    The MMM-Tools V2 doesn’t work
    9 Posts 2 Posters 1.5k Views 2 Watching
    • PeterPangP Online
      PeterPang
      he MMM-Tools V2 doesn’t work** , showed as below :
      pi@raspberrypi:~ $ cd [YourMagicMirrorDirectory]/modules
      bash: cd: [YourMagicMirrorDirectory]/modules: No such file or directory
      pi@raspberrypi:~ $ git clone https://github.com/eouia/MMM-Tools
      Cloning into ‘MMM-Tools’…
      remote: Enumerating objects: 5, done.
      remote: Counting objects: 100% (5/5), done.
      remote: Compressing objects: 100% (5/5), done.
      remote: Total 471 (delta 0), reused 0 (delta 0), pack-reused 466
      Receiving objects: 100% (471/471), 291.40 KiB | 429.00 KiB/s, done.
      Resolving deltas: 100% (271/271), done.
      pi@raspberrypi:~ $ npm start dev
      npm ERR! code ENOENT
      npm ERR! syscall open
      npm ERR! errno -2
      npm ERR! enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
      npm ERR! enoent This is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR! /home/pi/.npm/_logs/2021-02-08T09_12_00_398Z-debug.log
      pi@raspberrypi:~ $
        sdetweil @PeterPang
        @peterpang rihgt. you misunderstood the instructions
        the first command is
        cd [yourMagicMirrordirectory]/modules
        which means, replace [yourMagicMirrordirectory] with the name of your installation folder as u can nsme it anything
        which would typically be
        cd ~/MagicMirror/modules
        and then the module install git clone
        and the start. it needs to be done in the ~/MagicMirror folder too
        PeterPangP 2 Replies Last reply Reply Quote 0
        • PeterPangP Online
          PeterPang @sdetweil
          Thankyou , do it later ^^
          • PeterPangP Online
            PeterPang @sdetweil
            Can I just use the module name , such as MMM-Tools V2 to replace ?
            CHANGE TO
            $ cd MMM-Tools V2/module
            like this ?
              sdetweil @PeterPang
              @peterpang no. you need to be in ~/MagicMirror/modules
              then
              git clone …module_url
              cd MMM-Tools
              npm install
              npm start
              read the two links in my signature, practice
              • PeterPangP Online
                PeterPang @sdetweil
                OK , I try again , thanks !
                • PeterPangP Online
                  PeterPang @sdetweil
                  Still not work on my screen =,="
                  1. cd ~/MagicMirror/modules
                    2)git clone https://github.com/bugsounet/MMM-Tools
                    3)cd MMM-Tools
                    4)npm install
                    5)cd ~/MagicMirror
                    6)npm start
                    then she run automatic …
                    I see one row said :
                  [10.02.2021 10:29.43.540] [WARN] (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently “false”. It will change to be “true” in Electron 9. For more information please check https://github.com/electron/electron/issues/18397
                  PeterPangP 1 Reply Last reply Reply Quote 0
                  • PeterPangP Online
                    PeterPang @PeterPang
                    @peterpang
                    The main reason just my stupid , forgot to add the scripts into config.js
                      sdetweil @PeterPang
                      @peterpang glad you found it!..
