    currentWeather module showWindDirection not working
    4 Posts 2 Posters 951 Views 2 Watching
      SaltyRiver
      I am trying to disable the showWindDirection by overwriting the default property to false. But it does not take effect. All other properties like for example showHumidity I tried out work, its just that I cant get the wind direction disabled. Anyone got a clue? Thanks!
        sdetweil @SaltyRiver
        @saltyriver can u show the module config from config.js
          SaltyRiver @sdetweil
          @sdetweil This is my module config with the sensitive infos removed of course. It works fine, just the showWindDirection property refuses to:
          module: “currentweather”,
          position: “top_right”,
          locationID: “My location ID”,
          appid: “My appid”,
          roundTemp: true,
          degreeLabel: true,
          showWindDirection: false,
          showHumidity: false,
          initialLoadDelay: 1000
            @saltyriver spelled correctly, in right place, not sure why
            if u open dev window, sources tab , modules open the source for current weather.js put a stop on line 130 (click line number), push f5, or ctrl-r
            which is bad, hover mouse over to view object
            this
            config
            showWindDirection
