    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 827.9k Views 59 Watching
    • G Offline
      goEasy @sdetweil
      @sdetweil Hey, thank you for the reply…
      i am new to this MM and coding, at one point everything was working then i cant remember what happened.
      i think is something to do with the Electron settings…
      Opening with CMD
      C:\Users\Cowplain\MagicMirror>npm start
      > magicmirror@2.14.0 start
      > ./node_modules/.bin/electron js/electron.js
      '.' is not recognized as an internal or external command,
      operable program or batch file.
      Opening with Git Bash
      Cowplain@DESKTOP-4IAPDRU MINGW64 ~/magicmirror (master)
      $ npm start
      Please help
        sdetweil @goEasy
        @goeasy on windows, its support to say
        take off the ./
        windows doesn’t use that
        • G Offline
          goEasy @sdetweil
          @sdetweil how would i remove
          ? i looked in the MM folder and such thing doesn’t exist
            sdetweil @goEasy
            @goeasy edit package.json and change the start line
            • K Offline
              kithaam
              f6415e51-f1e8-4024-abe0-dfce398f0ded-image.png Please assist with this error
                sdetweil @kithaam
                @kithaam u are on windows. don’t follow the linux instructions
                • K Offline
                  kithaam @sdetweil
                  @sdetweil hi on windows
                    sdetweil @kithaam
                    @kithaam yes. I know
                    is a linux thing
                    follow the windows instructions
                    https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/141?page=15
                    • K Offline
                      kithaam @sdetweil
                      @sdetweil 62fe3601-ef5f-4d26-8b18-570f552dfeda-image.png Hi Please see this error
                        sdetweil @kithaam
                        @kithaam follow ALL the instructions…
                        • K Offline
                          kithaam @sdetweil
                          @sdetweil !hi im getting the same errors
                            sdetweil @kithaam
                            @kithaam it doesn’t say “npm start” in the vendor or font folders
                              airart @sdetweil
                              @sdetweil not working after edit package.json , i try to start on Win CMD with npm start ( folder MagicMirror)
                                sdetweil @airart
                                @airart what does it say?
                                show the text of the start line now
                                  airart @sdetweil
                                  @sdetweil i edit like this
                                  "start": "node_modules/.bin/electron js/electron.js",
                                  A S 2 Replies Last reply Reply Quote 0
                                    airart @airart
                                    @airart it say
                                    “node_modules” non è riconosciuto come come comando interno …
                                      sdetweil @airart
                                      @airart mine works like this
                                      "start": "./node_modules/.bin/electron js/electron.js",
                                        airart @sdetweil
                                        @sdetweil seems that in node_modules folder/.bin/ there’s not any electron.js
                                        i’v also tried with cmd …
                                          sdetweil @airart
                                          @airart did you do the npm install?
                                            airart @sdetweil
                                            @sdetweil yes i do
                                            • 10
                                            • 11
                                            • 16
                                            • 17
                                            • 9 / 17
