    Poemoftheday module showing black screen
    7 Posts 3 Posters 1.4k Views 3 Watching
      sdetweil @e199504
      @e199504 said in Poemoftheday module showing black screen:
      is that a period?
      not in JavaScript. remove that
      • E Offline
        e199504 @sdetweil
        @sdetweil I removed the dot. This time I am getting the error that I need to check my config file.
        When I runnpm run config:check, I am getting the following error
        [13.05.2021 15:06.26.058] [INFO]  Checking file...  /home/pi/MagicMirror/config/config.js
        [13.05.2021 15:06.26.130] [ERROR] Your configuration file contains syntax errors :(
        [13.05.2021 15:06.26.133] [ERROR] Line 56 column 3: Parsing error: Unexpected token {
        This is a snippet of my config file
          sdetweil @e199504
          so, that means the line before it contains an error…
          USUALLY unexpected token means the line before is missing a trailing comma
               		module:"......",
               	}       /// this line, should say, MORE to FOLLOW   , <--- comma
               		module:"ppppp",
          • E Offline
            e199504 @sdetweil
            @sdetweil I copied again the array to add in the config file from the Poemoftheday
            here is the snippet of my config file
            			module: "alert",
                			module: "MMM-PoemOfTheDay",
                			position: "upper_third",
                  				textLimit: 1000,
                  				lineLimit: 10,
                  				detectLanguageApiKey: "{API_KEY}",
                  				languageSet: ["en", "es"],
                  				updateInterval: 120000
             			module: "MMM-Breathwork",
              			position: "bottom_right",
              sdetweil @e199504
              @e199504 that should be ok… did config:check find anything?
              also, did you do the npm install in the module folder after git clone?
              what do the messages say where u start MM?
              npm start or pm2
              if using pm2 then
              pm2 logs --lines=100
              should show them
              • O Offline
                Ortega65
                I am also having similar issue.
