    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 874.0k Views 59 Watching
      CliffordW
      Thanks for a great guide, got me up and running quickly. Can you guide me where do I insert the commands to rotate the display to portrait mode?
        bdream
        @Mykle1 Many thanks for this description!
        Just got it run under Windows 7. That will help to play and learn how to get own modules :nerd_face:
        Two questions I have.
        My MM is version 2.6.0. I planned to run updatescript from @sdetweil but failed. Yahe you any idea?
        Is there an option to run MM in a window being able to shrink and move over the desktop?
        cheers, bdream
        S Mykle1M 3 Replies Last reply Reply Quote 0
          sdetweil @bdream
          @bdream come talk in the Updated Installer topic
          https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
            sdetweil @bdream
            @bdream F11 will take a window from full screen to not
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @bdream
              @bdream said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
              Your F11 key should toggle between full screen MM and MM in a window
              • Mykle1M
                Damn Sam, you’re just too fast!
                  bdream
                  F11 seems to be a got hint, even it comes from @Mykle1 or @sdetweil.
                  Will try it this evening - thanks!
                  cheers, bdream
                  • O
                    OldShaterhan
                    For me setup running MagicMirror on Windows 10 worked by:
                    • cloning the repository
                    • then edit package.json by changing following line:
                      "scripts": {
                        "start": "./run-start.sh",
                    to:
                      "scripts": {
                        "start": "bash ./run-start.sh",
                    Simple change, works in every location on my PC.
                    blake_northrupB 1 Reply Last reply Reply Quote 0
                      jagdambasoft
                      $ npm start
                      magicmirror@2.10.1 start C:\Users\Office\MagicMirror
                      ./run-start.sh
                      ‘.’ is not recognized as an internal or external command,
                      operable program or batch file.
                      npm ERR! code ELIFECYCLE
                      npm ERR! errno 1
                      npm ERR! magicmirror@2.10.1 start: ./run-start.sh
                      npm ERR! Exit status 1
                      npm ERR!
                      npm ERR! Failed at the magicmirror@2.10.1 start script.
                      npm ERR! C:\Users\Office\AppData\Roaming\npm-cache_logs\2020-02-25T06_03_03_308Z-debug.log
                      What Will I DO
                      J S 2 Replies Last reply Reply Quote 0
                        jagdambasoft @jagdambasoft
                        @jagdambasoft as above i post an error
                        Now in package.json change a line under scripts
                        to
                            "start": "run-start.sh",
                        • A
                          aab142
                          I’m using Windows 10 and got the previous message as well. Changing to “run-start.sh” just opens the file with my text editor. I’m missing something.
                            roccodicarlo
                            I am getting errors when executing NPM install
                            $ npm install
                            npm ERR! code EPROTO
                            npm ERR! errno EPROTO
                            npm ERR! request to https://registry.npmjs.org/feedme failed, reason: write EPROTO 15828:error:14094419:SSL routines:ssl3_read_bytes:tlsv1 alert access denied:c:\ws\deps\openssl\openssl\ssl\record\rec_layer_s3.c:1544:SSL alert number 49
                            npm ERR!
                            npm ERR! C:\Users\dicarlro\AppData\Roaming\npm-cache_logs\2020-03-11T19_20_19_606Z-debug.log
                            Does this require Adminstrator login…I am not logged in as administrator
                              sdetweil @jagdambasoft
                              @jagdambasoft try the results of the post just before yours
                                sdetweil @aab142
                                @aab142 windows … ugh… the script needs access to bash but doesn’t understand ./
                                so remove the ./
                                  dwburger
                                  I’ve started this installation process from 3 years ago on an old Acer laptop running Windows 10. It’s installing MM2 right now. Just wondering…have the walkthrough steps/commands changed in the intervening 3 years in any way that I need to know? I scanned the 85 posts and didn’t see any, but I could have missed it/them. Thanks! And, I’m really glad this topic is still alive!
                                    sdetweil @aab142
                                    @aab142 u need to change the startstring to
                                    "start":"node_modules/.bin/electron js/electron.js"
                                      dwburger @sdetweil
                                      @sdetweil Perfect timing…thanks! I was trying “npm start” and “npm serveronly” with no luck. I’ll give it a go.
                                        dwburger
                                        Just for clarity, I enter (without starting/ending quotes), npm “start”:“node_modules/.bin/electron js/electron.js”???
                                          sdetweil @dwburger
                                          @dwburger you have to change the “start”: line in package.json to the text I provided
                                            dwburger
                                            OK…I’ll work on that.
                                            • 16
                                            • 17
                                            • 5 / 17
