    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 886.4k Views 59 Watching
    • K
      kithaam
      f6415e51-f1e8-4024-abe0-dfce398f0ded-image.png Please assist with this error
        sdetweil @kithaam
        @kithaam u are on windows. don’t follow the linux instructions
        K 1 Reply Last reply
        • K
          kithaam @sdetweil
          @sdetweil hi on windows
            sdetweil @kithaam
            @kithaam yes. I know
            is a linux thing
            follow the windows instructions
            https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/141?page=15
            • K
              kithaam @sdetweil
              @sdetweil 62fe3601-ef5f-4d26-8b18-570f552dfeda-image.png Hi Please see this error
                sdetweil @kithaam
                @kithaam follow ALL the instructions…
                • K
                  kithaam @sdetweil
                  @sdetweil !hi im getting the same errors
                    sdetweil @kithaam
                    @kithaam it doesn’t say “npm start” in the vendor or font folders
                    • A
                      airart @sdetweil
                      @sdetweil not working after edit package.json , i try to start on Win CMD with npm start ( folder MagicMirror)
                        sdetweil @airart
                        @airart what does it say?
                        show the text of the start line now
                        A 1 Reply Last reply
                        • A
                          airart @sdetweil
                          @sdetweil i edit like this
                          "start": "node_modules/.bin/electron js/electron.js",
                          A S 2 Replies Last reply
                          • A
                            airart @airart
                            @airart it say
                            “node_modules” non è riconosciuto come come comando interno …
                              sdetweil @airart
                              @airart mine works like this
                              "start": "./node_modules/.bin/electron js/electron.js",
                              • A
                                airart @sdetweil
                                @sdetweil seems that in node_modules folder/.bin/ there’s not any electron.js
                                i’v also tried with cmd …
                                  sdetweil @airart
                                  @airart did you do the npm install?
                                  • A
                                    airart @sdetweil
                                    @sdetweil yes i do
                                      sdetweil @airart
                                      @airart what version of node and npm are installed
                                      npm -v
                                      node -v
                                      • A
                                        airart @sdetweil
                                        @sdetweil npm 7.14.0 , node 14.17.0
                                          sdetweil @airart
                                          @airart interesting
                                          ok, lets try to start over that step
                                          cd MagicMirror
                                          del package-lock.json
                                          rd /q/s  node_modules
                                          npm install  only=prod
                                          we will want the name of the log file when it finishes in case
                                          • A
                                            airart @sdetweil
                                            @sdetweil only the name ?
                                            2021-05-28T12_56_04_242Z-debug
                                            0 verbose cli [
                                            0 verbose cli   'C:\\Program Files\\nodejs\\node.exe',
                                            0 verbose cli   'C:\\Users\\gizmo\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js',
                                            0 verbose cli   'install',
                                            0 verbose cli   'only=prod'
                                            0 verbose cli ]
                                            1 info using npm@7.14.0
                                            2 info using node@v14.17.0
                                            3 timing npm:load:whichnode Completed in 8ms
                                            4 timing config:load:defaults Completed in 9ms
                                            5 timing config:load:file:C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\npmrc Completed in 8ms
                                            6 timing config:load:builtin Completed in 9ms
                                            7 timing config:load:cli Completed in 9ms
                                            8 timing config:load:env Completed in 3ms
                                            9 timing config:load:file:C:\Users\gizmo\MagicMirror\.npmrc Completed in 2ms
                                            10 timing config:load:project Completed in 5ms
                                            11 timing config:load:file:C:\Users\gizmo\.npmrc Completed in 1ms
                                            12 timing config:load:user Completed in 1ms
                                            13 timing config:load:file:C:\Users\gizmo\AppData\Roaming\npm\etc\npmrc Completed in 1ms
                                            14 timing config:load:global Completed in 2ms
                                            15 timing config:load:validate Completed in 1ms
                                            16 timing config:load:credentials Completed in 10ms
                                            17 timing config:load:setEnvs Completed in 12ms
                                            18 timing config:load Completed in 61ms
                                            19 timing npm:load:configload Completed in 61ms
                                            20 timing npm:load:setTitle Completed in 3ms
                                            21 timing npm:load:setupLog Completed in 11ms
                                            22 timing npm:load:cleanupLog Completed in 13ms
                                            23 timing npm:load:configScope Completed in 0ms
                                            24 timing npm:load:projectScope Completed in 4ms
                                            25 timing npm:load Completed in 104ms
                                            26 timing config:load:flatten Completed in 20ms
                                            27 timing arborist:ctor Completed in 3ms
                                            28 timing arborist:ctor Completed in 1ms
                                            29 timing idealTree:init Completed in 122ms
                                            30 timing idealTree Completed in 150ms
                                            31 timing command:install Completed in 234ms
                                            32 verbose stack Error: Invalid tag name "only=prod": Tags may not have any characters that encodeURIComponent encodes.
                                            32 verbose stack     at invalidTagName (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\npm-package-arg\npa.js:94:15)
                                            32 verbose stack     at fromRegistry (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\npm-package-arg\npa.js:299:13)
                                            32 verbose stack     at resolve (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\npm-package-arg\npa.js:84:12)
                                            32 verbose stack     at npa (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\npm-package-arg\npa.js:55:10)
                                            32 verbose stack     at C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\@npmcli\arborist\lib\arborist\build-ideal-tree.js:474:50
                                            32 verbose stack     at Array.map (<anonymous>)
                                            32 verbose stack     at Arborist.[add] (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\@npmcli\arborist\lib\arborist\build-ideal-tree.js:471:28)
                                            32 verbose stack     at Arborist.[applyUserRequestsToNode] (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\@npmcli\arborist\lib\arborist\build-ideal-tree.js:446:23)
                                            32 verbose stack     at Arborist.[applyUserRequests] (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\@npmcli\arborist\lib\arborist\build-ideal-tree.js:402:43)
                                            32 verbose stack     at Arborist.buildIdealTree (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\@npmcli\arborist\lib\arborist\build-ideal-tree.js:217:37)
                                            33 verbose cwd C:\Users\gizmo\MagicMirror
                                            34 verbose Windows_NT 10.0.18362
                                            35 verbose argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\gizmo\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js" "install" "only=prod"
                                            36 verbose node v14.17.0
                                            37 verbose npm  v7.14.0
                                            38 error code EINVALIDTAGNAME
                                            39 error Invalid tag name "only=prod": Tags may not have any characters that encodeURIComponent encodes.
                                            40 verbose exit 1
                                            • 10
                                            • 11
                                            • 16
                                            • 17
                                            • 9 / 17
