    Help please!!
    63 Posts 4 Posters 39.7k Views 4 Watching
    • I
      innovation
      I want my mirror to display images that have been uploaded onto google photos.
      I used the MMM-GooglePhotos module and I have configured it. However, the image does not show up instead it says “Loading…”
      It hasn’t loaded in a long time. Could you tell me what the issue can be?
      This is the code in the config.sj
      module: “MMM-GooglePhotos”,
      position: “middle_center”,
      albums: [“DesignMirror”], // Set your album name. like [“My wedding”, “family share”, “Travle to Paris”]
      updateInterval: 1000 * 60, // minimum 10 seconds.
      sort: “new”, // “old”, “random”
      uploadAlbum: null, // Only album created by create_uploadable_album.js.
      condition: {
      fromDate: null, // Or “2018-03”, RFC … format available
      toDate: null, // Or “2019-12-25”,
      minWidth: null, // Or 400
      maxWidth: null, // Or 8000
      minHeight: null, // Or 400
      maxHeight: null, // Or 8000
      minWHRatio: null,
      maxWHRatio: null,
      // WHRatio = Width/Height ratio ( ==1 : Squared Photo, < 1 : Portraited Photo, > 1 : Landscaped Photo)
      showWidth: 800, // These values will be used for quality of downloaded photos to show. real size to show in your MagicMirror region is recommended.
      showHeight: 600,
      timeFormat: “YYYY/MM/DD HH:mm”, // Or relative can be used.
      Thank you! Would appreciate it a lot.
      G 1 Reply Last reply
      • G
        George @innovation
        @innovation , why you not use MMM-ImagesPhotos? There you have a folder, “uploads”, where you can upload your photos.
        I 1 Reply Last reply
        • I
          innovation @George
          @George Hello, yes I could but I want to be able to upload the images from my phone - so that it can be displayed onto the mirror. Is that possible?
            sdetweil @innovation
            @innovation I have a module that provides a QR code image that lets u upload pics from your phone to whatever source you choose.
            I use imagesphotos as my photo display module
            see
            https://github.com/sdetweil/uploadPics
            I need to debug the Google photos problem as I advised my brother in law to use that.
            u did provide a credit card as part of the Google account setup, right? you must
            B 1 Reply Last reply
              barlouka @sdetweil
              Very interesting module. How do you configure exactly the config.js? I have e message on the mirror with undefined. Here is my config file :
              module: ‘uploadPics’,
              position: ‘bottom_left’,
              dest: “/home/pi/MagicMirror/module/MMMM-ImagesPhotos/uploads”,
                sdetweil @barlouka
                @barlouka did u run the npm install?
                the doc says exactly for imagesphotos and it’s the default. so u don’t have to add the dest value
                dest:'../modules/MMM-ImagesPhotos/uploads'
                there are two programs launched in the background…
                qrcp
                and
                exiftran
                can u try to run those in a terminal window
                with --help as a parm
                  unrelated to my module, GP module works great (new gransdon)
                    my developers window console
                    Load script: modules/MMM-GooglePhotos/MMM-GooglePhotos.js
                    module.js:516 Module registered: MMM-GooglePhotos
                    loader.js:157 Bootstrapping module: MMM-GooglePhotos
                    loader.js:162 Scripts loaded for: MMM-GooglePhotos
                    loader.js:204 Load stylesheet: modules/MMM-GooglePhotos/MMM-GooglePhotos.css
                    loader.js:164 Styles loaded for: MMM-GooglePhotos
                    loader.js:166 Translations loaded for: MMM-GooglePhotos
                    MMM-GooglePhotos.js:165 [GPHOTO] Image loaded: https://lh3.googleusercontent.com/lr/AFBm1_bZ6affCvFzH-wRT8AEZAoipqL8nwQ-p9dUdQL9zfSaQ0GecFooCneL3O5dn8Ii7TH6REVMYrvqiXkUas_Ig6gSIAeIzQ8CAs...
                    • I
                      innovation @sdetweil
                      @sdetweil Hey it is showing ‘Undefined’ for me too.
                      I did run the npm install.
                      position: ‘bottom_left’, //module position
                      dest: “…/module/MMMM-ImagesPhotos/uploads”,
                        @innovation
                        qrcp
                        and
                        exiftran
                        also, look in the terminal window where you do npm start
                        • I
                          @sdetweil --help qrcp?
                            @innovation no…
                            qrcp --help
                            and
                            exiftran --help
                            • I
                              @sdetweil It says ‘command not found’
                                @innovation k… hang on
                                  barlouka @sdetweil
                                  @sdetweil also command not found
                                    sdetweil @barlouka
                                    @barlouka ok, go to the module folder and do git pull
                                    then do npm install again
                                    then test qrcp --help
                                    • I
                                      @sdetweil It still shows command not found
                                        @innovation yeh, crazy… how it ever worked before I don’t know
                                        ONE more time git pull, npm install
                                        • I
                                          @sdetweil Haha sure! Just to clarify in
                                          ‘-/MagicMirror/modules/uploadPics’ folder in the terminal right?
                                            @innovation but the module wants RELATIVE to it… NOT absolute
                                            SO, …/MMM-ImagesPhotos/upload
                                            … means back up one level
                                            and, if you are using the MMM-ImagesPhotos module to display images, then the uploadPics dest: default is …/MMM-ImagesPhotos/upload
                                            from the readme
                                            	dest:  "..", // relative path to module showing images, place to put new images
                                                        // for MMM-ImagesPhotos dest is (the default)
                                            	//  ../modules/MMMM-ImagesPhotos/uploads
                                            • 1 / 4
