    [assistant] recipe error ............ please help to solve me
    2 Posts 1 Posters 413 Views 1 Watching
      coolkkmirror
      C 1 Reply Last reply
        coolkkmirror @coolkkmirror
        pi@raspberrypi:~ $ cd MagicMirror
        magicmirror@2.14.0 start /home/pi/MagicMirror
        [07.02.2021 20:13.42.795] [LOG] Starting MagicMirror: v2.14.0
        [07.02.2021 20:13.42.801] [LOG] Loading config …
        [07.02.2021 20:13.42.807] [LOG] Loading module helpers …
        [07.02.2021 20:13.42.809] [LOG] No helper found for module: alert.
        [07.02.2021 20:13.42.933] [LOG] Initializing new module helper …
        [07.02.2021 20:13.42.934] [LOG] Module helper loaded: updatenotification
        [07.02.2021 20:13.42.935] [LOG] No helper found for module: clock.
        [07.02.2021 20:13.43.343] [LOG] Initializing new module helper …
        [07.02.2021 20:13.43.344] [LOG] Module helper loaded: calendar
        [07.02.2021 20:13.45.069] [LOG] Initializing new module helper …
        [07.02.2021 20:13.45.070] [LOG] Module helper loaded: MMM-GoogleAssistant
        [07.02.2021 20:13.45.198] [LOG] Initializing new module helper …
        [07.02.2021 20:13.45.199] [LOG] Module helper loaded: MMM-Snowboy
        [07.02.2021 20:13.45.200] [LOG] No helper found for module: compliments.
        [07.02.2021 20:13.45.201] [LOG] No helper found for module: currentweather.
        [07.02.2021 20:13.45.202] [LOG] No helper found for module: weatherforecast.
        [07.02.2021 20:13.45.203] [LOG] No helper found for module: MMM-NowPlayingOnSpotify.
        [07.02.2021 20:13.45.203] [LOG] No helper found for module: MMM-AirQuality.
        [07.02.2021 20:13.45.225] [LOG] Initializing new module helper …
        [07.02.2021 20:13.45.226] [LOG] Module helper loaded: newsfeed
        [07.02.2021 20:13.45.226] [LOG] All module helpers loaded.
        [07.02.2021 20:13.45.323] [LOG] Starting server on port 8080 …
        [07.02.2021 20:13.45.335] [LOG] Server started …
        [07.02.2021 20:13.45.336] [LOG] Connecting socket for: updatenotification
        [07.02.2021 20:13.45.337] [LOG] Connecting socket for: calendar
        [07.02.2021 20:13.45.339] [LOG] Starting node helper for: calendar
        [07.02.2021 20:13.45.340] [LOG] Connecting socket for: MMM-GoogleAssistant
        [07.02.2021 20:13.45.341] [LOG] Connecting socket for: MMM-Snowboy
        [07.02.2021 20:13.45.341] [LOG] [SNOWBOY] Starting…
        [07.02.2021 20:13.45.342] [LOG] Connecting socket for: newsfeed
        [07.02.2021 20:13.45.343] [LOG] Starting node helper for: newsfeed
        [07.02.2021 20:13.45.343] [LOG] Sockets connected & modules started …
        [07.02.2021 20:13.45.646] [LOG] Launching application.
        [07.02.2021 20:13.45.687] [WARN] (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently “false”. It will change to be “true” in Electron 9. For more information please check https://github.com/electron/electron/issues/18397
        [07.02.2021 20:13.47.908] [LOG] [SNOWBOY] Model selected: smart_mirror
        [07.02.2021 20:13.47.917] [LOG] Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/coolkkmirror%40gmail.com/public/basic.ics - Interval: 300000
        [07.02.2021 20:13.48.007] [LOG] [SNOWBOY] Model selected: smart_mirror
        [07.02.2021 20:13.48.012] [LOG] Create new news fetcher for url: https://timesofindia.indiatimes.com/rssfeeds/3942666.cms - Interval: 300000
        [07.02.2021 20:13.48.067] [INFO] Checking git for module: MMM-GoogleAssistant
        [07.02.2021 20:13.48.071] [INFO] Checking git for module: MMM-Snowboy
        [07.02.2021 20:13.48.074] [LOG] [ASSISTANT] MMM-GoogleAssistant Version: 2.5.1
        [07.02.2021 20:13.48.096] [LOG] [ASSISTANT] RECIPE_ERROR (with-MMM-Snowboy.js): Cannot find module ‘./recipes/with-MMM-Snowboy.js’
        Require stack:
        • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_helper.js
        • Error: Cannot find module ‘./recipes/with-MMM-Snowboy.js’
          Require stack:
        • at Module._resolveFilename (internal/modules/cjs/loader.js:798:15)
          at Function…/lib/common/reset-search-paths.ts.Module._resolveFilename (electron/js2c/browser_init.js:7718:16)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
          at Module._load (internal/modules/cjs/loader.js:691:27)
          at Function.Module._load (electron/js2c/asar.js:748:26)
          at Module.require (internal/modules/cjs/loader.js:853:19)
          at require (internal/modules/cjs/helpers.js:74:18)
          at Class.loadRecipes (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_helper.js:1:4556)
          at Class.initialize (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_helper.js:1:3673)
          at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_helper.js:1:714) {
          code: ‘MODULE_NOT_FOUND’,
          requireStack: [
          ‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_helper.js’,
          ‘/home/pi/MagicMirror/js/app.js’,
          ‘/home/pi/MagicMirror/js/electron.js’,
          ‘/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,
          undefined
          [07.02.2021 20:13.48.106] [LOG] [NPM] Initialized v0.9.91
          [07.02.2021 20:13.48.279] [LOG] [ASSISTANT] Google Assistant is initialized.
          [07.02.2021 20:13.49.370] [INFO] Newsfeed-Fetcher: Broadcasting 20 items.
          [07.02.2021 20:13.49.661] [INFO] Calendar-Fetcher: Broadcasting 1 events.
          [07.02.2021 20:13.51.670] [LOG] Shutting down server…
          [07.02.2021 20:13.51.671] [LOG] Stopping module helper: updatenotification
          [07.02.2021 20:13.51.672] [LOG] Stopping module helper: calendar
          [07.02.2021 20:13.51.673] [LOG] Stopping module helper: MMM-GoogleAssistant
          [07.02.2021 20:13.51.674] [LOG] Stopping module helper: MMM-Snowboy
          [07.02.2021 20:13.51.675] [LOG]
