    RSS-Parser error?
    2 Posts 2 Posters 614 Views 2 Watching
      paulyp2k6
      I Think I am getting an RSS-Parser error when I run my config file. But, I am not sure where the issue is or what module is causing it.
      magicmirror@2.15.0 start /home/pi/MagicMirror
      [14.04.2021 21:58.53.881] [LOG] Starting MagicMirror: v2.15.0
      [14.04.2021 21:58.53.887] [LOG] Loading config …
      [14.04.2021 21:58.53.894] [LOG] Loading module helpers …
      [14.04.2021 21:58.53.896] [LOG] No helper found for module: alert.
      [14.04.2021 21:58.54.067] [LOG] Initializing new module helper …
      [14.04.2021 21:58.54.068] [LOG] Module helper loaded: updatenotification
      [14.04.2021 21:58.54.069] [LOG] No helper found for module: clock.
      [14.04.2021 21:58.54.587] [LOG] Initializing new module helper …
      [14.04.2021 21:58.54.588] [LOG] Module helper loaded: calendar
      [14.04.2021 21:58.54.589] [LOG] No helper found for module: compliments.
      [14.04.2021 21:58.54.589] [LOG] No helper found for module: weather.
      [14.04.2021 21:58.54.591] [LOG] Initializing new module helper …
      [14.04.2021 21:58.54.592] [LOG] Module helper loaded: MMM-MyScoreboard
      [14.04.2021 21:58.54.596] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘rss-parser’
      Require stack:
      • /home/pi/MagicMirror/modules/MMM-MyWeather/node_helper.js
      [14.04.2021 21:58.54.597] [LOG] Loading module helpers …
      [14.04.2021 21:58.54.597] [LOG] No helper found for module: alert.
      [14.04.2021 21:58.54.598] [LOG] Initializing new module helper …
      [14.04.2021 21:58.54.599] [LOG] Module helper loaded: updatenotification
      [14.04.2021 21:58.54.600] [LOG] No helper found for module: clock.
      [14.04.2021 21:58.54.601] [LOG] Initializing new module helper …
      [14.04.2021 21:58.54.601] [LOG] Module helper loaded: calendar
      [14.04.2021 21:58.54.603] [LOG] No helper found for module: compliments.
      [14.04.2021 21:58.54.604] [LOG] No helper found for module: weather.
      [14.04.2021 21:58.54.605] [LOG] Initializing new module helper …
      [14.04.2021 21:58.54.605] [LOG] Module helper loaded: MMM-MyScoreboard
      [14.04.2021 21:58.54.607] [ERROR] App threw an error during load
      [14.04.2021 21:58.54.609] [ERROR] Error: Cannot find module ‘rss-parser’
      Require stack:
      • at Module._resolveFilename (internal/modules/cjs/loader.js:972:15)
        at Function.n._resolveFilename (electron/js2c/browser_init.js:249:921)
        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
        at Module._load (internal/modules/cjs/loader.js:848:27)
        at Function.f._load (electron/js2c/asar_bundle.js:5:12738)
        at Module.require (internal/modules/cjs/loader.js:1032:19)
        at require (internal/modules/cjs/helpers.js:72:18)
        at Object. (/home/pi/MagicMirror/modules/MMM-MyWeather/node_helper.js:13:17)
        at Module._compile (internal/modules/cjs/loader.js:1152:30)
        at Object.Module._extensions…js (internal/modules/cjs/loader.js:1173:10)
        [14.04.2021 21:58.54.610] [ERROR] Whoops! There was an uncaught exception…
        [14.04.2021 21:58.54.616] [ERROR] Error: Cannot find module ‘rss-parser’
        Require stack:
        at Object.Module._extensions…js (internal/modules/cjs/loader.js:1173:10) {
        code: ‘MODULE_NOT_FOUND’,
        requireStack: [
        ‘/home/pi/MagicMirror/modules/MMM-MyWeather/node_helper.js’,
        ‘/home/pi/MagicMirror/js/app.js’,
        ‘/home/pi/MagicMirror/js/electron.js’,
        ‘/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,
        undefined
        [14.04.2021 21:58.54.619] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        [14.04.2021 21:58.54.619] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        [14.04.2021 21:58.54.895] [LOG] Launching application.
        [14.04.2021 21:58.59.153] [LOG] Shutting down server…
        [14.04.2021 21:58.59.158] [LOG] Stopping module helper: updatenotification
        [14.04.2021 21:58.59.159] [LOG] Stopping module helper: calendar
        [14.04.2021 21:58.59.160] [LOG] Stopping module helper: MMM-MyScoreboard
        [14.04.2021 21:58.59.161] [LOG] Stopping module helper: updatenotification
        [14.04.2021 21:58.59.162] [LOG] Stopping module helper: calendar
        [14.04.2021 21:58.59.163] [LOG] Stopping module helper: MMM-MyScoreboard
        sdetweil @paulyp2k6
        @paulyp2k6 said in RSS-Parser error?:
        /MMM-MyWeather
        we took out a bunch of modules that use code that is recommended to be discontinued
        some modules used things without documenting them… here is another case
        to fix
        in a terminal window
        cd ~/MagicMirror/modules/MMM-MyWeather
        npm install  rss-parser
        then restart MagicMirror
