EADDRINUSE: address already in use
No matter what addr/port I use, I get the msg below.
Any help is appreciated.
TIApi@magicmirror:~/MagicMirror $ npm run restart > magicmirror@2.14.0 start /home/pi/MagicMirror > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js [13.02.2021 16:42.34.745] [LOG] Starting MagicMirror: v2.14.0 [13.02.2021 16:42.34.754] [LOG] Loading config ... [13.02.2021 16:42.34.762] [LOG] Loading module helpers ... [13.02.2021 16:42.34.765] [LOG] No helper found for module: alert. [13.02.2021 16:42.34.931] [LOG] Initializing new module helper ... [13.02.2021 16:42.34.932] [LOG] Module helper loaded: updatenotification [13.02.2021 16:42.34.933] [LOG] No helper found for module: clock. [13.02.2021 16:42.34.935] [LOG] No helper found for module: currentweather. [13.02.2021 16:42.34.936] [LOG] No helper found for module: weatherforecast. [13.02.2021 16:42.35.134] [LOG] Initializing new module helper ... [13.02.2021 16:42.35.135] [LOG] Module helper loaded: MMM-Remote-Control [13.02.2021 16:42.35.431] [LOG] Initializing new module helper ... [13.02.2021 16:42.35.432] [LOG] Module helper loaded: newsfeed [13.02.2021 16:42.35.434] [LOG] Initializing new module helper ... [13.02.2021 16:42.35.435] [LOG] Module helper loaded: MMM-MoonPhase [13.02.2021 16:42.35.438] [LOG] Initializing new module helper ... [13.02.2021 16:42.35.438] [LOG] Module helper loaded: MMM-PiTemp [13.02.2021 16:42.35.730] [LOG] Initializing new module helper ... [13.02.2021 16:42.35.731] [LOG] Module helper loaded: MMM-iFrame-Ping [13.02.2021 16:42.35.732] [LOG] All module helpers loaded. [13.02.2021 16:42.35.825] [LOG] Starting server on port 8181 ... [13.02.2021 16:42.35.832] [WARN] You're using a full whitelist configuration to allow for all IPs [13.02.2021 16:42.35.841] [LOG] Server started ... [13.02.2021 16:42.35.842] [LOG] Connecting socket for: updatenotification [13.02.2021 16:42.35.843] [LOG] Connecting socket for: MMM-Remote-Control [13.02.2021 16:42.35.845] [LOG] Starting node helper for: MMM-Remote-Control [13.02.2021 16:42.35.868] [LOG] Connecting socket for: newsfeed [13.02.2021 16:42.35.869] [LOG] Starting node helper for: newsfeed [13.02.2021 16:42.35.870] [LOG] Connecting socket for: MMM-MoonPhase [13.02.2021 16:42.35.871] [LOG] Starting module helper: MMM-MoonPhase [13.02.2021 16:42.35.872] [LOG] Connecting socket for: MMM-PiTemp [13.02.2021 16:42.35.873] [LOG] Starting module helper: MMM-PiTemp [13.02.2021 16:42.35.873] [LOG] Connecting socket for: MMM-iFrame-Ping [13.02.2021 16:42.35.874] [LOG] MMM-iFrame-Ping helper started ... [13.02.2021 16:42.35.875] [LOG] Sockets connected & modules started ... [13.02.2021 16:42.35.883] [ERROR] Whoops! There was an uncaught exception... [13.02.2021 16:42.35.888] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8181 at Server.setupListenHandle [as _listen2] (net.js:1300:14) at listenInCluster (net.js:1348:12) at doListen (net.js:1487:7) at processTicksAndRejections (internal/process/task_queues.js:81:21) { code: 'EADDRINUSE', errno: 'EADDRINUSE', syscall: 'listen', address: '0.0.0.0', port: 8181 } [13.02.2021 16:42.35.890] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? [13.02.2021 16:42.35.891] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues [13.02.2021 16:42.36.145] [LOG] Launching application. [13.02.2021 16:42.36.173] [WARN] (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently "false". It will change to be "true" in Electron 9. For more information please check https://github.com/electron/electron/issues/18397 -
@ebolisa probably have pm2 running mm.
it is supposed yo autostart mm on boot, and keep it runningif using pm2 do not use npm commands until u stop pm2 instance
pm2 status
pm2 stop all -
@sdetweil actually, I use npm trhrough service to autostart it.
This’ what I get in the log. I know the app is talking to me, but I just cannot interpret it :confused_face:0 info it worked if it ends with ok 1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'stop' ] 2 info using npm@6.14.11 3 info using node@v10.23.3 4 verbose stack Error: missing script: stop 4 verbose stack at run (/usr/lib/node_modules/npm/lib/run-script.js:155:19) 4 verbose stack at /usr/lib/node_modules/npm/lib/run-script.js:63:5 4 verbose stack at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:116:5 4 verbose stack at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:436:5 4 verbose stack at checkBinReferences_ (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:391:45) 4 verbose stack at final (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:434:3) 4 verbose stack at then (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:161:5) 4 verbose stack at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:382:12 4 verbose stack at /usr/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:123:16 4 verbose stack at FSReqWrap.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:53:3) 5 verbose cwd /home/pi/MagicMirror 6 verbose Linux 5.10.11-v7l+ 7 verbose argv "/usr/bin/node" "/usr/bin/npm" "stop" 8 verbose node v10.23.3 9 verbose npm v6.14.11 10 error missing script: stop 11 verbose exit [ 1, true ] -
@ebolisa there are no nom commands stop.
u have to hit ctrl-c in the window where u started it or use sudo kill to kill the process running detached
@sdetweil Not sure I’m following you. The MM boot is done via the service and it works. Meaning, MM app is booting and the display looks as designed.
What I showed in my last post is the content of the last log file. There’s an error but I don’t know how to interpret it. -
@ebolisa it says therenis no npm stop function
@sdetweil Thanks, I’m probably looking into a non existing problem. Will check.
@ebolisa if u started it as a service, then u need to stop it as a sevice
you can remove the service and use pm2 to auto start and give u commands to stop
run the fixuppm2 script from my scripts
pm2 --help for all the things u can do
@sdetweil thank you. That explains my error shown in the first post.
I’m using npm and a service because I used this procedure to install MM https://docs.magicmirror.builders/getting-started/installation.html#manual-installation
