    Local host only shows NGINX server page.
    9 Posts 4 Posters 5.4k Views 3 Watching
      Jpseck89
      Hi guys,
      does anyone have an idea where to look if when after completely following all steps pulling up http://localhost in chromium would bring up only the NGINX site not anything magic mirror related. Should i look to see if there is maybe an issue with the code I loaded to connect chromium to the server? I cant get it to show anything besides the NGINX site.
      Than
      • K Offline
        KirAsh4 Moderator
        Rather than looking for other people’s write-ups, why not follow the tried and true method that’s on the actual project page?
        https://github.com/MichMich/MagicMirror
        There is an 'Automatic Installer' section, as well as a 'Manual Installation' if things fail.
          Jpseck89
          Also want to clarify im running raspberry pi 3 model B with jesse OS. I actually went off of Dylan J. Peirces guide from reddit. Im wondering if it just isn’t going to work based on the difference in models. Any input would be appreciated.
          • K Offline
            KirAsh4 Moderator
            You need to append the port to the address. By default, MM2 runs on port 8080, so you want to load up 'http://localhost:8080'…
              paviro
              Why exactly are you using chromium anyway? There is no need for that (if you do not use a Pi 1)
              – The Doctor
                Jpseck89
                Im just going by dyan J peirces guide. Unfortunatley still having issues. When I go to http://localhost:8080 via the browser I get an error that it cant be reached. I’m guessing I just need to wipe it out and find an updated version of code for the RPI3.
                • K Offline
                  KirAsh4 Moderator
                    Jpseck89
                    Perfect. Thanks guys. I’m new to this and programming so I wasn’t even aware there was a full read me and tutorial on that site. I’ll check it out. Thanks.
                      Jpseck89 @KirAsh4
                      @KirAsh4 this worked GREAT. Thank you I have it up and running. Just one more question. Do you know how to change the orientation of the display. it comes up on the mirror horizontally(Clock in the top left corner, forecast in the right) , I would like vertically so I could flip the TV on its side behind the mirror. Thanks for any input.
                        jtyle6 @Jpseck89
                        @Jpseck89 As in Configuring the Raspberry Pi on the github wiki.
                        Rotating the screen
                        edit /boot/config.txt
                        sudo nano /boot/config.txt
                        Add the following line:
                        display_rotate=1
