    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 886.3k Views 59 Watching
      sdetweil @blake_northrup
      @blake_northrup because u installed on windows, there are a couple extra steps
      cd MagicMirror
      cd vendor
      npm install
      cd …\fonts. 2dots
      npm install
      cd … 2dot
      the npm start
      this phone editor will not let me enter 2 dots, displays as 3
      blake_northrupB 3 Replies Last reply
      Reply Quote 2
      • blake_northrupB
        blake_northrup @sdetweil
        @sdetweil Thank you sdetweil. I will try thins now, and let you know.
        • blake_northrupB
          @sdetweil Still getting black screen after performing these steps. For some reason, it is stating that I have the wrong syntax in the config file.
          $ npm run config:check
          magicmirror@2.12.0 config:check C:\Users\blake\MagicMirror
          node js/check_config.js
          [2020-07-08 07:59:36.797] [INFO] Checking file… C:\Users\blake\MagicMirror\config\config.js
          [2020-07-08 07:59:36.854] [LOG] Line 1 col 1 Definition for rule ‘prettier/prettier’ was not found.
          C:\Users\blake\MagicMirror\js\check_config.js:66
          throw new Error(“Wrong syntax in config file!”);
          Error: Wrong syntax in config file!
          at C:\Users\blake\MagicMirror\js\check_config.js:66:10
          at FSReqCallback.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:63:3)
          npm ERR! code ELIFECYCLE
          npm ERR! errno 1
          npm ERR! magicmirror@2.12.0 config:check: node js/check_config.js
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the magicmirror@2.12.0 config:check script.
          npm ERR! C:\Users\blake\AppData\Roaming\npm-cache_logs\2020-07-08T12_59_36_872Z-debug.log
          • blake_northrupB
            @sdetweil Nevermind. All is now working. Had an extra bit of info in my config file that didn’t need to be there. Thanks again for all of your help sdetweil!
            D 1 Reply Last reply
              dphotograph @blake_northrup
              @blake_northrup
              what was your “extra bit of info in my config file” ? i haf the same error and dont find an error with my config file on my new installed MagicMirror
              blake_northrupB 1 Reply Last reply
              • blake_northrupB
                blake_northrup @dphotograph
                @dphotograph Hey dphotograph, I had somehow copied the bottom part twice, and that was my problem. I just copied the config sample again, and built all of my modules, one by one.
                  djkj84
                  Hey guys,
                  Really new to this so i’m doing my best… But i am stuck… Any help with this please?
                  I’m on Windows 10 Pro.
                  Thanks in advance.
                  npm start
                  magicmirror@2.12.0 start C:\Users\Smart Mirror\MagicMirror
                  ‘DISPLAY’ is not recognized as an internal or external command,
                  operable program or batch file.
                  npm ERR! errno 1
                  npm ERR! magicmirror@2.12.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                  npm ERR!
                  npm ERR! Failed at the magicmirror@2.12.0 start script.
                  npm ERR! C:\Users\Smart Mirror\AppData\Roaming\npm-cache_logs\2020-08-19T10_14_26_713Z-debug.log
                  earnestrichardsE 1 Reply Last reply
                  • earnestrichardsE
                    earnestrichards @djkj84
                    @djkj84 I had this same problem on Win7.
                    I searched the forum and found this post by @sdetweil…
                    fix
                    • U
                      Uwe Kretsen @Mykle1
                      @Mykle1 said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                      Had enough? Lets run that MagicMirror, NOW!
                      Hallo there,
                      if you will find some free time to help :
                      I tried a few times to process the whole procedure of starting new MM software on PC - I am not even a newbie so it is really hard to say what I am doing wrong.
                      see pic - does it say to you anything? 18f689c8-c4ec-4f15-9558-c554ee194971-image.png
                      it seems I will have to give up - programming is not for all ;-)
                      BR
                        sdetweil @Uwe Kretsen
                        @Uwe-Kretsen do not install under mingw, just open a command prompt/ powershell prompt and do the git clone/npm install
                        u need git of course and node/npm (google how to install)
                        then u need to do some more steps as the setup is for linux
                        cd MagicMirror
                        cd vendor
                        npm install
                        cd ..
                        cd fonts
                        npm install
                        cd ..
                        then edit package.json and change the start line
                        from
                        to
                        		"start": "node_modules/.bin/electron js/electron.js",
                        then npm start works as expected
                        also, you must manually copy the MagicMirror/config/config.js.sample to the initial config.js
                        also create the empty MagicMirror/css/custom.css
                        U B A M 4 Replies Last reply
                        Reply Quote 2
                        • U
                          Uwe Kretsen @sdetweil
                          @sdetweil Dear Sam, thank you for the help - it start to work. I am really grateful fro support.
                          Now I will spend some days or weeks :-) to find out how to add /remove extra modules. hope to do my MagicMirror project to the end.
                          once again thank you
                          and stay healthy
                          BR Uwe
                            @Uwe-Kretsen see the links in my signature , they will help you
                              bhumin
                              git clone https://github.com/MichMich/MagicMirror.git
                              following error arrives when start
                              magicmirror@2.13.0 start C:\Users\bhumi\MagicMirror
                              npm ERR! errno 1
                              npm ERR! magicmirror@2.13.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                              npm ERR!
                              npm ERR! Failed at the magicmirror@2.13.0 start script.
                              npm ERR! C:\Users\bhumi\AppData\Roaming\npm-cache_logs\2020-12-16T05_04_47_316Z-debug.log
                                bhumin @sdetweil
                                @sdetweil thanks man
                                • H
                                  Humez
                                  Thank you for your tutorial! I’m a absolute beginner. I followed the steps above but when I try to start magicmirror I get the below message:
                                  magicmirror@2.14.0 start C:\Users\1234\magicmirror
                                  npm ERR! errno 1
                                  npm ERR! magicmirror@2.14.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                                  npm ERR!
                                  npm ERR! Failed at the magicmirror@2.14.0 start script.
                                    sdetweil @Humez
                                    @humez read and follow the steps here
                                    https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/141?_=1612997713585
                                    u have not edited package.json as required
                                    • K
                                      kithaam
                                      Hi Please help install Magic Mirror on my PC please assist with below
                                      http://localhost:8080 is just a black screen No date and Time on
                                        sdetweil @kithaam
                                        @kithaam yes, some missing steps.
                                        do
                                        cd MagicMirror
                                        cd vendor
                                        npm install
                                        cd ..
                                        cd fonts
                                        npm install
                                        cd ..
                                        restart mm
                                        K G 3 Replies Last reply
                                        • K
                                          kithaam @sdetweil
                                          @sdetweil Thank you its working
                                          • K
                                            kithaam @sdetweil
                                            @sdetweil Hi where do i go and change the Time and date? im new to this
                                            • 10
                                            • 16
                                            • 17
                                            • 8 / 17
