    MagicMirror restarts all the time
    11 Posts 2 Posters 1.5k Views 2 Watching
    • L Offline
      Laurids
      I have to admit, that I´m an absolute noob. I was able to run the MagicMirror on a raspi3 with different modules. Yesterday I installed some updates (MM and ioserver) and since then, I have the problem, that my MM stops after 78 seconds everytime after a restart. What did I do wrong?
      Thanks for your help,
      Laurids
        sdetweil @Laurids
        @laurids need to see the messages where u start mm. either npm start or pm2. if pm2, then the
        pm2 logs --lines=100
        will provide the info
        • L Offline
          Laurids @sdetweil
          @sdetweil thank you for your reply. I´m sorry for this stupid question, but how can i copy text out of a log-file, when I use ssh? My pm2.log has more than 10000 lines, which are important for you?
            sdetweil @Laurids
            @laurids something near the end that shows around the time of the failure
            • L Offline
              Laurids @sdetweil
              @sdetweil I hope that this is helping
              2021-05-08T17:37:34: PM2 log: PM2 successfully stopped
              2021-05-08T17:38:09: PM2 log: ===============================================================================
              2021-05-08T17:38:09: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
              2021-05-08T17:38:09: PM2 log: Time                 : Sat May 08 2021 17:38:09 GMT+0200 (GMT+02:00)
              2021-05-08T17:38:09: PM2 log: PM2 version          : 4.2.3
              2021-05-08T17:38:09: PM2 log: Node.js version      : 10.24.1
              2021-05-08T17:38:09: PM2 log: Current arch         : arm
              2021-05-08T17:38:09: PM2 log: PM2 home             : /home/pi/.pm2
              2021-05-08T17:38:09: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
              2021-05-08T17:38:09: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
              2021-05-08T17:38:09: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
              2021-05-08T17:38:09: PM2 log: Application log path : /home/pi/.pm2/logs
              2021-05-08T17:38:09: PM2 log: Worker Interval      : 30000
              2021-05-08T17:38:09: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
              2021-05-08T17:38:09: PM2 log: Concurrent actions   : 2
              2021-05-08T17:38:09: PM2 log: SIGTERM timeout      : 1600
              2021-05-08T17:38:10: PM2 log: App [mm:0] starting in -fork mode-
              2021-05-08T17:38:10: PM2 log: App [mm:0] online
              2021-05-08T18:09:01: PM2 log: Stopping app:mm id:0
              2021-05-08T18:09:03: PM2 log: pid=890 msg=failed to kill - retrying in 100ms
              2021-05-08T18:09:04: PM2 log: pid=890 msg=failed to kill - retrying in 100ms
              2021-05-08T18:09:05: PM2 log: pid=890 msg=failed to kill - retrying in 100ms
              2021-05-08T18:09:05: PM2 log: Process with pid 890 still alive after 1600ms, sending it SIGKILL now...
              2021-05-08T18:09:05: PM2 log: App [mm:0] exited with code [0] via signal [SIGKILL]
              2021-05-08T18:09:06: PM2 log: pid=890 msg=process killed
              2021-05-08T18:09:07: PM2 log: PM2 successfully stopped
              2021-05-08T18:09:43: PM2 error: TypeError [ERR_INVALID_ARG_TYPE]: The "data" argument must be of type string or an in    at Object.writeFileSync (fs.js:1460:5)
                  at module.exports.Daemon.innerStart (/usr/local/lib/node_modules/pm2/lib/Daemon.js:90:8)
                  at Domain.<anonymous> (/usr/local/lib/node_modules/pm2/lib/Daemon.js:62:10)
                  at Domain.run (domain.js:370:15)
                  at module.exports.Daemon.start (/usr/local/lib/node_modules/pm2/lib/Daemon.js:61:5)
                  at Object.<anonymous> (/usr/local/lib/node_modules/pm2/lib/Daemon.js:455:10)
                  at Module._compile (internal/modules/cjs/loader.js:1063:30)
                  at Object.Module._extensions..js (internal/modules/cjs/loader.js:1092:10)
                  at Module.load (internal/modules/cjs/loader.js:928:32)
                  at Function.Module._load (internal/modules/cjs/loader.js:769:14)
              2021-05-08T18:09:43: PM2 log: ===============================================================================
              2021-05-08T18:09:43: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
              2021-05-08T18:09:43: PM2 log: Time                 : Sat May 08 2021 18:09:43 GMT+0200 (Mitteleuropäische Sommerzeit)2021-05-08T18:09:43: PM2 log: PM2 version          : 4.2.3
              2021-05-08T18:09:43: PM2 log: Node.js version      : 14.16.1
              2021-05-08T18:09:43: PM2 log: Current arch         : arm
              2021-05-08T18:09:43: PM2 log: PM2 home             : /home/pi/.pm2
              2021-05-08T18:09:43: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
              2021-05-08T18:09:43: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
              2021-05-08T18:09:43: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
              2021-05-08T18:09:43: PM2 log: Application log path : /home/pi/.pm2/logs
                sdetweil @Laurids
                @laurids sadly no. pm2 splits output inyo two logs
                errors and output. this looks like the output.
