    MagicMirror² v2.15.0 is available don't work.
    44 Posts 9 Posters 21.7k Views 10 Watching
      sdetweil @BKeyport
      @bkeyport great!
      C 1 Reply Last reply
        ChrizZz @sdetweil
        I do have some strange things after the update.
        At first, the new weather module is just “loading” without displaying content. Even after 30+ minutes. Is there something wrong with the config? I saw that there is a minor issue with the data request which will cause it to load for ~10min (or to reduce the update interval).
        			module: "weather",
        			classes: "always",
        				type: "current",
        				locationID: "YYY",
        				appid: "XXX"
        And I have new lines of errors in the log, I don’t understand why these syntax errors appear. I checked my config file and everything looks fine. Regarding git, does this mean it couldn’t connect to github?
        [03.04.2021 23:22.22.900] [ERROR] Failed to parse data , error SyntaxError: Unexpected end of JSON input
        [03.04.2021 23:22.24.037] [ERROR] Failed to parse data , error SyntaxError: Unexpected end of JSON input
        [03.04.2021 23:22.25.987] [ERROR] Failed to fetch git data for MMM-CountEvents: Error: block timeout reached
        [03.04.2021 23:22.27.080] [ERROR] Failed to fetch git data for MMM-Parcel: Error: block timeout reached
        [03.04.2021 23:22.35.518] [ERROR] Failed to fetch git data for MMM-Face-Reco-DNN: Error: block timeout reached
        [03.04.2021 23:22.39.290] [ERROR] Failed to fetch git data for MMM-PIR-Sensor: Error: block timeout reached
        [03.04.2021 23:32.42.638] [ERROR] Failed to fetch git data for MMM-CountEvents: Error: block timeout reached
        [03.04.2021 23:37.14.466] [ERROR] Failed to parse data , error SyntaxError: Unexpected end of JSON input
        [03.04.2021 23:37.14.577] [ERROR] Failed to parse data , error SyntaxError: Unexpected end of JSON input
        [03.04.2021 23:52.14.126] [ERROR] Failed to parse data , error SyntaxError: Unexpected end of JSON input
        [03.04.2021 23:52.14.377] [ERROR] Failed to parse data , error SyntaxError: Unexpected end of JSON input
        S C 2 Replies Last reply
          sdetweil @ChrizZz
          @chrizzz looks like a networking error… did u npm install after git pull? did both work?
            danjvd @sdetweil
            @sdetweil Thanks for the help, was about to make a post when I found this thread.
              ChrizZz @sdetweil
              @sdetweil yes I did and both worked.
              I did npm install in all module folders too and did the npm install of MM multiple times just to check if something is wrong
              • StoffbeuteluweS
                Stoffbeuteluwe Project Sponsor
                Hallo, i have installed the updatescript and than I have installed the valid url …the mirror starts normal and when i stop the Mirror I get this.
                nal SIGINT
                npm ERR! code ELIFECYCLE
                npm ERR! errno 1
                npm ERR! magicmirror@2.15.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                npm ERR! Exit status 1
                npm ERR!
                npm ERR! Failed at the magicmirror@2.15.0 start script.
                npm ERR!     /Users/patrickhahn/.npm/_logs/2021-04-06T20_05_51_094Z-debug.log
                patrickhahn@Mac-mini MagicMirror %
                hope somebody can help me …thanks
                  sdetweil @Stoffbeuteluwe
                  @stoffbeuteluwe that’s ok when u stop
                  • unfriendlydeviceU
                    unfriendlydevice @sdetweil
                    @sdetweil what is the full command to run this? I’ve done some searching on the forum but haven’t found anything.
                      sdetweil @unfriendlydevice
                      @unfriendlydevice run ‘this’???
                      unfriendlydeviceU 1 Reply Last reply
                      • unfriendlydeviceU
                        @sdetweil to run the electron-rebuild as you advised (sorry I think I replied to the main thread instead of your earlier reply)
                          @unfriendlydevice
                          npm install electron-rebuild
                          now change to your module folder where u need the electron rebuild
                          then
                          ~/MagicMirror/node_modules/.bin/electron-rebuild
                          (note the dot . in front of bin)
                          • unfriendlydeviceU
                            @sdetweil That’s great thanks
                              ChrizZz @ChrizZz
                              @chrizzz said in MagicMirror² v2.15.0 is available don't work.:
                              			module: "weather",
                              			classes: "always",
                              				type: "current",
                              				locationID: "YYY",
                              				appid: "XXX"
                              I checked this again with switching back to the old module and the old module works. The forcasting takes 10min (as expected) but the module itself works. I thought this might be something with the connection to the API. Any ideas?
                              • 3 / 3
