    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 886.4k Views 59 Watching
      sdetweil @kithaam
      @kithaam u are on windows. don’t follow the linux instructions
      K 1 Reply Last reply
      • K
        kithaam @sdetweil
        @sdetweil hi on windows
          sdetweil @kithaam
          @kithaam yes. I know
          is a linux thing
          follow the windows instructions
          https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/141?page=15
          • K
            kithaam @sdetweil
            @sdetweil 62fe3601-ef5f-4d26-8b18-570f552dfeda-image.png Hi Please see this error
              sdetweil @kithaam
              @kithaam follow ALL the instructions…
              • K
                kithaam @sdetweil
                @sdetweil !hi im getting the same errors
                  sdetweil @kithaam
                  @kithaam it doesn’t say “npm start” in the vendor or font folders
                  • A
                    airart @sdetweil
                    @sdetweil not working after edit package.json , i try to start on Win CMD with npm start ( folder MagicMirror)
                      sdetweil @airart
                      @airart what does it say?
                      show the text of the start line now
                      A 1 Reply Last reply
                      • A
                        airart @sdetweil
                        @sdetweil i edit like this
                        "start": "node_modules/.bin/electron js/electron.js",
                        A S 2 Replies Last reply
                        • A
                          airart @airart
                          @airart it say
                          “node_modules” non è riconosciuto come come comando interno …
                            sdetweil @airart
                            @airart mine works like this
                            "start": "./node_modules/.bin/electron js/electron.js",
                            • A
                              airart @sdetweil
                              @sdetweil seems that in node_modules folder/.bin/ there’s not any electron.js
                              i’v also tried with cmd …
                                sdetweil @airart
                                @airart did you do the npm install?
                                • A
                                  airart @sdetweil
                                  @sdetweil yes i do
                                    sdetweil @airart
                                    @airart what version of node and npm are installed
                                    npm -v
                                    node -v
                                    • A
                                      airart @sdetweil
                                      @sdetweil npm 7.14.0 , node 14.17.0
                                        sdetweil @airart
                                        @airart interesting
                                        ok, lets try to start over that step
                                        cd MagicMirror
                                        del package-lock.json
                                        rd /q/s  node_modules
                                        npm install  only=prod
                                        we will want the name of the log file when it finishes in case
                                        • A
                                          airart @sdetweil
                                          @sdetweil only the name ?
                                          2021-05-28T12_56_04_242Z-debug
                                          0 verbose cli [
                                          0 verbose cli   'C:\\Program Files\\nodejs\\node.exe',
                                          0 verbose cli   'C:\\Users\\gizmo\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js',
                                          0 verbose cli   'install',
                                          0 verbose cli   'only=prod'
                                          0 verbose cli ]
                                          1 info using npm@7.14.0
                                          2 info using node@v14.17.0
                                          3 timing npm:load:whichnode Completed in 8ms
                                          4 timing config:load:defaults Completed in 9ms
                                          5 timing config:load:file:C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\npmrc Completed in 8ms
                                          6 timing config:load:builtin Completed in 9ms
                                          7 timing config:load:cli Completed in 9ms
                                          8 timing config:load:env Completed in 3ms
                                          9 timing config:load:file:C:\Users\gizmo\MagicMirror\.npmrc Completed in 2ms
                                          10 timing config:load:project Completed in 5ms
                                          11 timing config:load:file:C:\Users\gizmo\.npmrc Completed in 1ms
                                          12 timing config:load:user Completed in 1ms
                                          13 timing config:load:file:C:\Users\gizmo\AppData\Roaming\npm\etc\npmrc Completed in 1ms
                                          14 timing config:load:global Completed in 2ms
                                          15 timing config:load:validate Completed in 1ms
                                          16 timing config:load:credentials Completed in 10ms
                                          17 timing config:load:setEnvs Completed in 12ms
                                          18 timing config:load Completed in 61ms
                                          19 timing npm:load:configload Completed in 61ms
                                          20 timing npm:load:setTitle Completed in 3ms
                                          21 timing npm:load:setupLog Completed in 11ms
                                          22 timing npm:load:cleanupLog Completed in 13ms
                                          23 timing npm:load:configScope Completed in 0ms
                                          24 timing npm:load:projectScope Completed in 4ms
                                          25 timing npm:load Completed in 104ms
                                          26 timing config:load:flatten Completed in 20ms
                                          27 timing arborist:ctor Completed in 3ms
                                          28 timing arborist:ctor Completed in 1ms
                                          29 timing idealTree:init Completed in 122ms
                                          30 timing idealTree Completed in 150ms
                                          31 timing command:install Completed in 234ms
                                          32 verbose stack Error: Invalid tag name "only=prod": Tags may not have any characters that encodeURIComponent encodes.
                                          32 verbose stack     at invalidTagName (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\npm-package-arg\npa.js:94:15)
                                          32 verbose stack     at fromRegistry (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\npm-package-arg\npa.js:299:13)
                                          32 verbose stack     at resolve (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\npm-package-arg\npa.js:84:12)
                                          32 verbose stack     at npa (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\npm-package-arg\npa.js:55:10)
                                          32 verbose stack     at C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\@npmcli\arborist\lib\arborist\build-ideal-tree.js:474:50
                                          32 verbose stack     at Array.map (<anonymous>)
                                          32 verbose stack     at Arborist.[add] (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\@npmcli\arborist\lib\arborist\build-ideal-tree.js:471:28)
                                          32 verbose stack     at Arborist.[applyUserRequestsToNode] (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\@npmcli\arborist\lib\arborist\build-ideal-tree.js:446:23)
                                          32 verbose stack     at Arborist.[applyUserRequests] (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\@npmcli\arborist\lib\arborist\build-ideal-tree.js:402:43)
                                          32 verbose stack     at Arborist.buildIdealTree (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\@npmcli\arborist\lib\arborist\build-ideal-tree.js:217:37)
                                          33 verbose cwd C:\Users\gizmo\MagicMirror
                                          34 verbose Windows_NT 10.0.18362
                                          35 verbose argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\gizmo\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js" "install" "only=prod"
                                          36 verbose node v14.17.0
                                          37 verbose npm  v7.14.0
                                          38 error code EINVALIDTAGNAME
                                          39 error Invalid tag name "only=prod": Tags may not have any characters that encodeURIComponent encodes.
                                          40 verbose exit 1
                                            sdetweil @airart
                                            @airart sorry, typo
                                            –only=prod
                                            • 10
                                            • 11
                                            • 16
                                            • 17
                                            • 9 / 17
