    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 886.4k Views 59 Watching
      sdetweil @airart
      @airart mine works like this
      "start": "./node_modules/.bin/electron js/electron.js",
      A 1 Reply Last reply
      • A
        airart @sdetweil
        @sdetweil seems that in node_modules folder/.bin/ there’s not any electron.js
        i’v also tried with cmd …
          sdetweil @airart
          @airart did you do the npm install?
          • A
            airart @sdetweil
            @sdetweil yes i do
              sdetweil @airart
              @airart what version of node and npm are installed
              npm -v
              node -v
              • A
                airart @sdetweil
                @sdetweil npm 7.14.0 , node 14.17.0
                  sdetweil @airart
                  @airart interesting
                  ok, lets try to start over that step
                  cd MagicMirror
                  del package-lock.json
                  rd /q/s  node_modules
                  npm install  only=prod
                  we will want the name of the log file when it finishes in case
                  • A
                    airart @sdetweil
                    @sdetweil only the name ?
                    2021-05-28T12_56_04_242Z-debug
                    0 verbose cli [
                    0 verbose cli   'C:\\Program Files\\nodejs\\node.exe',
                    0 verbose cli   'C:\\Users\\gizmo\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js',
                    0 verbose cli   'install',
                    0 verbose cli   'only=prod'
                    0 verbose cli ]
                    1 info using npm@7.14.0
                    2 info using node@v14.17.0
                    3 timing npm:load:whichnode Completed in 8ms
                    4 timing config:load:defaults Completed in 9ms
                    5 timing config:load:file:C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\npmrc Completed in 8ms
                    6 timing config:load:builtin Completed in 9ms
                    7 timing config:load:cli Completed in 9ms
                    8 timing config:load:env Completed in 3ms
                    9 timing config:load:file:C:\Users\gizmo\MagicMirror\.npmrc Completed in 2ms
                    10 timing config:load:project Completed in 5ms
                    11 timing config:load:file:C:\Users\gizmo\.npmrc Completed in 1ms
                    12 timing config:load:user Completed in 1ms
                    13 timing config:load:file:C:\Users\gizmo\AppData\Roaming\npm\etc\npmrc Completed in 1ms
                    14 timing config:load:global Completed in 2ms
                    15 timing config:load:validate Completed in 1ms
                    16 timing config:load:credentials Completed in 10ms
                    17 timing config:load:setEnvs Completed in 12ms
                    18 timing config:load Completed in 61ms
                    19 timing npm:load:configload Completed in 61ms
                    20 timing npm:load:setTitle Completed in 3ms
                    21 timing npm:load:setupLog Completed in 11ms
                    22 timing npm:load:cleanupLog Completed in 13ms
                    23 timing npm:load:configScope Completed in 0ms
                    24 timing npm:load:projectScope Completed in 4ms
                    25 timing npm:load Completed in 104ms
                    26 timing config:load:flatten Completed in 20ms
                    27 timing arborist:ctor Completed in 3ms
                    28 timing arborist:ctor Completed in 1ms
                    29 timing idealTree:init Completed in 122ms
                    30 timing idealTree Completed in 150ms
                    31 timing command:install Completed in 234ms
                    32 verbose stack Error: Invalid tag name "only=prod": Tags may not have any characters that encodeURIComponent encodes.
                    32 verbose stack     at invalidTagName (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\npm-package-arg\npa.js:94:15)
                    32 verbose stack     at fromRegistry (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\npm-package-arg\npa.js:299:13)
                    32 verbose stack     at resolve (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\npm-package-arg\npa.js:84:12)
                    32 verbose stack     at npa (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\npm-package-arg\npa.js:55:10)
                    32 verbose stack     at C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\@npmcli\arborist\lib\arborist\build-ideal-tree.js:474:50
                    32 verbose stack     at Array.map (<anonymous>)
                    32 verbose stack     at Arborist.[add] (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\@npmcli\arborist\lib\arborist\build-ideal-tree.js:471:28)
                    32 verbose stack     at Arborist.[applyUserRequestsToNode] (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\@npmcli\arborist\lib\arborist\build-ideal-tree.js:446:23)
                    32 verbose stack     at Arborist.[applyUserRequests] (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\@npmcli\arborist\lib\arborist\build-ideal-tree.js:402:43)
                    32 verbose stack     at Arborist.buildIdealTree (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\@npmcli\arborist\lib\arborist\build-ideal-tree.js:217:37)
                    33 verbose cwd C:\Users\gizmo\MagicMirror
                    34 verbose Windows_NT 10.0.18362
                    35 verbose argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\gizmo\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js" "install" "only=prod"
                    36 verbose node v14.17.0
                    37 verbose npm  v7.14.0
                    38 error code EINVALIDTAGNAME
                    39 error Invalid tag name "only=prod": Tags may not have any characters that encodeURIComponent encodes.
