    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 886.3k Views 59 Watching
      sdetweil @dwburger
      @dwburger said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
      I want to manage it from my desktop in my office using Git Bash ssh connection.
      also, don’t know what this means… manage… it doesn’t NEED to run MM at all… just display it.
      u could have two instances running on the base machine… 2 different ports…
      the tablet accesses port(8081) , the base another (8080)
      run the tablet instance as serveronly then no ui memory consumption on the base for that instance
      to make a second copy from the first, just copy the MM folder to MM1, and change the config for port (and address/whitelist above)
      then do npm serveronly for the tablet mm
        Plainbroke 0
        All,
        You can not copy and paste though. I had to manually type it all in to make it work.
        Still in MagicMirror;
        nano package.json
        right under the other “start”: “???”
        go to the line below it and hit enter.
        Then type in the blank space you just made.
        “start”: “node_modules/.bin/electron js/electron.js”,
        //DO NOT LEAVE OUT THE PUNCTUATION. ESPECIALLY THE COMMA AT THE END.
        //I speak from expereince on this matter.
        //Mykle1 usually has to help me find it after struggling for a couple hours.
        THEN:
        cd ~/MagicMirror/vendor
        npm install
        cd fonts
        npm install
        NOW IT will RUN
        Thank you agian Mykle1
        I am really enjoying this on my laptop,
        so much easier to do testing ect.
          sdetweil @Plainbroke 0
          @Plainbroke-0 it was Sam, but anyway I cut and paste ALL the time. you need to add the code block marks around the actual steps to make them readable
          • blake_northrupB
            blake_northrup @OldShaterhan
            @OldShaterhan
            I just made the change, and this is what I get when trying npm start:
            $ npm start
            magicmirror@2.12.0 start C:\Users\blake\MagicMirror
            run-start.sh
            ‘run-start.sh’ is not recognized as an internal or external command,
            operable program or batch file.
            npm ERR! code ELIFECYCLE
            npm ERR! errno 1
            npm ERR! magicmirror@2.12.0 start: run-start.sh
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the magicmirror@2.12.0 start script.
            npm ERR! C:\Users\blake\AppData\Roaming\npm-cache_logs\2020-07-07T18_11_04_725Z-debug.log
            • blake_northrupB
              blake_northrup @dwburger
              Thank you dwburger! This fixed my issue!
              • blake_northrupB
                blake_northrup
                I guess I spoke too soon. npm starts, but I have a blank screen. Haven’t done anything to the config.js file, except make a copy of the config.js.sample, and removed the .sample. See output:
                $ npm run config:check
                magicmirror@2.12.0 config:check C:\Users\blake\MagicMirror
                node js/check_config.js
                [2020-07-07 13:50:13.582] [INFO] Checking file… C:\Users\blake\MagicMirror\config\config.js
                [2020-07-07 13:50:13.630] [LOG] Line 1 col 1 Definition for rule ‘prettier/prettier’ was not found.
                C:\Users\blake\MagicMirror\js\check_config.js:66
                throw new Error(“Wrong syntax in config file!”);
                Error: Wrong syntax in config file!
                at C:\Users\blake\MagicMirror\js\check_config.js:66:10
                at FSReqCallback.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:63:3)
                npm ERR! errno 1
                npm ERR! magicmirror@2.12.0 config:check: node js/check_config.js
                npm ERR!
                npm ERR! Failed at the magicmirror@2.12.0 config:check script.
                npm ERR! C:\Users\blake\AppData\Roaming\npm-cache_logs\2020-07-07T18_50_13_660Z-debug.log
                  sdetweil @blake_northrup
                  @blake_northrup not run-start
                  “start”:“node_modules/.bin/electron js/electron.js”,
                    @blake_northrup because u installed on windows, there are a couple extra steps
                    cd MagicMirror
                    cd vendor
                    npm install
                    cd …\fonts. 2dots
                    npm install
                    cd … 2dot
                    the npm start
                    this phone editor will not let me enter 2 dots, displays as 3
                    blake_northrupB 3 Replies Last reply
                    Reply Quote 2
                    • blake_northrupB
                      blake_northrup @sdetweil
                      @sdetweil Thank you sdetweil. I will try thins now, and let you know.
                      • blake_northrupB
                        @sdetweil Still getting black screen after performing these steps. For some reason, it is stating that I have the wrong syntax in the config file.
