    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 874.0k Views 59 Watching
    • A
      airart @sdetweil
      @sdetweil not working after edit package.json , i try to start on Win CMD with npm start ( folder MagicMirror)
        sdetweil @airart
        @airart what does it say?
        show the text of the start line now
        • A
          airart @sdetweil
          @sdetweil i edit like this
          "start": "node_modules/.bin/electron js/electron.js",
          A S 2 Replies Last reply Reply Quote 0
          • A
            airart @airart
            @airart it say
            “node_modules” non è riconosciuto come come comando interno …
              sdetweil @airart
              @airart mine works like this
              "start": "./node_modules/.bin/electron js/electron.js",
              • A
                airart @sdetweil
                @sdetweil seems that in node_modules folder/.bin/ there’s not any electron.js
                i’v also tried with cmd …
                  sdetweil @airart
                  @airart did you do the npm install?
                  • A
                    airart @sdetweil
                    @sdetweil yes i do
                      sdetweil @airart
                      @airart what version of node and npm are installed
                      npm -v
                      node -v
                      • A
                        airart @sdetweil
                        @sdetweil npm 7.14.0 , node 14.17.0
                          sdetweil @airart
                          @airart interesting
                          ok, lets try to start over that step
                          cd MagicMirror
                          del package-lock.json
                          rd /q/s  node_modules
                          npm install  only=prod
                          we will want the name of the log file when it finishes in case
                          • A
                            airart @sdetweil
                            @sdetweil only the name ?
                            2021-05-28T12_56_04_242Z-debug
                            0 verbose cli [
                            0 verbose cli   'C:\\Program Files\\nodejs\\node.exe',
                            0 verbose cli   'C:\\Users\\gizmo\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js',
                            0 verbose cli   'install',
                            0 verbose cli   'only=prod'
                            0 verbose cli ]
                            1 info using npm@7.14.0
                            2 info using node@v14.17.0
                            3 timing npm:load:whichnode Completed in 8ms
                            4 timing config:load:defaults Completed in 9ms
                            5 timing config:load:file:C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\npmrc Completed in 8ms
                            6 timing config:load:builtin Completed in 9ms
                            7 timing config:load:cli Completed in 9ms
                            8 timing config:load:env Completed in 3ms
                            9 timing config:load:file:C:\Users\gizmo\MagicMirror\.npmrc Completed in 2ms
                            10 timing config:load:project Completed in 5ms
                            11 timing config:load:file:C:\Users\gizmo\.npmrc Completed in 1ms
                            12 timing config:load:user Completed in 1ms
                            13 timing config:load:file:C:\Users\gizmo\AppData\Roaming\npm\etc\npmrc Completed in 1ms
                            14 timing config:load:global Completed in 2ms
                            15 timing config:load:validate Completed in 1ms
                            16 timing config:load:credentials Completed in 10ms
                            17 timing config:load:setEnvs Completed in 12ms
                            18 timing config:load Completed in 61ms
                            19 timing npm:load:configload Completed in 61ms
                            20 timing npm:load:setTitle Completed in 3ms
                            21 timing npm:load:setupLog Completed in 11ms
                            22 timing npm:load:cleanupLog Completed in 13ms
                            23 timing npm:load:configScope Completed in 0ms
                            24 timing npm:load:projectScope Completed in 4ms
                            25 timing npm:load Completed in 104ms
                            26 timing config:load:flatten Completed in 20ms
                            27 timing arborist:ctor Completed in 3ms
                            28 timing arborist:ctor Completed in 1ms
                            29 timing idealTree:init Completed in 122ms
                            30 timing idealTree Completed in 150ms
                            31 timing command:install Completed in 234ms
                            32 verbose stack Error: Invalid tag name "only=prod": Tags may not have any characters that encodeURIComponent encodes.
