    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 886.3k Views 59 Watching
    • blake_northrupB
      blake_northrup
      I guess I spoke too soon. npm starts, but I have a blank screen. Haven’t done anything to the config.js file, except make a copy of the config.js.sample, and removed the .sample. See output:
      $ npm run config:check
      magicmirror@2.12.0 config:check C:\Users\blake\MagicMirror
      node js/check_config.js
      [2020-07-07 13:50:13.582] [INFO] Checking file… C:\Users\blake\MagicMirror\config\config.js
      [2020-07-07 13:50:13.630] [LOG] Line 1 col 1 Definition for rule ‘prettier/prettier’ was not found.
      C:\Users\blake\MagicMirror\js\check_config.js:66
      throw new Error(“Wrong syntax in config file!”);
      Error: Wrong syntax in config file!
      at C:\Users\blake\MagicMirror\js\check_config.js:66:10
      at FSReqCallback.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:63:3)
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.12.0 config:check: node js/check_config.js
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.12.0 config:check script.
      npm ERR! C:\Users\blake\AppData\Roaming\npm-cache_logs\2020-07-07T18_50_13_660Z-debug.log
        sdetweil @blake_northrup
        @blake_northrup not run-start
        “start”:“node_modules/.bin/electron js/electron.js”,
          @blake_northrup because u installed on windows, there are a couple extra steps
          cd MagicMirror
          cd vendor
          npm install
          cd …\fonts. 2dots
          npm install
          cd … 2dot
          the npm start
          this phone editor will not let me enter 2 dots, displays as 3
          blake_northrupB 3 Replies Last reply
          Reply Quote 2
          • blake_northrupB
            blake_northrup @sdetweil
            @sdetweil Thank you sdetweil. I will try thins now, and let you know.
            • blake_northrupB
              @sdetweil Still getting black screen after performing these steps. For some reason, it is stating that I have the wrong syntax in the config file.
              [2020-07-08 07:59:36.797] [INFO] Checking file… C:\Users\blake\MagicMirror\config\config.js
              [2020-07-08 07:59:36.854] [LOG] Line 1 col 1 Definition for rule ‘prettier/prettier’ was not found.
              npm ERR! errno 1
              npm ERR!
              npm ERR! C:\Users\blake\AppData\Roaming\npm-cache_logs\2020-07-08T12_59_36_872Z-debug.log
              • blake_northrupB
                @sdetweil Nevermind. All is now working. Had an extra bit of info in my config file that didn’t need to be there. Thanks again for all of your help sdetweil!
                D 1 Reply Last reply
                  dphotograph @blake_northrup
                  @blake_northrup
                  what was your “extra bit of info in my config file” ? i haf the same error and dont find an error with my config file on my new installed MagicMirror
                  blake_northrupB 1 Reply Last reply
                  • blake_northrupB
                    blake_northrup @dphotograph
                    @dphotograph Hey dphotograph, I had somehow copied the bottom part twice, and that was my problem. I just copied the config sample again, and built all of my modules, one by one.
                      djkj84
                      Hey guys,
                      Really new to this so i’m doing my best… But i am stuck… Any help with this please?
                      I’m on Windows 10 Pro.
                      Thanks in advance.
                      npm start
                      magicmirror@2.12.0 start C:\Users\Smart Mirror\MagicMirror
                      ‘DISPLAY’ is not recognized as an internal or external command,
                      operable program or batch file.
                      npm ERR! errno 1
                      npm ERR! magicmirror@2.12.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                      npm ERR!
                      npm ERR! Failed at the magicmirror@2.12.0 start script.
                      npm ERR! C:\Users\Smart Mirror\AppData\Roaming\npm-cache_logs\2020-08-19T10_14_26_713Z-debug.log
                      earnestrichardsE 1 Reply Last reply
                      • earnestrichardsE
                        earnestrichards @djkj84
                        @djkj84 I had this same problem on Win7.
                        I searched the forum and found this post by @sdetweil…
                        fix
                        • U
                          Uwe Kretsen @Mykle1
                          @Mykle1 said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                          Had enough? Lets run that MagicMirror, NOW!
                          Hallo there,
                          if you will find some free time to help :
                          I tried a few times to process the whole procedure of starting new MM software on PC - I am not even a newbie so it is really hard to say what I am doing wrong.
                          see pic - does it say to you anything? 18f689c8-c4ec-4f15-9558-c554ee194971-image.png
                          it seems I will have to give up - programming is not for all ;-)
                          BR
                            sdetweil @Uwe Kretsen
                            @Uwe-Kretsen do not install under mingw, just open a command prompt/ powershell prompt and do the git clone/npm install
                            u need git of course and node/npm (google how to install)
                            then u need to do some more steps as the setup is for linux
                            cd MagicMirror
                            cd vendor
                            npm install
                            cd ..
                            cd fonts
                            npm install
                            cd ..
                            then edit package.json and change the start line
                            from
                            to
                            		"start": "node_modules/.bin/electron js/electron.js",
                            then npm start works as expected
                            also, you must manually copy the MagicMirror/config/config.js.sample to the initial config.js
                            also create the empty MagicMirror/css/custom.css
                            U B A M 4 Replies Last reply
                            Reply Quote 2
                            • U
                              Uwe Kretsen @sdetweil
                              @sdetweil Dear Sam, thank you for the help - it start to work. I am really grateful fro support.
                              Now I will spend some days or weeks :-) to find out how to add /remove extra modules. hope to do my MagicMirror project to the end.
                              once again thank you
                              and stay healthy
                              BR Uwe
                                @Uwe-Kretsen see the links in my signature , they will help you
                                  bhumin
                                  git clone https://github.com/MichMich/MagicMirror.git
                                  following error arrives when start
                                  magicmirror@2.13.0 start C:\Users\bhumi\MagicMirror
                                  npm ERR! errno 1
                                  npm ERR! magicmirror@2.13.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                                  npm ERR!
                                  npm ERR! Failed at the magicmirror@2.13.0 start script.
                                  npm ERR! C:\Users\bhumi\AppData\Roaming\npm-cache_logs\2020-12-16T05_04_47_316Z-debug.log
                                    bhumin @sdetweil
                                    @sdetweil thanks man
                                    • H
                                      Humez
                                      Thank you for your tutorial! I’m a absolute beginner. I followed the steps above but when I try to start magicmirror I get the below message:
                                      magicmirror@2.14.0 start C:\Users\1234\magicmirror
                                      npm ERR! errno 1
                                      npm ERR! magicmirror@2.14.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                                      npm ERR!
                                      npm ERR! Failed at the magicmirror@2.14.0 start script.
                                        sdetweil @Humez
                                        @humez read and follow the steps here
                                        https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/141?_=1612997713585
                                        u have not edited package.json as required
                                        • K
                                          kithaam
                                          Hi Please help install Magic Mirror on my PC please assist with below
                                          http://localhost:8080 is just a black screen No date and Time on
                                            sdetweil @kithaam
                                            @kithaam yes, some missing steps.
                                            do
                                            cd MagicMirror
                                            cd vendor
                                            npm install
                                            cd ..
                                            cd fonts
                                            npm install
                                            cd ..
                                            restart mm
                                            K G 3 Replies Last reply
                                            • 16
                                            • 17
                                            • 7 / 17
