    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 855.8k Views 59 Watching
      @sdetweil If u want to SEE/view it on the tablet (which might have a browser)
      in the base system config.js
      address:"0.0.0.0",
      ipWhitelist:[]
      then open the tablet browser to the ip of the base and port
      http://ip_address:8080
        dwburger @sdetweil
        @sdetweil Yes, it’s a Windows 10 laptop with a detachable screen that becomes a tablet basically.
        “Runs fine” = On the laptop, using Git Bash, I can start the MM2 normally with “npm start”.
        “Run it remotely” = The MM2 running on the tablet part of the laptop will sit in the kitchen (no keyboard or mouse). I want to manage it from my desktop in my office using Git Bash ssh connection.
        The laptop came with Edge, but I’ve been using Chrome.
        http://192.168.1.65:8080 fails
        http://localhost:8080 works
        S 3 Replies Last reply Reply Quote 0
          Windows doesn’t support remote display like linux does. u have to use an rdp client
          I am booted to my linux system now
            dwburger @sdetweil
            @sdetweil Oh, of course! I’ll work on that…thanks!
              sdetweil @dwburger
              @dwburger said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
              so, that looks like the address/ipWhitelist setting above…
              (by default MM thinks it is in a closed box on the wall, so only allows connections from INSIDE the box)
                dwburger @sdetweil
                @sdetweil :thumbs_up:
                  sdetweil @dwburger
                  but I don’t understand this…
                  with the change to the start script, it runs in windows without bash… just regular windows batch
                  (cmd/powershell)
                    dwburger @sdetweil
                    @sdetweil OK
                      sdetweil @dwburger
                      also, don’t know what this means… manage… it doesn’t NEED to run MM at all… just display it.
                      u could have two instances running on the base machine… 2 different ports…
                      the tablet accesses port(8081) , the base another (8080)
                      run the tablet instance as serveronly then no ui memory consumption on the base for that instance
                      to make a second copy from the first, just copy the MM folder to MM1, and change the config for port (and address/whitelist above)
                      then do npm serveronly for the tablet mm
                        Plainbroke 0
                        All,
                        You can not copy and paste though. I had to manually type it all in to make it work.
                        Still in MagicMirror;
                        nano package.json
                        right under the other “start”: “???”
                        go to the line below it and hit enter.
                        Then type in the blank space you just made.
                        “start”: “node_modules/.bin/electron js/electron.js”,
                        //DO NOT LEAVE OUT THE PUNCTUATION. ESPECIALLY THE COMMA AT THE END.
                        //I speak from expereince on this matter.
                        //Mykle1 usually has to help me find it after struggling for a couple hours.
                        THEN:
                        cd ~/MagicMirror/vendor
                        npm install
                        cd fonts
                        npm install
                        NOW IT will RUN
                        Thank you agian Mykle1
                        I am really enjoying this on my laptop,
                        so much easier to do testing ect.
                          sdetweil @Plainbroke 0
                          @Plainbroke-0 it was Sam, but anyway I cut and paste ALL the time. you need to add the code block marks around the actual steps to make them readable
                          • blake_northrupB Offline
                            blake_northrup @OldShaterhan
                            @OldShaterhan
                            I just made the change, and this is what I get when trying npm start:
                            $ npm start
                            magicmirror@2.12.0 start C:\Users\blake\MagicMirror
                            run-start.sh
                            ‘run-start.sh’ is not recognized as an internal or external command,
                            operable program or batch file.
                            npm ERR! code ELIFECYCLE
                            npm ERR! errno 1
                            npm ERR! magicmirror@2.12.0 start: run-start.sh
                            npm ERR! Exit status 1
                            npm ERR!
                            npm ERR! Failed at the magicmirror@2.12.0 start script.
                            npm ERR! C:\Users\blake\AppData\Roaming\npm-cache_logs\2020-07-07T18_11_04_725Z-debug.log
                              blake_northrup @dwburger
                              Thank you dwburger! This fixed my issue!
                                blake_northrup
                                I guess I spoke too soon. npm starts, but I have a blank screen. Haven’t done anything to the config.js file, except make a copy of the config.js.sample, and removed the .sample. See output:
                                $ npm run config:check
                                magicmirror@2.12.0 config:check C:\Users\blake\MagicMirror
                                node js/check_config.js
                                [2020-07-07 13:50:13.582] [INFO] Checking file… C:\Users\blake\MagicMirror\config\config.js
                                [2020-07-07 13:50:13.630] [LOG] Line 1 col 1 Definition for rule ‘prettier/prettier’ was not found.
                                C:\Users\blake\MagicMirror\js\check_config.js:66
                                throw new Error(“Wrong syntax in config file!”);
                                Error: Wrong syntax in config file!
                                at C:\Users\blake\MagicMirror\js\check_config.js:66:10
                                at FSReqCallback.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:63:3)
                                npm ERR! errno 1
                                npm ERR! magicmirror@2.12.0 config:check: node js/check_config.js
                                npm ERR!
                                npm ERR! Failed at the magicmirror@2.12.0 config:check script.
                                npm ERR! C:\Users\blake\AppData\Roaming\npm-cache_logs\2020-07-07T18_50_13_660Z-debug.log
                                  sdetweil @blake_northrup
                                  @blake_northrup not run-start
                                  “start”:“node_modules/.bin/electron js/electron.js”,
                                    @blake_northrup because u installed on windows, there are a couple extra steps
                                    cd MagicMirror
                                    cd vendor
                                    npm install
                                    cd …\fonts. 2dots
                                    npm install
                                    cd … 2dot
                                    the npm start
                                    this phone editor will not let me enter 2 dots, displays as 3
                                    blake_northrupB 3 Replies Last reply Reply Quote 2
                                      blake_northrup @sdetweil
                                      @sdetweil Thank you sdetweil. I will try thins now, and let you know.
                                        @sdetweil Still getting black screen after performing these steps. For some reason, it is stating that I have the wrong syntax in the config file.
                                        [2020-07-08 07:59:36.797] [INFO] Checking file… C:\Users\blake\MagicMirror\config\config.js
                                        [2020-07-08 07:59:36.854] [LOG] Line 1 col 1 Definition for rule ‘prettier/prettier’ was not found.
                                        npm ERR! errno 1
                                        npm ERR!
                                        npm ERR! C:\Users\blake\AppData\Roaming\npm-cache_logs\2020-07-08T12_59_36_872Z-debug.log
                                          @sdetweil Nevermind. All is now working. Had an extra bit of info in my config file that didn’t need to be there. Thanks again for all of your help sdetweil!
                                            dphotograph @blake_northrup
                                            @blake_northrup
                                            what was your “extra bit of info in my config file” ? i haf the same error and dont find an error with my config file on my new installed MagicMirror
                                            blake_northrupB 1 Reply Last reply Reply Quote 0
                                            • 16
                                            • 17
                                            • 7 / 17