                errors are printed first
                send the output to a file
                pm2 logs --lines=100 >somefile
                then edit somfile
                • L Offline
                  Laurids @sdetweil
                  @sdetweil here are some lines of the error.log. They repeat all the time:
                  [17:05:32.926] [ERROR]  error: cannot lock ref 'refs/tags/v2.12.0': unable to resolve reference 'refs/tags/v2.12.0':
                  Von https://github.com/MichMich/MagicMirror
                   ! [neues Tag]         v2.12.0    -> v2.12.0  (kann lokale Referenz nicht aktualisieren)
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 1
                  npm ERR! magicmirror@2.10.1 start: `./run-start.sh`
                  npm ERR! Exit status 1
                  npm ERR!.
                  npm ERR! Failed at the magicmirror@2.10.1 start script.
                  npm ERR!     /home/pi/.npm/_logs/2021-05-08T15_37_28_171Z-debug.log
                  /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                  [08.05.2021 17:39.18.396] [WARN]  The module 'currentweather' is deprecated in favor of the 'weather'-module, please
                  [08.05.2021 17:39.18.402] [WARN]  The module 'weatherforecast' is deprecated in favor of the 'weather'-module, please[08.05.2021 17:40.30.779] [ERROR] Whoops! There was an uncaught exception...
                  [08.05.2021 17:40.30.812] [ERROR] Error: connect ECONNREFUSED 192.168.178.1:1012
                      at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1141:16) {
                    errno: 'ECONNREFUSED',
                    code: 'ECONNREFUSED',
                    syscall: 'connect',
                    address: '192.168.178.1',
                    port: 1012
                  [08.05.2021 17:40.30.816] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened.
                  [08.05.2021 17:40.30.819] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://githu[08.05.2021 17:40.36.632] [ERROR] Failed to fetch git data for MMM-ioBroker: Error: block timeout reached
                  [08.05.2021 17:40.37.844] [ERROR] Failed to fetch git data for default: Error: block timeout reached
                  [08.05.2021 17:50.40.859] [ERROR] Failed to fetch git data for default: Error: block timeout reached
                  [08.05.2021 17:53.34.562] [ERROR] Got error: connect ECONNREFUSED 127.0.0.1:8087
                  [08.05.2021 17:53.34.564] [ERROR] Got error: connect ECONNREFUSED 127.0.0.1:8087
                  and
                  [09.05.2021 11:28.04.125] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened.
                  [09.05.2021 11:28.04.126] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://githu[09.05.2021 11:28.04.676] [ERROR] Got error: connect ECONNREFUSED 127.0.0.1:8087
                  [09.05.2021 11:28.04.679] [ERROR] Got error: connect ECONNREFUSED 127.0.0.1:8087
                  [09.05.2021 11:28.04.681] [ERROR] Got error: connect ECONNREFUSED 127.0.0.1:8087
                  [09.05.2021 11:28.04.683] [ERROR] Got error: connect ECONNREFUSED 127.0.0.1:8087
                  [09.05.2021 11:28.04.686] [ERROR] Got error: connect ECONNREFUSED 127.0.0.1:8087
                  [09.05.2021 11:28.04.691] [ERROR] Got error: connect ECONNREFUSED 127.0.0.1:8087
                  [09.05.2021 11:28.06.421] [ERROR] Failed to fetch git data for MMM-FRITZ-Box-Callmonitor: Error: block timeout reache[09.05.2021 11:29.04.732] [ERROR] Got error: connect ECONNREFUSED 127.0.0.1:8087
                  [09.05.2021 11:29.04.737] [ERROR] Got error: connect ECONNREFUSED 127.0.0.1:8087
                  [09.05.2021 11:29.04.740] [ERROR] Got error: connect ECONNREFUSED 127.0.0.1:8087
                  [09.05.2021 11:29.04.743] [ERROR] Got error: connect ECONNREFUSED 127.0.0.1:8087
                  [09.05.2021 11:29.04.746] [ERROR] Got error: connect ECONNREFUSED 127.0.0.1:8087
                  [09.05.2021 11:29.04.751] [ERROR] Got error: connect ECONNREFUSED 127.0.0.1:8087
                  [09.05.2021 11:29.30.532] [WARN]  The module 'currentweather' is deprecated in favor of the 'weather'-module, please
                  [09.05.2021 11:29.30.535] [WARN]  The module 'weatherforecast' is deprecated in favor of the 'weather'-module, please[09.05.2021 11:29.34.824] [ERROR] Whoops! There was an uncaught exception...
                  [09.05.2021 11:29.34.836] [ERROR] Error: connect ECONNREFUSED 192.168.178.1:1012
                    syscall: 'connect',
                    port: 1012
                    sdetweil @Laurids
                    @laurids said in MagicMirror restarts all the time:
                    errno: ‘ECONNREFUSED’,
                    code: ‘ECONNREFUSED’,
                    syscall: ‘connect’,
                    address: ‘192.168.178.1’,
                    and
                    look like the indicators…
                    whatever is using 192.168.178.1 looks like it didn’t handle the error
                    this 127.0.0.1:8087 is localhost, on the same machine, some server maybe related to above…
                    • L Offline
                      Laurids @sdetweil
                      @sdetweil thanks for your help. I have to admit, that I don´t have a clue how to fix the errors ;) I think I just give it another try with a new installation.
                        sdetweil @Laurids
                        @laurids I’m assuming it’s some module you’ve installed, so looking at the config.js may give a clue
