    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 886.4k Views 59 Watching
      dwburger
      I’ve installed MM2 on a new RCA Cambio. This little, cheap ($75) Windows 10 laptop (with a detachable screen that turns into a tablet) is meant to be an information MM2 in the kitchen. I got it up and running fine (following steps provided here), but I’d like to be able to run it remotely (e.g. when just the tablet is sitting in the kitchen). I can SSH to it using Git Bash and I see the start.sh script steps completing, but nothing ever happens on the tablet’s screen. It stays on the Windows 10 desktop. It starts fine using its own keyboard. I’m just wondering where I should look for a solution to this problem. Any ideas??? Thanks!
      S 2 Replies Last reply
        sdetweil @dwburger
        @dwburger the start script on windows needs to be changed
        in package.json
        change this
          "scripts": {
            "start": "./run-start",
        to this
          "scripts": {
            "start": "node_modules/.bin/electron",
        D 1 Reply Last reply
          dwburger @sdetweil
          @sdetweil Yes…I did that. You helped me with it last week.
            sdetweil @dwburger
            @dwburger but u got me wondering about the words…
            Windows 10
            runs fine
            run it remotely
            ssh/ git bash
            S D 2 Replies Last reply
              @sdetweil If u want to SEE/view it on the tablet (which might have a browser)
              in the base system config.js
              address:"0.0.0.0",
              ipWhitelist:[]
              then open the tablet browser to the ip of the base and port
              http://ip_address:8080
                dwburger @sdetweil
                @sdetweil Yes, it’s a Windows 10 laptop with a detachable screen that becomes a tablet basically.
                “Runs fine” = On the laptop, using Git Bash, I can start the MM2 normally with “npm start”.
                “Run it remotely” = The MM2 running on the tablet part of the laptop will sit in the kitchen (no keyboard or mouse). I want to manage it from my desktop in my office using Git Bash ssh connection.
                The laptop came with Edge, but I’ve been using Chrome.
                http://192.168.1.65:8080 fails
                http://localhost:8080 works
                S 3 Replies Last reply
                  Windows doesn’t support remote display like linux does. u have to use an rdp client
                  I am booted to my linux system now
                    dwburger @sdetweil
                    @sdetweil Oh, of course! I’ll work on that…thanks!
                      sdetweil @dwburger
                      @dwburger said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                      so, that looks like the address/ipWhitelist setting above…
                      (by default MM thinks it is in a closed box on the wall, so only allows connections from INSIDE the box)
                        dwburger @sdetweil
                        @sdetweil :thumbs_up:
                          sdetweil @dwburger
                          but I don’t understand this…
                          with the change to the start script, it runs in windows without bash… just regular windows batch
                          (cmd/powershell)
                            dwburger @sdetweil
                            @sdetweil OK
                              sdetweil @dwburger
                              also, don’t know what this means… manage… it doesn’t NEED to run MM at all… just display it.
                              u could have two instances running on the base machine… 2 different ports…
                              the tablet accesses port(8081) , the base another (8080)
                              run the tablet instance as serveronly then no ui memory consumption on the base for that instance
                              to make a second copy from the first, just copy the MM folder to MM1, and change the config for port (and address/whitelist above)
                              then do npm serveronly for the tablet mm
                                Plainbroke 0
                                All,
                                You can not copy and paste though. I had to manually type it all in to make it work.
                                Still in MagicMirror;
                                nano package.json
                                right under the other “start”: “???”
                                go to the line below it and hit enter.
                                Then type in the blank space you just made.
                                “start”: “node_modules/.bin/electron js/electron.js”,
                                //DO NOT LEAVE OUT THE PUNCTUATION. ESPECIALLY THE COMMA AT THE END.
                                //I speak from expereince on this matter.
                                //Mykle1 usually has to help me find it after struggling for a couple hours.
                                THEN:
                                cd ~/MagicMirror/vendor
                                npm install
                                cd fonts
                                npm install
                                NOW IT will RUN
                                Thank you agian Mykle1
                                I am really enjoying this on my laptop,
                                so much easier to do testing ect.
                                  sdetweil @Plainbroke 0
                                  @Plainbroke-0 it was Sam, but anyway I cut and paste ALL the time. you need to add the code block marks around the actual steps to make them readable
                                  • blake_northrupB
                                    blake_northrup @OldShaterhan
                                    @OldShaterhan
                                    I just made the change, and this is what I get when trying npm start:
                                    $ npm start
                                    magicmirror@2.12.0 start C:\Users\blake\MagicMirror
                                    run-start.sh
                                    ‘run-start.sh’ is not recognized as an internal or external command,
                                    operable program or batch file.
                                    npm ERR! code ELIFECYCLE
                                    npm ERR! errno 1
                                    npm ERR! magicmirror@2.12.0 start: run-start.sh
                                    npm ERR! Exit status 1
                                    npm ERR!
                                    npm ERR! Failed at the magicmirror@2.12.0 start script.
                                    npm ERR! C:\Users\blake\AppData\Roaming\npm-cache_logs\2020-07-07T18_11_04_725Z-debug.log
                                    • blake_northrupB
                                      blake_northrup @dwburger
                                      Thank you dwburger! This fixed my issue!
                                      • blake_northrupB
                                        blake_northrup
                                        I guess I spoke too soon. npm starts, but I have a blank screen. Haven’t done anything to the config.js file, except make a copy of the config.js.sample, and removed the .sample. See output:
                                        $ npm run config:check
                                        magicmirror@2.12.0 config:check C:\Users\blake\MagicMirror
                                        node js/check_config.js
                                        [2020-07-07 13:50:13.582] [INFO] Checking file… C:\Users\blake\MagicMirror\config\config.js
                                        [2020-07-07 13:50:13.630] [LOG] Line 1 col 1 Definition for rule ‘prettier/prettier’ was not found.
                                        C:\Users\blake\MagicMirror\js\check_config.js:66
                                        throw new Error(“Wrong syntax in config file!”);
                                        Error: Wrong syntax in config file!
                                        at C:\Users\blake\MagicMirror\js\check_config.js:66:10
                                        at FSReqCallback.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:63:3)
                                        npm ERR! errno 1
                                        npm ERR! magicmirror@2.12.0 config:check: node js/check_config.js
                                        npm ERR!
                                        npm ERR! Failed at the magicmirror@2.12.0 config:check script.
                                        npm ERR! C:\Users\blake\AppData\Roaming\npm-cache_logs\2020-07-07T18_50_13_660Z-debug.log
                                          sdetweil @blake_northrup
                                          @blake_northrup not run-start
                                          “start”:“node_modules/.bin/electron js/electron.js”,
                                            @blake_northrup because u installed on windows, there are a couple extra steps
                                            cd MagicMirror
                                            cd vendor
                                            npm install
                                            cd …\fonts. 2dots
                                            npm install
                                            cd … 2dot
                                            the npm start
                                            this phone editor will not let me enter 2 dots, displays as 3
                                            blake_northrupB 3 Replies Last reply
                                            Reply Quote 2
                                            • 16
                                            • 17
                                            • 7 / 17
