    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 891.6k Views 59 Watching
      sdetweil @Uwe Kretsen
      @Uwe-Kretsen do not install under mingw, just open a command prompt/ powershell prompt and do the git clone/npm install
      u need git of course and node/npm (google how to install)
      then u need to do some more steps as the setup is for linux
      cd MagicMirror
      cd vendor
      npm install
      cd ..
      cd fonts
      npm install
      cd ..
      then edit package.json and change the start line
      from
      to
      		"start": "node_modules/.bin/electron js/electron.js",
      then npm start works as expected
      also, you must manually copy the MagicMirror/config/config.js.sample to the initial config.js
      also create the empty MagicMirror/css/custom.css
      U B A M 4 Replies Last reply
      Reply Quote 2
      • U
        Uwe Kretsen @sdetweil
        @sdetweil Dear Sam, thank you for the help - it start to work. I am really grateful fro support.
        Now I will spend some days or weeks :-) to find out how to add /remove extra modules. hope to do my MagicMirror project to the end.
        once again thank you
        and stay healthy
        BR Uwe
          @Uwe-Kretsen see the links in my signature , they will help you
            bhumin
            @Mykle1 said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
            git clone https://github.com/MichMich/MagicMirror.git
            following error arrives when start
            magicmirror@2.13.0 start C:\Users\bhumi\MagicMirror
            ‘DISPLAY’ is not recognized as an internal or external command,
            operable program or batch file.
            npm ERR! code ELIFECYCLE
            npm ERR! errno 1
            npm ERR! magicmirror@2.13.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the magicmirror@2.13.0 start script.
            npm ERR! C:\Users\bhumi\AppData\Roaming\npm-cache_logs\2020-12-16T05_04_47_316Z-debug.log
              bhumin @sdetweil
              @sdetweil thanks man
              • H
                Humez
                Thank you for your tutorial! I’m a absolute beginner. I followed the steps above but when I try to start magicmirror I get the below message:
                magicmirror@2.14.0 start C:\Users\1234\magicmirror
                npm ERR! errno 1
                npm ERR! magicmirror@2.14.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                npm ERR!
                npm ERR! Failed at the magicmirror@2.14.0 start script.
                  sdetweil @Humez
                  @humez read and follow the steps here
                  https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/141?_=1612997713585
                  u have not edited package.json as required
                  • K
                    kithaam
                    Hi Please help install Magic Mirror on my PC please assist with below
                    http://localhost:8080 is just a black screen No date and Time on
                      sdetweil @kithaam
                      @kithaam yes, some missing steps.
                      do
                      cd MagicMirror
                      cd vendor
                      npm install
                      cd ..
                      cd fonts
                      npm install
                      cd ..
                      restart mm
                      K G 3 Replies Last reply
                      • K
                        kithaam @sdetweil
                        @sdetweil Thank you its working
                        • K
                          kithaam @sdetweil
                          @sdetweil Hi where do i go and change the Time and date? im new to this
                          • G
                            goEasy @sdetweil
                            @sdetweil hello, i have done as you mentioned, but i have this trouble. please Help
                            cd MagicMirror
                            cd vendor
                            npm install
                            1 package is looking for funding
                              run `npm fund` for details
                            found 0 vulnerabilities
                            $ npm fund
                            magicmirror-vendors
                            `-- https://github.com/sponsors/jonschlinkert
                              `-- picomatch@2.2.2
                              sdetweil @goEasy
                              @goeasy no trouble… warnings… ignore
                              G 1 Reply Last reply
                              • G
                                goEasy @sdetweil
                                @sdetweil you are a legend… btw all i had to do was
                                exit
                                then start mm again :grinning_face_with_sweat:
                                • G
                                  goEasy @Mykle1
                                  @mykle1 Please Help, i am running into this ERROR…
                                  Cowplain@DESKTOP-4IAPDRU MINGW64 ~
                                  $ cd magicmirror
                                  Cowplain@DESKTOP-4IAPDRU MINGW64 ~/magicmirror (master)
                                  $ npm start
                                  '.' is not recognized as an internal or external command,
                                    sdetweil @goEasy
                                    @goeasy do NOT install under MINGW64, just straight under windows
                                    • G
                                      goEasy @sdetweil
                                      @sdetweil Hey, thank you for the reply…
                                      i am new to this MM and coding, at one point everything was working then i cant remember what happened.
                                      i think is something to do with the Electron settings…
                                      Opening with CMD
                                      C:\Users\Cowplain\MagicMirror>npm start
                                      Opening with Git Bash
                                      $ npm start
                                      Please help
                                        sdetweil @goEasy
                                        @goeasy on windows, its support to say
                                        take off the ./
                                        windows doesn’t use that
                                        • G
                                          goEasy @sdetweil
                                          @sdetweil how would i remove
                                          ? i looked in the MM folder and such thing doesn’t exist
                                            sdetweil @goEasy
                                            @goeasy edit package.json and change the start line
                                            • 10
                                            • 16
                                            • 17
                                            • 8 / 17
