    PIR Sensor won't wake up
    22 Posts 7 Posters 8.6k Views 7 Watching
      Sceetch
      Hi guys,
      i want to install for my Magicmirror project a PIR Sensor (HC-SR501) for switching the monitor automatically on/off.
      i have already tested MMM-PIR-Sensor and MMM-PIR. But both have the same issue.
      After the adjusted delay the monitor switches off. But there is no chance to wake it up again.
      It seems to me that i have installed something wrong in the pins.
      In both modules i need a value for sensorPin:
      That mean the "out"wire of the PIR? thats right. That mean according my Occupancy i have to put “16” into it?
      please help!
      karsten13K D 2 Replies Last reply Reply Quote 0
      • karsten13K Online
        karsten13 @Sceetch
        should be 23 (not 16)
        alt text
          Sceetch
          Thx. now the table should be clear.
          But the PIR doesn’t work.
          After delay the screen switch off.
          But i can breakdance in front of the sensor. It happend nothing…
          but if i remove the cable from sensorpin 23 the sceen wakes up.
            Sceetch @Sceetch
            hi.
            There are some news about my Sensor problem.
            i tried to install these steps according this link
            https://teilzeitrebell.de/blog/magicmirror-part-2-bewegungsmelder
            i made two sh-scripts for screen on & off
            monitor_off.sh
            monitor_on.sh
            then i created this phyton
            pir_loop.py
            !/usr/bin/env python
            import sys
            import time
            import RPi.GPIO as io
            import subprocess
            io.setmode(io.BCM)
            SHUTOFF_DELAY = 10  # seconds
            PIR_PIN = 17        # Pin 11 on the board
            def main():
                io.setup(PIR_PIN, io.IN)
                turned_off = False
                last_motion_time = time.time()
                while True:
                    if io.input(PIR_PIN):
                        sys.stdout.flush()
                        if turned_off:
                            turned_off = False
                            turn_on()
                    else:
                        if not turned_off and time.time() > (last_motion_time + SHUTOFF_DELAY):
                            turned_off = True
                            turn_off()
                    time.sleep(.1)
            def turn_on():
                subprocess.call("sh /home/pi/Pir-Sensor/monitor_on.sh", shell=True)
            def turn_off():
                subprocess.call("sh /home/pi/Pir-Sensor/monitor_off.sh", shell=True)
            if __name__ == '__main__':
                try:
                    main()
                except KeyboardInterrupt:
                    io.cleanup()
            i can start this with
            python pir_loop.py
            and it seems that it works.
            But in the code i defined a delay of 10 seconds. But after it, it happend nothing.
            the weird thing is, that the screen turn off after exact 2 minutes. If i move in front of the sensor the screen turn on again.
            But if i do nothing or cover the sensor with something the screen turn on after exact one minute.
            does anybody has an idea, whats wrong there?
            ebolisaE 1 Reply Last reply Reply Quote 0
            • ebolisaE Offline
              ebolisa @Sceetch
              @sceetch I’ve, more or less, the same setup but the sh files stored in the MagicMirror folder.
                dbg @Sceetch
                @sceetch Which Raspberry Pi board are you using?
                  Sceetch @dbg
                  @dbg i’m using Raspberry Pi 3 Modell B Plus (B +)
                  I have no idea whats wrong.
                  I can change the delay time value randomly. There is no effect. After exact 2 minutes the screen turn off.
                  Could it be, there is something activated in the tvservice?
                  S D 3 Replies Last reply Reply Quote 0
                    sdetweil @Sceetch
                    @sceetch off is because the module does this no motion was detected
                      dbg @Sceetch
                      @Sceetch
                      Hi
                      I installed the MMM-PIR-Sensor last week and I had a similar problem. I just couldn’t get the sensor to work with the module. I spent a lot of time and tried a few different things and nothing worked… in the end I updated the wiringPi GPIO access library (I’m using a Pi 4 Model B).
                      See here:
                      http://wiringpi.com/wiringpi-updated-to-2-52-for-the-raspberry-pi-4b/
                      And now it’s working OK. I’m not saying this will fix your problem. It may be that an install I did overwrote the wiringPi files on my Pi or rolled them back in some way, but it worked for me.
                      Regards
                      dbg62
                        sdetweil @Sceetch
                        @sceetch also i think u need to make sure the sensor actually works
                        https://projects.raspberrypi.org/en/projects/parent-detector/3
