    Can't change color of analog clock in default clock module
    Scheduled Pinned Locked Moved Solved Custom CSS
    4 Posts 2 Posters 2.0k Views 2 Watching
      jjd
      I’m not an expert CSS guy, but I thought I was doing the right thing. Can someone let me know what I’m doing wrong? I want the entire analog face red for night time.
      In my config/config.js, I have this for the clock module:
      	    module: "clock",
      	    position: "middle_center",
      	    classes: "nightclock",
      	    displaySeconds: true,
      	    displayType: "analog",
      	    analogSize: "400px",
                  analogFace: "face-010"
      and then in my css/custom.css I have:
      .clock .nightclock {
          color: red;
      to no effect – the clock is still white.
      I tried bringing MagicMirror up inside Chrome and using dev tools to mess with the css, but nothing I could do there would seem to have an effect on the color either.
      Thanks for any help,
      –Jim–
      PeterPangP J 2 Replies Last reply Reply Quote 0
        jjd @jjd
        OK, I finally succeeded in changing the analog clock to red. It wasn’t pretty and I don’t know if there is a better way. But here’s what I did, for the record:
        1. In modules/default/clock/faces, I copied face-010.svg to face-013.svg to create a new face.
        2. I edited face-013.svg to modify the style to have a fill color:
          <style>.cls-1{fill:#f00;}</style>
        3. Added the following to my custom.css:
        /* for the date display */
        .nightclock .date.normal.medium {
            color: #f00;
        /* for the hour hand */
        .nightclock .clockHour {
            background: #f00;
        /* for the minute hand */
        .nightclock .clockMinute {
            background: #f00;
        1. Edit the config: section of the clock module in config.js.
        • Added secondsColor: “#f00” to the config: section of the clock module in config.js to change the color of the second hand
        • Change the analogFace config to the newly edited “face-013”.
        • PeterPangP Offline
          PeterPang @jjd
          @jjd
          Its seem to have write [ code name , such as #11111111 ] , not the color name as red .
            jjd @PeterPang
            @peterpang said in Can't change color of analog clock in default clock module:
            @jjd
            Thanks, but no luck. I tried #ff0000 and everything’s still white.
              jjd @jjd
                  color: #f00;
                  background: #f00;
                  background: #f00;
