    MMM-Carousel Hide Mousecursor
    5 Posts 2 Posters 1.1k Views 2 Watching
    • F Offline
      Foxy25
      it is possible to hide the Mousecursor when the MMM-Carousel is installed?
      i changed from MMM-Pages + Page Indicator to MMM-Carousel because its faster and works a little bit better for me. But after the change there is a littel hand as a mousecursor? I want to hide oder remove this. The courser is only displayed when i use the Pageinationbuttons or the Slidebuttons from the MMM-Carousel modul?
      Greetings Torsten
        arus @Foxy25
        @foxy25
        out of interest what device are you running MMM-Carousel on as I was just about to install MMM-Pages + Page Indicator until I read you comment.
        • F Offline
          Foxy25
          HI
          im running a Raspi 4B 8GB with Raspian Buster.
          Maybe there is an other Issue with the modul: sometimes the screensaver comes up and lock the screen with a password prompt?
          Greetings Torsten
            arus @Foxy25
            @foxy25
            Given your hardware I’d say you’re platform is sound.
            Questions:
            Have you removed the MMM-pages & MMM-page-indicator folders in the ~/MagicMirror/modules folder.
            Do you have a backup of the original config.js file (~/MagicMirror/config/config.js)
            Possible Test Solution:
            If you had a copy of the original config.js file and did a backup or rename of your current config.js file you could just add the MMM-Carousel settings into the original or a vanilla config.js file and ‘pm2 restart MagicMirror’ to see if you get the same result.
            As a way of testing its a quick way to test the module and/or MagicMirror.
            • F Offline
              Foxy25
              Hi @arus,
              no, i dont have the mmm-pages and page-indicator folder in /MagicMirror/modules removed.
              I only comment the modules it in the config.js out.
              ok, when i have a littel more time this weekend i test it out.
              Thank you for your hints.
              I get in touch here, wen im finish with the test.
              Greetings Torsten
