    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 865.0k Views 59 Watching
      dwburger
      I’ve started this installation process from 3 years ago on an old Acer laptop running Windows 10. It’s installing MM2 right now. Just wondering…have the walkthrough steps/commands changed in the intervening 3 years in any way that I need to know? I scanned the 85 posts and didn’t see any, but I could have missed it/them. Thanks! And, I’m really glad this topic is still alive!
        sdetweil @aab142
        @aab142 u need to change the startstring to
        "start":"node_modules/.bin/electron js/electron.js"
          dwburger @sdetweil
          @sdetweil Perfect timing…thanks! I was trying “npm start” and “npm serveronly” with no luck. I’ll give it a go.
            dwburger
            Just for clarity, I enter (without starting/ending quotes), npm “start”:“node_modules/.bin/electron js/electron.js”???
              sdetweil @dwburger
              @dwburger you have to change the “start”: line in package.json to the text I provided
                dwburger
                OK…I’ll work on that.
                  sdetweil @dwburger
                  @dwburger then npm start will work…
                  npm ???, executes the script next to ??? in package.json
                  D Mykle1M 2 Replies Last reply Reply Quote 0
                    dwburger @sdetweil
                    @sdetweil Yep, it works…thanks!
                      Sam, is there something that I need to change in the original post that is causing problems?
                      D S 2 Replies Last reply Reply Quote 0
                        dwburger @Mykle1
                        @Mykle1 May I butt in here. I was the one who started the question. I had to change the “start:” string in the package.json file to:
                        As Sam instructed. Once I did that, the “npm start” command got my MM2 running.
                        Thanks, BTW, for creating the walkthrough. I’m thrilled to have MM2 running on my old Acer laptop!
                        Mykle1M blake_northrupB 2 Replies Last reply Reply Quote 2
                          Mykle1 Project Sponsor Module Developer @dwburger
                          @dwburger
                          Oh, I thought perhaps something in the tutorial was wrong. I did not know that MM changed in a way that caused the tutorial to fail. :-(
                          You’re welcome. When I wrote this I was thrilled as well and have since moved to strictly laptop boards, However, I moved from Windows to ubuntu and I’ve never been happier. MM loves linux (ubuntu) and runs beautifully under it, without jumping through any hoops for Windows. It also uses far less resources than Windows. Consider it. You won’t be sorry.
                          And here it is.
                          https://forum.magicmirror.builders/topic/6994/mm-and-ubuntu-made-for-each-other
                            dwburger @Mykle1
                            @Mykle1 I will definitely take a look at Ubuntu. I got here since 1 of my 2 MM2 running with RPi isn’t stable enough and I’ve run out of things to try. I also have an old MacMini that I’m going to try. Thanks for the encouragement!
                              @dwburger
                              Dude, you’ll have so much fun doing it. I guarantee it! (Well, almost). But I did. And your MacMini? I’ve done Mac boards with ubuntu and MM, as well.
                              Here. Take a look.
                              https://forum.magicmirror.builders/topic/6376/macmirror
                                dwburger @Mykle1
                                @Mykle1 Nice!
                                  @dwburger
                                  Did you watch the video? Not bad for a useless, early gen, white iMac
                                    dwburger @Mykle1
                                    @Mykle1 Nope, missed the video the first time. Now seen. Amazing! Being a relatively new MM2 user, I didn’t know about hiding/showing pages or Hello-Lucy. Once I get my new MM2s up and running I’ll check into it.
                                      sdetweil @Mykle1
                                      @Mykle1 in 2.9 they introduced run-start.sh to fix the custom.css erasure problem. I extended it in 2.10.
                                      But it won’t work on windows at all.
                                      I didn’t know that til last week. I did test on the Linux runtime in Windows, but never on windows native.
                                      Mykle1M D 2 Replies Last reply Reply Quote 0
                                        Ah, ok, thanks
                                          dwburger @Mykle1
                                          @Mykle1 Yep, I had an old Toshiba NB205 laptop that I had converted to Ubuntu a couple years ago. I updated the OS and installed MM2 without a single hitch. Nice!
                                            dwburger @sdetweil
                                            @sdetweil On a side note…I updated my old Toshiba NB 205 laptop to Ubuntu Mate and tried to manually install MM2. After a few unsuccessful attempts, I used your script on Github and it ran through the installation and started up the new MM2 successfully in one attempt. THANKS! Since I’m “staying at home” due to the virus, I’ve now gotten MM2 to run on a Windows 10 PC, Mac Mini and now Ubuntu Mate. And…in the process, I’ve learned a great deal! Now, all I have to figure out is what I’m going to do with all these MM2s! :slightly_smiling_face:
                                            S Mykle1M 2 Replies Last reply Reply Quote 0
                                            • 16
                                            • 17
                                            • 5 / 17