                    40 verbose exit 1
                      sdetweil @airart
                      @airart sorry, typo
                      –only=prod
                      • A
                        airart @sdetweil
                        @sdetweil ok done , but no log is generated
                        npm start
                        same errors :-(
                          sdetweil @airart
                          @airart there is always a log
                          in the users home folder .npm/logs
                          I will recheck my windows env too
                          npm install --loglevel verbose
                          should write a file in the local folder
                          npm-debug.log
                          when I start my MM i get
                          C:\Users\sdetw\MagicMirror>npm start
                          > magicmirror@2.15.0 start C:\Users\sdetw\MagicMirror
                          [28.05.2021 09:25.27.486] [LOG]   Starting MagicMirror: v2.15.0
                          • A
                            airart @sdetweil
                            @sdetweil i try to find this .log but no one is generating … i search in all of my hdd …
                            when i type npm start
                            C:\Users\gizmo\MagicMirror>npm start
                            "node_modules" non è riconosciuto come comando interno o esterno,
                             un programma eseguibile o un file batch.
                            and there’s no electron js FOLDER in .bin FOLDER
                              sdetweil @airart
                              @airart do again
                              • A
                                airart @sdetweil
                                @sdetweil nope pal , nothing …
                                no log
                                no start
                                where is your log ?
                                  sdetweil @airart
                                  @airart man I hate this stuff changing all the time
                                  do this
                                  npm install --only=prod --loglevel verbose >somefile.txt 2>&1
                                  then the install info is in somefile.txt
                                  • A
                                    airart @sdetweil
                                    @sdetweil here !
                                    npm verb cli [
                                    npm verb cli   'C:\\Program Files\\nodejs\\node.exe',
                                    npm verb cli   'C:\\Users\\gizmo\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js',
                                    npm verb cli   'install',
                                    npm verb cli   '--only=prod',
                                    npm verb cli   '--loglevel',
                                    npm verb cli   'verbose'
                                    npm verb cli ]
                                    npm info using npm@7.14.0
                                    npm info using node@v14.17.0
                                    npm timing npm:load:whichnode Completed in 8ms
                                    npm timing config:load:defaults Completed in 10ms
                                    npm timing config:load:file:C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\npmrc Completed in 16ms
                                    npm timing config:load:builtin Completed in 16ms
                                    npm verb config only Use `--omit=dev` to omit dev dependencies from the install.
                                    npm timing config:load:cli Completed in 11ms
                                    npm timing config:load:env Completed in 2ms
                                    npm timing config:load:file:C:\Users\gizmo\MagicMirror\.npmrc Completed in 2ms
                                    npm timing config:load:project Completed in 5ms
                                    npm timing config:load:file:C:\Users\gizmo\.npmrc Completed in 1ms
                                    npm timing config:load:user Completed in 2ms
                                    npm timing config:load:file:C:\Users\gizmo\AppData\Roaming\npm\etc\npmrc Completed in 1ms
                                    npm timing config:load:global Completed in 1ms
                                    npm timing config:load:validate Completed in 2ms
                                    npm timing config:load:credentials Completed in 7ms
                                    npm timing config:load:setEnvs Completed in 5ms
                                    npm timing config:load Completed in 64ms
                                    npm timing npm:load:configload Completed in 65ms
                                    npm timing npm:load:setTitle Completed in 1ms
                                    npm timing npm:load:setupLog Completed in 5ms
                                    npm timing npm:load:cleanupLog Completed in 14ms
                                    npm timing npm:load:configScope Completed in 0ms
                                    npm timing npm:load:projectScope Completed in 5ms
                                    npm timing npm:load Completed in 127ms
                                    npm timing config:load:flatten Completed in 16ms
                                    npm timing arborist:ctor Completed in 4ms
                                    npm timing idealTree:init Completed in 2669ms
                                    npm timing idealTree:userRequests Completed in 1ms
                                    npm timing idealTree:#root Completed in 2ms
                                    npm timing idealTree:buildDeps Completed in 9ms
                                    npm timing idealTree:fixDepFlags Completed in 1ms
                                    npm timing idealTree Completed in 2750ms
                                    npm timing arborist:ctor Completed in 1ms
                                    npm timing reify:loadTrees Completed in 5000ms
                                    npm timing reify:diffTrees Completed in 162ms
                                    npm timing reify:retireShallow Completed in 1ms
                                    npm timing reify:createSparse Completed in 5ms
                                    npm timing reify:trashOmits Completed in 70ms