                            32 verbose stack     at invalidTagName (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\npm-package-arg\npa.js:94:15)
                            32 verbose stack     at fromRegistry (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\npm-package-arg\npa.js:299:13)
                            32 verbose stack     at resolve (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\npm-package-arg\npa.js:84:12)
                            32 verbose stack     at npa (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\npm-package-arg\npa.js:55:10)
                            32 verbose stack     at C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\@npmcli\arborist\lib\arborist\build-ideal-tree.js:474:50
                            32 verbose stack     at Array.map (<anonymous>)
                            32 verbose stack     at Arborist.[add] (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\@npmcli\arborist\lib\arborist\build-ideal-tree.js:471:28)
                            32 verbose stack     at Arborist.[applyUserRequestsToNode] (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\@npmcli\arborist\lib\arborist\build-ideal-tree.js:446:23)
                            32 verbose stack     at Arborist.[applyUserRequests] (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\@npmcli\arborist\lib\arborist\build-ideal-tree.js:402:43)
                            32 verbose stack     at Arborist.buildIdealTree (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\@npmcli\arborist\lib\arborist\build-ideal-tree.js:217:37)
                            33 verbose cwd C:\Users\gizmo\MagicMirror
                            34 verbose Windows_NT 10.0.18362
                            35 verbose argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\gizmo\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js" "install" "only=prod"
                            36 verbose node v14.17.0
                            37 verbose npm  v7.14.0
                            38 error code EINVALIDTAGNAME
                            39 error Invalid tag name "only=prod": Tags may not have any characters that encodeURIComponent encodes.
                            40 verbose exit 1
                              sdetweil @airart
                              @airart sorry, typo
                              –only=prod
                              • A
                                airart @sdetweil
                                @sdetweil ok done , but no log is generated
                                npm start
                                same errors :-(
                                  sdetweil @airart
                                  @airart there is always a log
                                  in the users home folder .npm/logs
                                  I will recheck my windows env too
                                  npm install --loglevel verbose
                                  should write a file in the local folder
                                  npm-debug.log
                                  when I start my MM i get
                                  C:\Users\sdetw\MagicMirror>npm start
                                  > magicmirror@2.15.0 start C:\Users\sdetw\MagicMirror
                                  [28.05.2021 09:25.27.486] [LOG]   Starting MagicMirror: v2.15.0
                                  • A
                                    airart @sdetweil
                                    @sdetweil i try to find this .log but no one is generating … i search in all of my hdd …
                                    when i type npm start
                                    C:\Users\gizmo\MagicMirror>npm start
                                    "node_modules" non è riconosciuto come comando interno o esterno,
                                     un programma eseguibile o un file batch.
                                    and there’s no electron js FOLDER in .bin FOLDER
                                      sdetweil @airart
                                      @airart do again
                                      • A
                                        airart @sdetweil
                                        @sdetweil nope pal , nothing …
                                        no log
                                        no start
                                        where is your log ?
                                          sdetweil @airart
                                          @airart man I hate this stuff changing all the time
                                          do this
                                          npm install --only=prod --loglevel verbose >somefile.txt 2>&1
                                          then the install info is in somefile.txt
                                          • A
                                            airart @sdetweil
                                            @sdetweil here !
                                            npm verb cli [
                                            npm verb cli   'C:\\Program Files\\nodejs\\node.exe',
                                            npm verb cli   'C:\\Users\\gizmo\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js',
                                            npm verb cli   'install',
                                            npm verb cli   '--only=prod',
                                            npm verb cli   '--loglevel',
                                            npm verb cli   'verbose'
                                            npm verb cli ]
                                            npm info using npm@7.14.0
                                            npm info using node@v14.17.0
                                            npm timing npm:load:whichnode Completed in 8ms
                                            npm timing config:load:defaults Completed in 10ms
                                            npm timing config:load:file:C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\npmrc Completed in 16ms
                                            npm timing config:load:builtin Completed in 16ms
                                            npm verb config only Use `--omit=dev` to omit dev dependencies from the install.
