    Calendar module EHOSTUNREACH error
    calendarehostunreacherror
    4 Posts 2 Posters 960 Views 2 Watching
      SaltyRiver
      Hi everyone,
      I am running MM in a docker container. Displaying all my appointements worked completely fine until this evening it just stopped for some reason. When I restart the container it spits out the following error (see image). I have no clue what is causing this all of a sudden. It is a private google calendar, the private address is unchanged and used to work until this evening. Can anyone help me regarding this? Thanks a lot! ! Screenshot 2021-03-27 192539.png
        sdetweil @SaltyRiver
        @saltyriver that is a networking problem… your router, or pihole or somethign needs to be restarted
          SaltyRiver @sdetweil
          @sdetweil Sorry I should have been a bit more specific regarding that. I use other modules that connect over the Internet and those work finde. Router restarting and so on I tried. I managed to find a solution though: I removed the configuration for the static IP adress for the Pi and that solved it for some reason.
            @saltyriver said in Calendar module EHOSTUNREACH error:
            weird… but still a networking problem
