    Header missing for Current weather (MMM_OpenMapWeather)
    10 Posts 3 Posters 2.6k Views 3 Watching
    • N Offline
      Nneuland @Nneuland
      @nneuland https://forum.magicmirror.builders/assets/uploads/files/1616691041491-weather_header.png
      To clarify. I am looking to include “Atlanta” header
      only New York
        scumbelly
        @Nneuland ,
        Sorry, my example was not explained properly. It was basically how not to put the Location/LocationID name in the header. In my example you would just edit the header to say header: “Weather Forecast for New York”, or in your case just “New York, USA”. With the appendLocationNameToHeader: false, I put this in to stop the the appid city ID being populated as my location because it wasn’t my village name but a nearby city. So in your instance, if I remember correctly, your don’t need header: it should be fine with appendLocationNameToHeader: true,
        The default config for openmapweather
        module: “MMM-OpenmapWeather”,
        position: “top_left”, // This can be any of the regions.
        // Best results in left or right regions.
        // See ‘Configuration options’ for more information.
        locationID: “”, //Location ID from http://openweathermap.org/help/city_list.txt
        appid: “abcde12345abcde12345abcde12345ab”, //openweathermap.org API key
        colorIcon: true
        should just be location:“New York”,
        locationID: “5128581”,
        appid: “xxxxxxxxxxx”,
        If you want the USA, location “New York, USA” that might work. It may not like the USA part because it might conflict with the returned locationID of just New York - I can’t remember. If you want USA you’ll have to create the header “New York, USA” using my example. I hope your config.js file has a comma at the end of your appid".
        Cheers, hope this helps.
        • N Offline
          Nneuland @scumbelly
          @scumbelly
          Thank you so much for your time. Doing research on this, I never see a header on the openmapweather mmm. Only with the default current weather module is there a header.
          Perhaps I should investigate why the default current weather mmm wont work. Thanks again for your help
          • N Offline
            Nneuland @Nneuland
            @scumbelly
            Just figured I would let you know. I nixed the openmapweather mmm, and found a way to get the default current weather module working AND displaying a New York header. Thanks again for the support.
            • E Offline
              eltonnascimento
              @nneuland said in Header missing for Current weather (MMM_OpenMapWeather):
              @scumbelly
              how did u solve this?
              • N Offline
                Nneuland @eltonnascimento
                @eltonnascimento
                Hi. Apologize for the late response.
                Not sure I would call this a fix. I reverted back to the default Current Weather module and avoided the Openmapweather module all together. For the life of me I couldn’t figure a way to show a header with the Openmapweather. However, the default Current weather worked.
                Hope this helps
