    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 865.0k Views 59 Watching
      sdetweil @Uwe Kretsen
      @Uwe-Kretsen see the links in my signature , they will help you
        bhumin
        @Mykle1 said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
        git clone https://github.com/MichMich/MagicMirror.git
        following error arrives when start
        magicmirror@2.13.0 start C:\Users\bhumi\MagicMirror
        ‘DISPLAY’ is not recognized as an internal or external command,
        operable program or batch file.
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! magicmirror@2.13.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the magicmirror@2.13.0 start script.
        npm ERR! C:\Users\bhumi\AppData\Roaming\npm-cache_logs\2020-12-16T05_04_47_316Z-debug.log
          bhumin @sdetweil
          @sdetweil thanks man
          • H Offline
            Humez
            Thank you for your tutorial! I’m a absolute beginner. I followed the steps above but when I try to start magicmirror I get the below message:
            magicmirror@2.14.0 start C:\Users\1234\magicmirror
            npm ERR! errno 1
            npm ERR! magicmirror@2.14.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
            npm ERR!
            npm ERR! Failed at the magicmirror@2.14.0 start script.
              sdetweil @Humez
              @humez read and follow the steps here
              https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/141?_=1612997713585
              u have not edited package.json as required
              • K Offline
                kithaam
                Hi Please help install Magic Mirror on my PC please assist with below
                http://localhost:8080 is just a black screen No date and Time on
                  sdetweil @kithaam
                  @kithaam yes, some missing steps.
                  do
                  cd MagicMirror
                  cd vendor
                  npm install
                  cd ..
                  cd fonts
                  npm install
                  cd ..
                  restart mm
                  K G 3 Replies Last reply Reply Quote 0
                  • K Offline
                    kithaam @sdetweil
                    @sdetweil Thank you its working
                    • K Offline
                      kithaam @sdetweil
                      @sdetweil Hi where do i go and change the Time and date? im new to this
                      • G Offline
                        goEasy @sdetweil
                        @sdetweil hello, i have done as you mentioned, but i have this trouble. please Help
                        cd MagicMirror
                        cd vendor
                        npm install
                        1 package is looking for funding
                          run `npm fund` for details
                        found 0 vulnerabilities
                        $ npm fund
                        magicmirror-vendors
                        `-- https://github.com/sponsors/jonschlinkert
                          `-- picomatch@2.2.2
                          sdetweil @goEasy
                          @goeasy no trouble… warnings… ignore
                          • G Offline
                            goEasy @sdetweil
                            @sdetweil you are a legend… btw all i had to do was
                            exit
                            then start mm again :grinning_face_with_sweat:
                            • G Offline
                              goEasy @Mykle1
                              @mykle1 Please Help, i am running into this ERROR…
                              Cowplain@DESKTOP-4IAPDRU MINGW64 ~
                              $ cd magicmirror
                              Cowplain@DESKTOP-4IAPDRU MINGW64 ~/magicmirror (master)
                              $ npm start
                              '.' is not recognized as an internal or external command,
                                sdetweil @goEasy
                                @goeasy do NOT install under MINGW64, just straight under windows
                                • G Offline
                                  goEasy @sdetweil
                                  @sdetweil Hey, thank you for the reply…
                                  i am new to this MM and coding, at one point everything was working then i cant remember what happened.
                                  i think is something to do with the Electron settings…
                                  Opening with CMD
                                  C:\Users\Cowplain\MagicMirror>npm start
                                  Opening with Git Bash
                                  $ npm start
                                  Please help
                                    sdetweil @goEasy
                                    @goeasy on windows, its support to say
                                    take off the ./
                                    windows doesn’t use that
                                    • G Offline
                                      goEasy @sdetweil
                                      @sdetweil how would i remove
                                      ? i looked in the MM folder and such thing doesn’t exist
                                        sdetweil @goEasy
                                        @goeasy edit package.json and change the start line
                                        • K Offline
                                          kithaam
                                          f6415e51-f1e8-4024-abe0-dfce398f0ded-image.png Please assist with this error
                                            sdetweil @kithaam
                                            @kithaam u are on windows. don’t follow the linux instructions
                                            • 10
                                            • 16
                                            • 17
                                            • 8 / 17
