonfile
    14 Posts 3 Posters 6.6k Views 3 Watching
    • telminiT Offline
      telmini
      Hi.
      I want to define my modules [] in a separate JSON file and then have config.js read from that file and populate it.
      Is it possible? something like this
      var config =
        address: "0.0.0.0",
        electronOptions: {},
        ipWhitelist: [],
        language: "pt",
        modules: loadJSON("configuration.json"),
        paths: {
          modules: "modules",
          vendor: "vendor"
        useHttps: false,
        httpsPrivateKey: "",
        httpsCertificate: ""
      function loadJSON(filePath){
         try {
              var fs = require('fs');
              var path = require('path');
              var filename = path.resolve(__dirname, filePath);
              var jsonFile = JSON.parse(fs.readFileSync(filename));
              return jsonFile;
            } catch (e) {
               console.error(e);
                return [];
      Thank you
        sdetweil @telmini
        @telmini the browser side also reads config.js but cannot use file (fs.) operations due to browser security
        if u can read files u can read ANY files
        • telminiT Offline
          telmini
          So, I tried this, as seen on another example in this thread
          config.js:
          var config =
            address: "0.0.0.0",
            ipWhitelist: [],
            language: "pt",
            logLevel: ["LOG", "WARN", "ERROR", "DEBUG"],
            modules: loadJSON("./modules.json"),
            paths: {
              modules: "modules",
              vendor: "vendor"
            useHttps: false,
            if (typeof module !== "undefined") {
                  return require(filePath);
              } else {
              var XMLHttpRequest = require("xmlhttprequest").XMLHttpRequest;
              var xhr = new XMLHttpRequest();
          		xhr.overrideMimeType("application/json");
          		xhr.open("GET", filePath, true);
          		xhr.onreadystatechange = function () {
          			if (xhr.readyState === 4 && xhr.status === 200) {
          				// needs error handler try/catch at least
          				let fileinfo = null;
          				try {
          					fileinfo = JSON.parse(xhr.responseText);
          				} catch (exception) {
          					// nothing here, but don't die
          					Log.error(" loading json file =" + file + " failed");
          				return fileinfo;
          		xhr.send(null);
          modules.json
                "module": "currentweather",
                "position": "top_left",
                "config": {
                  "location": "Lisboa",
                  "locationID": "2267057",
                  "appid": "314d9c29c18fd11e79034c56e1348f4c",
                  "iconTable": {
                    "01d": "wi-day-sunny",
                    "02d": "wi-day-cloudy",
                    "03d": "wi-cloudy",
                    "04d": "wi-cloudy-windy",
                    "09d": "wi-showers",
                    "10d": "wi-rain",
                    "11d": "wi-thunderstorm",
                    "13d": "wi-snow",
                    "50d": "wi-fog",
                    "01n": "wi-night-clear",
                    "02n": "wi-night-cloudy",
                    "03n": "wi-night-cloudy",
                    "04n": "wi-night-cloudy",
                    "09n": "wi-night-showers",
                    "10n": "wi-night-rain",
                    "11n": "wi-night-thunderstorm",
                    "13n": "wi-night-snow",
                    "50n": "wi-night-alt-cloudy-windy"
          And this is the output:
          ![0_1611766820659_output.png](Uploading 100%)
          output
          • telminiT Offline
            telmini
            So, it can detect that the json file has the “currentweather” module, but then fails to load it properly.
            Any help?
              sdetweil @telmini
              @telmini u have a bad path
              /js/ /modules
              note modules is off the mm root just like js
              /modules/modulename
              /js/mm_core_filename.js
              • telminiT Offline
                telmini
                @telmini said in Config modules from external file (JSON):
                loadJSON(“./modules.json”)
                But that bug/crash is inside Magic Mirror code. Or is related to the path defined here “loadJSON(”./modules.json")"?
                  sdetweil @telmini
                  @telmini i do not know, screen is hard to read. got enoent file not found. path is wrong.
                  • telminiT Offline
                    telmini
                    Sorry, this is the output.
                    > magicmirror@2.11.0 start /home/pi/MagicMirror
                    [2021-01-27 16:55:09.858] [LOG]    Starting MagicMirror: v2.11.0
                    [2021-01-27 16:55:09.878] [LOG]    Loading config ...
                    [2021-01-27 16:55:09.892] [LOG]    Loading module helpers ...
                    [2021-01-27 16:55:09.896] [LOG]    Error: ENOENT: no such file or directory, access '/home/pi/MagicMirror/js/../modules/default/currentweather/node_helper.js'
                        at Object.accessSync (fs.js:202:3)
                        at Object.fs.accessSync (electron/js2c/asar.js:491:38)
                        at loadModule (/home/pi/MagicMirror/js/app.js:124:7)
                        at loadNextModule (/home/pi/MagicMirror/js/app.js:166:5)
                        at loadModules (/home/pi/MagicMirror/js/app.js:177:3)
                        at /home/pi/MagicMirror/js/app.js:223:4
                        at loadConfig (/home/pi/MagicMirror/js/app.js:72:4)
                        at App.start (/home/pi/MagicMirror/js/app.js:211:3)
                        at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:115:7) {
                      errno: -2,
                      syscall: 'access',
                      code: 'ENOENT',
                      path: '/home/pi/MagicMirror/js/../modules/default/currentweather/node_helper.js'
                    [2021-01-27 16:55:09.924] [LOG]    No helper found for module: currentweather.
                    [2021-01-27 16:55:09.926] [LOG]    All module helpers loaded.
                    [2021-01-27 16:55:10.246] [LOG]    Starting server on port 8080 ...
                    [2021-01-27 16:55:10.256] [INFO]   You're using a full whitelist configuration to allow for all IPs
                    [2021-01-27 16:55:10.268] [LOG]    Server started ...
                    [2021-01-27 16:55:10.268] [LOG]    Sockets connected & modules started ...
                    [2021-01-27 16:55:10.428] [LOG]    Launching application.
                    I don’t understand why it’s trying to go to this path
                    Error: ENOENT: no such file or directory, access’/home/pi/MagicMirror/js/…/modules/default/currentweather/node_helper.js’
                      sdetweil @telmini
                      @telmini because its looking for the (optional) node_helper.js of a module.
                      this one, currentweather doesnt use one
                        sdetweil @telmini
                        @telmini so the returncode is right but its not fatal in mm view.
                        • telminiT Offline
                          telmini
                          It could probably be that the XmlHttpRequest is async and the page is already loaded when the request has finished executing.
                          • T Offline
                            tatianobusatto
                            Hi, I’m trying something similar. Have you managed to solve your issue using this fuction loadJSON? If not, did you find any solution to update config.js “dinamicaly”?
                              sdetweil @tatianobusatto
                              @tatianobusatto others have written js/python code that takes their settings ( file, database, web service) and applied to a model config.js. (all their modules with fake strings for keys, etc)
                              and call that js/python just before launching mm
                              in installers/mm.sh
                              • T Offline
                                tatianobusatto @sdetweil
                                @sdetweil thanks for the tip. Unfortunately, I couldn’t find a good js/python script example for that. For a while, I ended up creating a simple batch script to append multiple json config files for each module in between the config header and footer. In case you remember a place were I can find a thread for that discussion, please let me know.
