    MMM-Pages and MMM-Motioneye
    5 Posts 2 Posters 1.0k Views 2 Watching
    • O Offline
      OberfragGER
      im using MMM-Pages togehther with MMM-Motioneye.
      I fixed MMM-Motioneye in Pages so i have no “refresh” Its possible to disable MMM-Motioneye via http-request.
      I disable MMM-Motioneye butwith every flip, MMM-Motioneye is loaded again.
      I checked the developer settings, but no new loading of MMM-Motioneye in sight. Pretty strange.
      Does anyone have an idea? I just want to use both modules.
        sdetweil @OberfragGER
        @oberfragger i don’t understand your message
        it says u put it in the fixed section of pages
        and then u disabled that module (how it doesn’t say, then says u can use and http request)
        then iut says every cflip )of page) you get a new instance of motioneye?
        then says u looked at the developer site, and couldn’t find anything
        but then says evey flip you DON"T see loading…
        so, what are u trying to say
        every module in config.js that is not disabled, is loaded…
        pages plays a hide and seek game, only showing some when that ‘page’ is selected…
        the module is still there running, but not shown if not on this page…
        a few modules behave poorly… and it messes up pages (cause they can’t be hidden/shown on command as expected
        • O Offline
          OberfragGER @sdetweil
          @sdetweil Thanks for you fast reply. I think im using the wrong terms and now youre confused ab bit.
          First of all- i think i found a solution with MMM-Remote-Control so i can show/ hide modules like i want.
          Now i try to explain it a bit better.
          I use MMM-pages and configured MMM-MotionEye under the fixed section. Every time i have movement, i want to show the camera-stream with the http-command:
          http://mirror:8080/motioneye
          I always want to hide the stream, but not for 60 seconds when i have movement in my entrance. So the camera stream needs to be activated.
          With the MMM-pages module i have configured 2 different pages and auto-flipping every 60 seconds.
          The problem is: Every time i hide the stream with http://mirror:8080/motioneye/hide … with the flip to the next side, the stream is showing up again.
          I hope you understand me now in a better way. Now i have to figure out, how to show/hide the MMM-MotionEye via API in MMM-Remote-Control.
            @oberfragger when you surface the stream the ‘module’ has become visible (side effect), pages doesn’t know.
            you flip page, and the module is visible…(still)
            you have two show/hide controllers… the module and pages… who don’t know about each other
            seems motioneye made the video content hide, but not itself (the module)
            • O Offline
              @sdetweil Thanks for you explanation.
