    MMM-RemoteCompliments-Black Screen
    13 Posts 3 Posters 2.3k Views 3 Watching
      sdetweil @shagtimetim
      @shagtimetim but the black screen has a cause. show us the messages.
      didu run npm install in the new module folders if the instructions said to? were there any errors?
      did u do one module at a time, or throw it all in at once.
      so, messages from npm start window please
      npm start >somefile
      wait, black screen
      alt-spacebar, n
      ctrl-c in npm start window
      show contents of somefile
        shagtimetim @sdetweil
        @sdetweil Yes, I installed the modules individually and as directed. The APIs and all other things loaded successfully. I really think I am just confused with the simplicity of the config. At least I hope that is all:
        magicmirror@2.14.0 start /home/pi/MagicMirror
        DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js “run”
        [27.01.2021 16:28.28.299] [LOG] Starting MagicMirror: v2.14.0
        [27.01.2021 16:28.28.305] [LOG] Loading config …
        [27.01.2021 16:28.28.310] [LOG] Loading module helpers …
        [27.01.2021 16:28.29.760] [LOG] Initializing new module helper …
        [27.01.2021 16:28.29.762] [LOG] Module helper loaded: MMM-RemoteCompliments
        [27.01.2021 16:28.29.764] [LOG] All module helpers loaded.
        [27.01.2021 16:28.29.845] [LOG] Starting server on port 8080 …
        [27.01.2021 16:28.29.859] [LOG] Server started …
        [27.01.2021 16:28.29.861] [LOG] Connecting socket for: MMM-RemoteCompliments
        [27.01.2021 16:28.29.863] [LOG] Starting node helper for: MMM-RemoteCompliments
        [27.01.2021 16:28.29.864] [LOG] Sockets connected & modules started …
        [27.01.2021 16:28.30.157] [LOG] Launching application.
        [27.01.2021 16:28.30.190] [WARN] (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently “false”. It will change to be “true” in Electron 9. For more information please check https://github.com/electron/electron/issues/18397
        ^C
        Inserted this at the bottom but above the line of the config.js. I have tried inserting it highter without the var config liine with no success
        var config = {
        module: “MMM-RemoteCompliments”,
        header: “MMM-RemoteCompliments”,
        // See below for configurable options
          shagtimetim
          /* Magic Mirror Config Sample
           * By Michael Teeuw https://michaelteeuw.nl
           * MIT Licensed.
          var config = {
          	address: "localhost", 	// Address to listen on, can be:
          	port: 8080,
          	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
          	ipWhitelist: ["xxx", "::ffff:1xxx", "::1"], 	// Set [] to allow all IP addresses
          															// or add a specific IPv4 of 1xx5 :
          															// ["xx", "::ffff:1xxx1", "::1", "::ffff:192.168.1.5"],
          															// or IPv4 range of 1xx0 --> 1xx use CIDR format :
          															// ["1xx1", "::ffff:1xx.1", "::1", "::ffff:192.168.3.0/28"],
          	language: "en",
          	timeFormat: 12,
          	units: "imperial",
          			module: "alert",
          			module: "updatenotification",
          			position: "top_bar"
          			module: "clock",
          			position: "top_left"
          			header: "US Holidays",
          						symbol: "calendar-check",
          						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
          			module: "compliments",
          			position: "lower_third"
          			module: "currentweather",
          				locationID: "xx", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          				appid: "1xx"
          			module: "weatherforecast",
          			header: "Weather Forecast",
          				locationID: "4xxx", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          				appid: "xxx"
          			module: "newsfeed",
          			position: "bottom_bar",
          				feeds: [
          						title: "Fox News - National",
          						url: "http://feeds.foxnews.com/foxnews/national"
                                                          title: "Fox News - Latest",
                                                          url: "http://feeds.foxnews.com/foxnews/latest"
                                                          title: "ESPN - Headlines",
                                                          url: "https://www.espn.com/espn/rss/news",
          				showSourceTitle: true,
          				showPublishDate: true,
          				broadcastNewsFeeds: true,
          				broadcastNewsUpdates: true
              module: "MMM-awesome-alexa",
                  wakeWord: "Smart Mirror",
                  clientId: "xxxf",
                  clientSecret: "xxx",
                  deviceId: "xxxr",
                  refreshToken: "xxx",
                  lite: true,
                  isSpeechVisualizationEnabled: true
          var config = {
                      module: "MMM-RemoteCompliments",
                      header: "MMM-RemoteCompliments",
            @shagtimetim said in MMM-RemoteCompliments-Black Screen:
            var config = {
            what is that mess? there is only one config={ and one modules array
            please see the links in my signature below on adding modules and making a config file
              @sdetweil This is why I am glad you are the expert. Hopefully, I can return the favor one day. I will check out your links. Thank you Sam!
                shagtimetim
                For other newbies reading this thread, the links beneath Sam’s name are priceless. However, degrading banter is not helpful on anyone’s thread including this one. That being said, I simply added a “},” also known in my world as a closed bracket with a comma beneath my AwesomeAlexa module. That solve my issue of the black screen. I am now getting a known issue related to the Electron of which there is help located on github. I may need additional assistance with this error, but even a newbie of two weeks can do some incredible things with the platform Mitch and others have willingly provided us
                  shagtimetim
                    @shagtimetim i dont see how you can fix that with a },
                      @sdetweil Feel free to give it a shot. replace the XXX fields with your personal info:
                      • By Michael Teeuw https://michaelteeuw.nl
                      • MIT Licensed.
                      • For more information on how you can configure this file
                      • See https://github.com/MichMich/MagicMirror#configuration
                      var config = {
                      // - “0.0.0.0”, “::” to listen on any interface
                      // Default, when address config is left out or empty, is “localhost”
                      port: 8080,
                      basePath: “/”, // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                      ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
                      // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
                      // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
                      language: "en",
                      timeFormat: 12,
                      units: "imperial",
                      		module: "alert",
                      		position: "top_bar"
                      		module: "clock",
                      			locationID: "XXX", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                      			appid: "XXX"
                      			appid: "XXX"
                      		module: "newsfeed",
                      			feeds: [
                      module: “MMM-awesome-alexa”,
                      position: “bottom_bar”,
                      wakeWord: “Smart Mirror”,
                      clientId: “XXX”,
                      clientSecret: “XXX”,
                      deviceId: “XXX”,
                      refreshToken: “XXX”,
                      lite: true,
                      if (typeof module !== “undefined”) {module.exports = config;}
