    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 887.4k Views 59 Watching
      sdetweil @dstoianovici
      @dstoianovici yes,if some other app is using 8080 then u have to change it… mine is on 8086. 8080-8085 are in use
        CliffordW
        It should probably be easy, but I can’t seem to find it. What is the command I can use to start MM on Windows 10 startup?
          CliffordW
          Thanks for a great guide, got me up and running quickly. Can you guide me where do I insert the commands to rotate the display to portrait mode?
            bdream
            @Mykle1 Many thanks for this description!
            Just got it run under Windows 7. That will help to play and learn how to get own modules :nerd_face:
            Two questions I have.
            My MM is version 2.6.0. I planned to run updatescript from @sdetweil but failed. Yahe you any idea?
            Is there an option to run MM in a window being able to shrink and move over the desktop?
            cheers, bdream
            S Mykle1M 3 Replies Last reply
              sdetweil @bdream
              @bdream come talk in the Updated Installer topic
              https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
                sdetweil @bdream
                @bdream F11 will take a window from full screen to not
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @bdream
                  @bdream said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                  Your F11 key should toggle between full screen MM and MM in a window
                  • Mykle1M
                    Damn Sam, you’re just too fast!
                      bdream
                      F11 seems to be a got hint, even it comes from @Mykle1 or @sdetweil.
                      Will try it this evening - thanks!
                      cheers, bdream
                      • O
                        OldShaterhan
                        For me setup running MagicMirror on Windows 10 worked by:
                        • cloning the repository
                        • then edit package.json by changing following line:
                          "scripts": {
                            "start": "./run-start.sh",
                        to:
                          "scripts": {
                            "start": "bash ./run-start.sh",
                        Simple change, works in every location on my PC.
                        blake_northrupB 1 Reply Last reply
                          jagdambasoft
                          $ npm start
                          magicmirror@2.10.1 start C:\Users\Office\MagicMirror
                          ./run-start.sh
                          ‘.’ is not recognized as an internal or external command,
                          operable program or batch file.
                          npm ERR! code ELIFECYCLE
                          npm ERR! errno 1
                          npm ERR! magicmirror@2.10.1 start: ./run-start.sh
                          npm ERR! Exit status 1
                          npm ERR!
                          npm ERR! Failed at the magicmirror@2.10.1 start script.
                          npm ERR! C:\Users\Office\AppData\Roaming\npm-cache_logs\2020-02-25T06_03_03_308Z-debug.log
                          What Will I DO
                          J S 2 Replies Last reply
                            jagdambasoft @jagdambasoft
                            @jagdambasoft as above i post an error
                            Now in package.json change a line under scripts
                            to
                                "start": "run-start.sh",
                            • A
                              aab142
                              I’m using Windows 10 and got the previous message as well. Changing to “run-start.sh” just opens the file with my text editor. I’m missing something.
                                roccodicarlo
                                I am getting errors when executing NPM install
                                $ npm install
                                npm ERR! code EPROTO
                                npm ERR! errno EPROTO
                                npm ERR! request to https://registry.npmjs.org/feedme failed, reason: write EPROTO 15828:error:14094419:SSL routines:ssl3_read_bytes:tlsv1 alert access denied:c:\ws\deps\openssl\openssl\ssl\record\rec_layer_s3.c:1544:SSL alert number 49
                                npm ERR!
                                npm ERR! C:\Users\dicarlro\AppData\Roaming\npm-cache_logs\2020-03-11T19_20_19_606Z-debug.log
                                Does this require Adminstrator login…I am not logged in as administrator
                                  sdetweil @jagdambasoft
                                  @jagdambasoft try the results of the post just before yours
                                    sdetweil @aab142
                                    @aab142 windows … ugh… the script needs access to bash but doesn’t understand ./
                                    so remove the ./
                                      dwburger
                                      I’ve started this installation process from 3 years ago on an old Acer laptop running Windows 10. It’s installing MM2 right now. Just wondering…have the walkthrough steps/commands changed in the intervening 3 years in any way that I need to know? I scanned the 85 posts and didn’t see any, but I could have missed it/them. Thanks! And, I’m really glad this topic is still alive!
                                        sdetweil @aab142
                                        @aab142 u need to change the startstring to
                                        "start":"node_modules/.bin/electron js/electron.js"
                                        D 1 Reply Last reply
                                          dwburger @sdetweil
                                          @sdetweil Perfect timing…thanks! I was trying “npm start” and “npm serveronly” with no luck. I’ll give it a go.
                                            dwburger
                                            Just for clarity, I enter (without starting/ending quotes), npm “start”:“node_modules/.bin/electron js/electron.js”???
                                            • 16
                                            • 17
                                            • 4 / 17