                        [2020-07-08 07:59:36.797] [INFO] Checking file… C:\Users\blake\MagicMirror\config\config.js
                        [2020-07-08 07:59:36.854] [LOG] Line 1 col 1 Definition for rule ‘prettier/prettier’ was not found.
                        npm ERR! errno 1
                        npm ERR!
                        npm ERR! C:\Users\blake\AppData\Roaming\npm-cache_logs\2020-07-08T12_59_36_872Z-debug.log
                        • blake_northrupB
                          @sdetweil Nevermind. All is now working. Had an extra bit of info in my config file that didn’t need to be there. Thanks again for all of your help sdetweil!
                          D 1 Reply Last reply
                            dphotograph @blake_northrup
                            @blake_northrup
                            what was your “extra bit of info in my config file” ? i haf the same error and dont find an error with my config file on my new installed MagicMirror
                            blake_northrupB 1 Reply Last reply
                            • blake_northrupB
                              blake_northrup @dphotograph
                              @dphotograph Hey dphotograph, I had somehow copied the bottom part twice, and that was my problem. I just copied the config sample again, and built all of my modules, one by one.
                                djkj84
                                Hey guys,
                                Really new to this so i’m doing my best… But i am stuck… Any help with this please?
                                I’m on Windows 10 Pro.
                                Thanks in advance.
                                npm start
                                magicmirror@2.12.0 start C:\Users\Smart Mirror\MagicMirror
                                ‘DISPLAY’ is not recognized as an internal or external command,
                                npm ERR! errno 1
                                npm ERR! magicmirror@2.12.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                                npm ERR!
                                npm ERR! C:\Users\Smart Mirror\AppData\Roaming\npm-cache_logs\2020-08-19T10_14_26_713Z-debug.log
                                earnestrichardsE 1 Reply Last reply
                                • earnestrichardsE
                                  earnestrichards @djkj84
                                  @djkj84 I had this same problem on Win7.
                                  I searched the forum and found this post by @sdetweil…
                                  fix
                                  • U
                                    Uwe Kretsen @Mykle1
                                    @Mykle1 said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                                    Had enough? Lets run that MagicMirror, NOW!
                                    Hallo there,
                                    if you will find some free time to help :
                                    I tried a few times to process the whole procedure of starting new MM software on PC - I am not even a newbie so it is really hard to say what I am doing wrong.
                                    see pic - does it say to you anything? 18f689c8-c4ec-4f15-9558-c554ee194971-image.png
                                    it seems I will have to give up - programming is not for all ;-)
                                    BR
                                      sdetweil @Uwe Kretsen
                                      @Uwe-Kretsen do not install under mingw, just open a command prompt/ powershell prompt and do the git clone/npm install
                                      u need git of course and node/npm (google how to install)
                                      then u need to do some more steps as the setup is for linux
                                      cd MagicMirror
                                      cd vendor
                                      npm install
                                      cd ..
                                      cd fonts
                                      npm install
                                      cd ..
                                      then edit package.json and change the start line
                                      from
                                      to
                                      		"start": "node_modules/.bin/electron js/electron.js",
                                      then npm start works as expected
                                      also, you must manually copy the MagicMirror/config/config.js.sample to the initial config.js
                                      also create the empty MagicMirror/css/custom.css
                                      U B A M 4 Replies Last reply
                                      Reply Quote 2
                                      • U
                                        Uwe Kretsen @sdetweil
                                        @sdetweil Dear Sam, thank you for the help - it start to work. I am really grateful fro support.
                                        Now I will spend some days or weeks :-) to find out how to add /remove extra modules. hope to do my MagicMirror project to the end.
                                        once again thank you
                                        and stay healthy
                                        BR Uwe
                                          @Uwe-Kretsen see the links in my signature , they will help you
                                            bhumin
                                            git clone https://github.com/MichMich/MagicMirror.git
                                            following error arrives when start
                                            magicmirror@2.13.0 start C:\Users\bhumi\MagicMirror
                                            npm ERR! errno 1
                                            npm ERR! magicmirror@2.13.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                                            npm ERR!
                                            npm ERR! Failed at the magicmirror@2.13.0 start script.
                                            npm ERR! C:\Users\bhumi\AppData\Roaming\npm-cache_logs\2020-12-16T05_04_47_316Z-debug.log
                                            • 16
                                            • 17
                                            • 7 / 17