                                            npm timing config:load:cli Completed in 11ms
                                            npm timing config:load:env Completed in 2ms
                                            npm timing config:load:file:C:\Users\gizmo\MagicMirror\.npmrc Completed in 2ms
                                            npm timing config:load:project Completed in 5ms
                                            npm timing config:load:file:C:\Users\gizmo\.npmrc Completed in 1ms
                                            npm timing config:load:user Completed in 2ms
                                            npm timing config:load:file:C:\Users\gizmo\AppData\Roaming\npm\etc\npmrc Completed in 1ms
                                            npm timing config:load:global Completed in 1ms
                                            npm timing config:load:validate Completed in 2ms
                                            npm timing config:load:credentials Completed in 7ms
                                            npm timing config:load:setEnvs Completed in 5ms
                                            npm timing config:load Completed in 64ms
                                            npm timing npm:load:configload Completed in 65ms
                                            npm timing npm:load:setTitle Completed in 1ms
                                            npm timing npm:load:setupLog Completed in 5ms
                                            npm timing npm:load:cleanupLog Completed in 14ms
                                            npm timing npm:load:configScope Completed in 0ms
                                            npm timing npm:load:projectScope Completed in 5ms
                                            npm timing npm:load Completed in 127ms
                                            npm timing config:load:flatten Completed in 16ms
                                            npm timing arborist:ctor Completed in 4ms
                                            npm timing idealTree:init Completed in 2669ms
                                            npm timing idealTree:userRequests Completed in 1ms
                                            npm timing idealTree:#root Completed in 2ms
                                            npm timing idealTree:buildDeps Completed in 9ms
                                            npm timing idealTree:fixDepFlags Completed in 1ms
                                            npm timing idealTree Completed in 2750ms
                                            npm timing arborist:ctor Completed in 1ms
                                            npm timing reify:loadTrees Completed in 5000ms
                                            npm timing reify:diffTrees Completed in 162ms
                                            npm timing reify:retireShallow Completed in 1ms
                                            npm timing reify:createSparse Completed in 5ms
                                            npm timing reify:trashOmits Completed in 70ms
                                            npm timing reify:loadBundles Completed in 0ms
                                            npm timing reify:unpack Completed in 189ms
                                            npm timing reify:unretire Completed in 1ms
                                            npm timing build:queue Completed in 20ms
                                            npm timing build:deps Completed in 23ms
                                            npm timing build Completed in 23ms
                                            npm timing reify:build Completed in 25ms
                                            npm http fetch POST 200 https://registry.npmjs.org/-/npm/v1/security/advisories/bulk 7305ms
                                            npm timing auditReport:getReport Completed in 7342ms
                                            npm timing auditReport:init Completed in 0ms
                                            npm timing reify:audit Completed in 7347ms
                                            npm timing reify:trash Completed in 7867ms
                                            npm timing reify:save Completed in 1634ms
                                            npm timing reify Completed in 15363ms
                                            > magicmirror@2.15.0 install
                                            > " && cd vendor && npm install --loglevel=error
                                            > magicmirror@2.15.0 postinstall
                                            > npm run install-fonts && echo "MagicMirror installation finished successfully!
                                            npm info it worked if it ends with ok
                                            npm verb cli [
                                            npm verb cli   'C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js',
                                            npm verb cli   'prefix',
                                            npm verb cli   '-g'
                                            npm verb cli ]
                                            npm info using npm@6.14.13
                                            npm verb exit [ 0, true ]
                                            npm timing npm Completed in 377ms
                                            npm info ok
                                            npm verb cli [
                                            npm verb cli   'run',
                                            npm verb cli   'install-fonts'
                                            npm verb cli ]
                                            npm timing config:load:defaults Completed in 11ms
                                            npm timing config:load:file:C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\npmrc Completed in 15ms
                                            npm timing config:load:cli Completed in 8ms
                                            npm timing config:load:env Completed in 5ms
                                            npm timing config:load:file:C:\Users\gizmo\MagicMirror\.npmrc Completed in 1ms
                                            npm timing config:load:file:C:\Users\gizmo\.npmrc Completed in 0ms
                                            npm timing config:load:user Completed in 1ms
                                            npm timing config:load:validate Completed in 4ms
                                            npm timing config:load:credentials Completed in 5ms
                                            npm timing config:load:setEnvs Completed in 4ms
                                            npm timing config:load Completed in 60ms
                                            npm timing npm:load:configload Completed in 62ms
                                            npm timing npm:load Completed in 118ms
                                            > magicmirror@2.15.0 install-fonts
                                            > echo "Installing fonts ...
                                            > " && cd fonts && npm install --loglevel=error
                                            npm timing command:run-script Completed in 65ms
                                            npm verb exit 0
                                            npm timing npm Completed in 1407ms
                                            npm info ok
                                            up to date, audited 331 packages in 21s
                                            21 packages are looking for funding
                                              run `npm fund` for details
                                            found 0 vulnerabilities
                                            npm timing command:install Completed in 19769ms
                                            npm verb exit 0
                                            npm timing npm Completed in 21493ms
                                            npm info ok
                                            • 10
                                            • 11
                                            • 16
                                            • 17
                                            • 9 / 17
