    Use of array within all module files
    10 Posts 2 Posters 3.0k Views 2 Watching
    • bdeelmanB
      bdeelman
      I convert a CSV file to a JSON array at the node_helper.js file. This array (subscriptions) is needed at several functions at the mmm-sample.js file.
      The array is available at other functions within the node_helper.js I use this.subscriptions = (jsonObj); within the CSVtoJSON function and declare var subscriptions = []; at the top of nodehelper.js and also at the mmm-sample.js.
      How can I achieve this? Do I need the sendSocketNotification functionality to send data back and forth between the files?
      Any help is much appreciated.
      Regards,
      Bert
        sdetweil @bdeelman
        @bdeelman correct. the helper gets data, and sends it to the module to use
        I use the csvtojson library in my MyCovid19 module.
        • bdeelmanB
          bdeelman
          Hi Sam,
          I take a look at that code. I can read it. ;) But can’t find the answer.
          This are my thougts. From start() I send
          this.sendSocketNotification('CONFIG', this.config);
          The this.config payload is needed at the node_helper.js at two places. One to figure out the csv file and do the MQTT stuff.
          CSVToJSON({ ignoreEmpty: true, trim: true })
          		.fromFile(CSVfile)
          		.then((jsonObj) => {
          			//console.log(jsonObj);
          			this.subscriptions = (jsonObj); //JSON.parse
          			this.setconfig(payload);
          I forward the this.config to the MQTT function. The array subscriptions is available there. At the MQTT function:
          self.sendSocketNotification('MQTT_PAYLOAD', {
          				topic: topic,
          				value: value,
          				subs: self.subscriptions
          These payloads arrived within the function at the module file. But I can not use the payload outside of that specific function.
          I am not a programmer as you can see…just using reverse engineering and read a lot of configurations. I am almost there, I think.
          Regards,
          Bert
          S 2 Replies Last reply
            sdetweil @bdeelman
            @bdeelman you would save the config value in a variable usable by all routines in the source file.
            u do not need to save in the modulename.js, as it is provided as this.config
            bdeelmanB 1 Reply Last reply
            • bdeelmanB
              bdeelman @sdetweil
              @sdetweil can you be more precise? I did not understand you.
              The subscriptions is the generate json array with all kind of information to build an element / divs etc. That array is build at node_helper.js and globally needed within modulename.js.
              As I understand the way of working well…?
              Regards,
              Bert
                sdetweil @bdeelman
                @bdeelman said in Use of array within all module files:
                so in the receiving function, store the payload value somewhere that other functions can use it
                this.subscriptions=payload
                similar for the config info in the node_helper
                • bdeelmanB
                  bdeelman @sdetweil
                  @sdetweil Thanks for your reply. Much appreciated!
                  I think I need another approach to get the result that I need. The subscriptions array is (must be) part of the this.config. So I add subscriptions: [];to the defaults: at the modulename.js
                  The thing now is add the generated JSON (csvtojson) to the this.config. :grinning_face_with_big_eyes: and I can use this.config as a payload.
                  The array is something like this:
                  subscriptions = [{
                      topic: 'homey/light/keuken/dimmer-fibaro-1/onoff', // MQTT Topic name
                      label: 'Licht keuken',
                      type: 'device',
                      display: { left: 50, top: 50  },
                      topic: 'homey/sensor/washok/temp-hum-xiaomi-1/measure-temperature',
                      label: 'Washok Temp',
                      type: 'label',
                      display: { left: 265, top: 0, prefix: "", suffix: "°C", decimals: 0 },
                    sdetweil @bdeelman
                    @bdeelman sorry I do not understand what you want
                    u can send anything with sendSocketNotification and you can store it anywhere, not just in this.config
                    • bdeelmanB
                      bdeelman @sdetweil
                      @sdetweil I am sorry and lost. ;)
                      The sendSocketNotification from node_helper.js
                      				topic: topic,
                      				value: value,
                      So if I understand correctly…I should add this.subscriptions = payload; at the receiving function socketNotificationReceived at modulename.js
                        if (notification === 'MQTT_PAYLOAD') {
                      I did that but it is not working. The array is not available at other functions within modulename.js.
                      At the node_helper part it is working. this.subscriptions = (jsonObj);and I can use the array at other functions. with
                      var self = this;
                      var l = self.subscriptions.length; // as an example.
                        sdetweil @bdeelman
                        @bdeelman so, I would open the developers window., ctrl-shift-i on the pi MM window
                        select the sources tab, navigate the left nav modules/your module name, select the source file name modulename.js
                        scroll to the line for the socketNotificationReceived().
                        this.
                        and click the number at the left edge of that line, should turn blue
                        then hit f5 to refresh the page, and MM will reload and you should stop at the line…
                        move your mouse over the word ‘this’, and it should expand a box describing what this points to , which should be THIS modules instance data…
                        if not, then THAT is the problem…