                                    npm timing reify:loadBundles Completed in 0ms
                                    npm timing reify:unpack Completed in 189ms
                                    npm timing reify:unretire Completed in 1ms
                                    npm timing build:queue Completed in 20ms
                                    npm timing build:deps Completed in 23ms
                                    npm timing build Completed in 23ms
                                    npm timing reify:build Completed in 25ms
                                    npm http fetch POST 200 https://registry.npmjs.org/-/npm/v1/security/advisories/bulk 7305ms
                                    npm timing auditReport:getReport Completed in 7342ms
                                    npm timing auditReport:init Completed in 0ms
                                    npm timing reify:audit Completed in 7347ms
                                    npm timing reify:trash Completed in 7867ms
                                    npm timing reify:save Completed in 1634ms
                                    npm timing reify Completed in 15363ms
                                    > magicmirror@2.15.0 install
                                    > " && cd vendor && npm install --loglevel=error
                                    > magicmirror@2.15.0 postinstall
                                    > npm run install-fonts && echo "MagicMirror installation finished successfully!
                                    npm info it worked if it ends with ok
                                    npm verb cli [
                                    npm verb cli   'C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js',
                                    npm verb cli   'prefix',
                                    npm verb cli   '-g'
                                    npm verb cli ]
                                    npm info using npm@6.14.13
                                    npm verb exit [ 0, true ]
                                    npm timing npm Completed in 377ms
                                    npm info ok
                                    npm verb cli [
                                    npm verb cli   'run',
                                    npm verb cli   'install-fonts'
                                    npm verb cli ]
                                    npm timing config:load:defaults Completed in 11ms
                                    npm timing config:load:file:C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\npmrc Completed in 15ms
                                    npm timing config:load:cli Completed in 8ms
                                    npm timing config:load:env Completed in 5ms
                                    npm timing config:load:file:C:\Users\gizmo\MagicMirror\.npmrc Completed in 1ms
                                    npm timing config:load:file:C:\Users\gizmo\.npmrc Completed in 0ms
                                    npm timing config:load:user Completed in 1ms
                                    npm timing config:load:validate Completed in 4ms
                                    npm timing config:load:credentials Completed in 5ms
                                    npm timing config:load:setEnvs Completed in 4ms
                                    npm timing config:load Completed in 60ms
                                    npm timing npm:load:configload Completed in 62ms
                                    npm timing npm:load Completed in 118ms
                                    > magicmirror@2.15.0 install-fonts
                                    > echo "Installing fonts ...
                                    > " && cd fonts && npm install --loglevel=error
                                    npm timing command:run-script Completed in 65ms
                                    npm verb exit 0
                                    npm timing npm Completed in 1407ms
                                    npm info ok
                                    up to date, audited 331 packages in 21s
                                    21 packages are looking for funding
                                      run `npm fund` for details
                                    found 0 vulnerabilities
                                    npm timing command:install Completed in 19769ms
                                    npm verb exit 0
                                    npm timing npm Completed in 21493ms
                                    npm info ok
                                      sdetweil @airart
                                      @airart well aint that useless… doesn;t say anything about electron
                                      lets try this
                                      cd MagicMirror
                                      npm install  electron@11.3.0  --loglevel=verbose
                                      • A
                                        airart @sdetweil
                                        @sdetweil is not working
                                        	"scripts": {
                                        		"start": "node_modules/.bin/electron js/electron.js",
                                        		"start:dev": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js dev",
                                        same errors
                                          sdetweil @airart
                                          @airart did u try to install electron?
                                          so we can see the error, if any
                                          A 2 Replies Last reply
                                          • A
                                            airart @sdetweil
                                            @sdetweil yes
                                            C:\Users\gizmo\MagicMirror>npm install  electron@11.3.0  --loglevel=verbose
                                            npm verb cli [
                                            npm verb cli   'electron@11.3.0',
                                            npm verb cli   '--loglevel=verbose'
                                            n................ecc
                                            • 10
                                            • 11
                                            • 12
                                            • 16
                                            • 17
                                            • 10 / 17
