    MMM-GoogleAssistant by Bugsounet isn't taking my GoogleAIY microphone
    6 Posts 5 Posters 2.2k Views 5 Watching
      JamRaps
      https://gyazo.com/331d0b99d17f16a21218816a6650e329
      As seen in this photo, MMM-GoogleAssistant is detecting my GoogleAIY microphone, but every time I try and use it, it says “current configuration not Working”, and subdevices says 0/1. I was just wondering if this module doesn’t work with the Google AIY kit, and if I should get a usb mic. Please let me know if there is a fix for this. Thanks!
        robfer @JamRaps
        @JamRaps
        I want to try to follow this thread too, because I’ve the same problem with GoogleAIY, while the mic works perfectly with the demo python Google AIY code.
          robfer @robfer
          @JamRaps
          do you have some new info ?
          I’m continuing the investigation :
          after a lot of try I found that the problem is maybe connected to pulseaudio and arecord
          if, very fast, inside a terminal connected in ssh to the mirror, inside htop I kill the third process of pulseaudio (the mic?) and I say Jarvis wake up word the MMM/GA hear me and it try correctly to answer me , but the pulseaudio process (correctly?) respawn and only two time (for lucky my credential are ok!) I can see the answer but after this this the mic is blocked again
          info founded here
          https://askubuntu.com/questions/1207680/stop-pulseaudio-from-restarting-under-gdm-systemd-other-answers-do-not-work
          still searching for the correct solution 😞
            sdetweil @robfer
            @robfer there was an update to the hat code last year that fixed a problem lile this…
              robfer @sdetweil
              @sdetweil Hi, I’ve taken the latest raspberri Pi OS
              of the 11 january 2021 for a full restart
              and added the info for AIY HAT v1
              that I found here
              https://github.com/google/aiyprojects-raspbian/blob/aiyprojects/HACKING.md#install-aiy-software-on-an-existing-raspbian-system
              but no luck, I’m always blocked
                raf
                i also had problems with my micro in the beginning and removed pulseaudio from the pi and had no more problems
                sudo apt-get autoremove --purge pulseaudio
