    Error on fresh install
    3 Posts 2 Posters 826 Views 2 Watching
      cpramhofer
      Hi Folks,
      i have problems with installing MM. i tried (several times) a complete fresh install on a new SD with Raspberry Pi OS Lite 2021-03-04 and the install script:
      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
      when i try to run MM i get following ERROR
      pi@MMM:~/MagicMirror $ DISPLAY=:0 npm start
      > magicmirror@2.15.0 start /home/pi/MagicMirror
      > ./run-start.sh $1
      [19.04.2021 10:37.10.619] [LOG]   Starting MagicMirror: v2.15.0
      [19.04.2021 10:37.10.632] [LOG]   Loading config ...
      [19.04.2021 10:37.10.642] [LOG]   Loading module helpers ...
      [19.04.2021 10:37.10.646] [LOG]   No helper found for module: alert.
      [19.04.2021 10:37.10.894] [LOG]   Initializing new module helper ...
      [19.04.2021 10:37.10.896] [LOG]   Module helper loaded: updatenotification
      [19.04.2021 10:37.10.898] [LOG]   No helper found for module: clock.
      ./run-start.sh: Zeile 102:  7065 Getötet                node serveronly
      npm ERR! code ELIFECYCLE
      npm ERR! errno 137
      npm ERR! magicmirror@2.15.0 start: `./run-start.sh $1`
      npm ERR! Exit status 137
      npm ERR!
      npm ERR! Failed at the magicmirror@2.15.0 start script.
      npm ERR!     /home/pi/.npm/_logs/2021-04-19T08_37_11_344Z-debug.log
      the log shows the following:
      1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
      2 info using npm@6.14.12
      3 info using node@v10.24.1
      5 info lifecycle magicmirror@2.15.0~prestart: magicmirror@2.15.0
      6 info lifecycle magicmirror@2.15.0~start: magicmirror@2.15.0
      7 verbose lifecycle magicmirror@2.15.0~start: unsafe-perm in lifecycle true
      8 verbose lifecycle magicmirror@2.15.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/$
      9 verbose lifecycle magicmirror@2.15.0~start: CWD: /home/pi/MagicMirror
      10 silly lifecycle magicmirror@2.15.0~start: Args: [ '-c', './run-start.sh $1' ]
      11 silly lifecycle magicmirror@2.15.0~start: Returned: code: 137  signal: null
      12 info lifecycle magicmirror@2.15.0~start: Failed to exec start script
      13 verbose stack Error: magicmirror@2.15.0 start: `./run-start.sh $1`
      13 verbose stack Exit status 137
      13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
      13 verbose stack     at EventEmitter.emit (events.js:198:13)
      13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
      13 verbose stack     at ChildProcess.emit (events.js:198:13)
      13 verbose stack     at maybeClose (internal/child_process.js:982:16)
      13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
      14 verbose pkgid magicmirror@2.15.0
      15 verbose cwd /home/pi/MagicMirror
      16 verbose Linux 5.10.17-v7+
      17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
      18 verbose node v10.24.1
      19 verbose npm  v6.14.12
      20 error code ELIFECYCLE
      21 error errno 137
      22 error magicmirror@2.15.0 start: `./run-start.sh $1`
      22 error Exit status 137
      23 error Failed at the magicmirror@2.15.0 start script.
      23 error This is probably not a problem with npm. There is likely additional logging output above.
      24 verbose exit [ 137, true ]
        sdetweil @cpramhofer
        @cpramhofer cannot be os lite. u need the graphical desktop
        change to full, refladh the sd card
          cpramhofer
          hi @sdetweil,
          in deed that was the problem, thank you!
