    Development Branch -- Screen Going Blank
    13 Posts 2 Posters 4.1k Views 2 Watching
      sdetweil @yk
      @yk yes, good steps
      free -m
      will tell you if any has been used
      • Y Offline
        yk @sdetweil
        @sdetweil keeps happening unfortunately. it might be time to start removing modules to see if that helps.
        Two errors seen:
        out of memory error and also saw a fatal: unable to access ‘https://github.com/MichMich/MagicMirror.git/’: gnutls_handshake() failed: Error in the push function.
        I’m only using:
        MMM-MyWastePickup (only uses local file)
        MMM-Unsplash (hits Unsplash twice an hour)
        MMM-DarkSkyForecast
        MMM-Tools
        Calendar does an iCloud refresh using vdirsyncer (every 30 minutes)
        Calendar-Fetcher looks to be doing a broadcasting of events every 10 to 12 minutes. Not sure what this is.
        mem total=925 / used=272
        swap total=1023 / used=116
        I wonder if the iCloud hit happens at the same time as the Unsplash hit causing an issue.
          sdetweil @yk
          @yk said in Development Branch -- Screen Going Blank:
          if swap was 100, now 116 meg used.
          memory 272 used doesn’t make sense
          • Y Offline
            yk @sdetweil
            @sdetweil sorry
            I bumped up the swap already to 1024
            memory
            total = 925
            used = 272
            swap
            total=1023
            used=116
              sdetweil @yk
              @yk shouldn’t have used any swap if u still have free main memory
              Y 2 Replies Last reply Reply Quote 0
              • Y Offline
                yk @sdetweil
                @sdetweil agreed.
                But i’m seeing the below after another memory issue today.
                type total used free shared buff/cache availabl
                Mem: 925 291 367 9 267 571
                Swap: 1023 93 930
                • Y Offline
                  yk @sdetweil
                  @sdetweil I’m working with the developer of MMM-Unsplash. This might be down the the usage of “raw”. Will revert.
                  Separately, just to confirm: no issue with calendar fetcher broadcasting every 10 minutes? What is it doing? (can you tell I’m sniffing everything now?) ;)
                  • Y Offline
                    yk @yk
                    @sdetweil let’s close this one. There was a need to pass through a height or width value when using MMM-Unsplash. Passing nothing seems to have grabbed the raw file and chewed up a good deal of memory. I’m still monitoring.
                    I’d love to setup a log element that drops memory usage into the pm2 logs. Just fear monitoring memory may eat up too much memory ;) (but I should have plenty of it)
                    I’m using MMM-Tools to display stats, may leverage that.
