    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 886.4k Views 59 Watching
    • A
      airart @sdetweil
      @sdetweil is not working
      	"scripts": {
      		"start": "node_modules/.bin/electron js/electron.js",
      		"start:dev": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js dev",
      same errors
      C:\Users\gizmo\MagicMirror>npm start
      > magicmirror@2.15.0 start
      "node_modules" non è riconosciuto come comando interno o esterno,
       un programma eseguibile o un file batch.
        sdetweil @airart
        @airart did u try to install electron?
        npm install electron@11.3.0
        so we can see the error, if any
        A 2 Replies Last reply
        • A
          airart @sdetweil
          @sdetweil yes
          C:\Users\gizmo\MagicMirror>npm install  electron@11.3.0  --loglevel=verbose
          npm verb cli [
          npm verb cli   'C:\\Program Files\\nodejs\\node.exe',
          npm verb cli   'C:\\Users\\gizmo\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js',
          npm verb cli   'install',
          npm verb cli   'electron@11.3.0',
          npm verb cli   '--loglevel=verbose'
          n................ecc
          • A
            airart @sdetweil
            @sdetweil i try to restore original package.js and this show me a new log…
            0 verbose cli [
            0 verbose cli   'C:\\Program Files\\nodejs\\node.exe',
            0 verbose cli   'C:\\Users\\gizmo\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js',
            0 verbose cli   'start'
            0 verbose cli ]
            1 info using npm@7.14.0
            2 info using node@v14.17.0
            3 timing npm:load:whichnode Completed in 8ms
            4 timing config:load:defaults Completed in 10ms
            5 timing config:load:file:C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\npmrc Completed in 15ms
            6 timing config:load:builtin Completed in 15ms
            7 timing config:load:cli Completed in 8ms
            8 timing config:load:env Completed in 3ms
            9 timing config:load:file:C:\Users\gizmo\MagicMirror\.npmrc Completed in 1ms
            10 timing config:load:project Completed in 4ms
            11 timing config:load:file:C:\Users\gizmo\.npmrc Completed in 1ms
            12 timing config:load:user Completed in 1ms
            13 timing config:load:file:C:\Users\gizmo\AppData\Roaming\npm\etc\npmrc Completed in 1ms
            14 timing config:load:global Completed in 1ms
            15 timing config:load:validate Completed in 1ms
            16 timing config:load:credentials Completed in 5ms
            17 timing config:load:setEnvs Completed in 4ms
            18 timing config:load Completed in 53ms
            19 timing npm:load:configload Completed in 54ms
            20 timing npm:load:setTitle Completed in 1ms
            21 timing npm:load:setupLog Completed in 13ms
            22 timing npm:load:cleanupLog Completed in 14ms
            23 timing npm:load:configScope Completed in 0ms
            24 timing npm:load:projectScope Completed in 2ms
            25 timing npm:load Completed in 96ms
            26 timing config:load:flatten Completed in 15ms
            27 timing command:run-script Completed in 3ms
            28 timing command:start Completed in 57ms
            29 verbose stack Error: ENOENT: no such file or directory, open 'C:\Users\gizmo\MagicMirror\package.json'
            30 verbose cwd C:\Users\gizmo\MagicMirror
            31 verbose Windows_NT 10.0.18362
            32 verbose argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\gizmo\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js" "start"
            33 verbose node v14.17.0
            34 verbose npm  v7.14.0
            35 error code ENOENT
            36 error syscall open
            37 error path C:\Users\gizmo\MagicMirror/package.json
            38 error errno -4058
            39 error enoent ENOENT: no such file or directory, open 'C:\Users\gizmo\MagicMirror\package.json'
            40 error enoent This is related to npm not being able to find a file.
            41 verbose exit -4058
            • A
              airart
              nothing to do, it doesn’t seem to find the electron file and folders
                sdetweil @airart
                @airart i don’t understand, I installed on windows 10 without trouble… but it was npm v6.
                I just installed and used npm 7.14…
                I had to use the full path to electron
                here is my package.json start line
                "start": "/Users/sdetw/MagicMirror/node_modules/.bin/electron js/electron.js",
                this is due to a change in npm… my prior instance will not start now without the full path
                S A 2 Replies Last reply
                  this is because npm 7.14 is trying to launch from the MagicMirror folder instead of the module folder…
                  • A
                    airart @sdetweil
                    @sdetweil can i install npm v6 ?
                      sdetweil @airart
                      @airart yes,
                      npm install -g npm@6.14.0
                      after this completes
                      cd MagicMirror
                      rd /s/q node_modules
                      npm install
                      A 1 Reply Last reply
                      • A
                        airart @sdetweil
                        @sdetweil in which folder it should be installed
                          sdetweil @airart
                          @airart -g means global
                          • A
                            airart @sdetweil
                            @sdetweil it works ! I am so moved, evidently that was the problem.
                            Does CMD remain active how do I leave the MM? fn + f11 reduces to window
                            I also noticed some warnings
                              sdetweil @airart
                              @airart ctrl-c in ther terminal window will stop the active program
                              ignore warnings
                                matefits71
                                Thanks for the tutorial, i’m running magicmirror on a surface pro 4,
                                The installation worked perfectly but when i tried to run npm start it throw an error “> DISPLAY=”${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js"
                                To bypass the error i edited the package.json by removing the DISPLAY="${DISPLAY:=:0} at the begining, tried npm start and it worked.
                                I’m not sure for what is that display option.
                                  sdetweil @matefits71
                                  @matefits71 on Linux, the xwindows graphical system writes to a numbered ‘display’ , and there can be multiple.
                                  windows doesn’t have that. which is why I’ve written to remove that part, and also run the manual npm install in vendors and go ta folders
                                  • A
                                    angeldchaveza
                                    $ npm start
                                    magicmirror@2.16.0 start C:\Users\Tecsis\MagicMirror
                                    “DISPLAY” no se reconoce como un comando interno o externo,
                                    programa o archivo por lotes ejecutable.
                                    npm ERR! code ELIFECYCLE
                                    npm ERR! errno 1
                                    npm ERR! magicmirror@2.16.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                                    npm ERR! Exit status 1
                                    npm ERR!
                                    npm ERR! Failed at the magicmirror@2.16.0 start script.
                                    npm ERR! C:\Users\Tecsis\AppData\Roaming\npm-cache_logs\2021-09-02T01_57_52_304Z-debug.log
                                    • A
                                      angeldchaveza @angeldchaveza
                                      @angeldchaveza .
                                      im delete display of "matefits71 " error logs view
                                      1 verbose cli [
                                      1 verbose cli ‘C:\Program Files\nodejs\node.exe’,
                                      1 verbose cli ‘C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js’,
                                      1 verbose cli ‘start’
                                      1 verbose cli ]
                                      2 info using npm@6.14.14
                                      3 info using node@v14.17.5
                                      4 verbose stack Error: missing script: start
                                      4 verbose stack at run (C:\Program Files\nodejs\node_modules\npm\lib\run-script.js:155:19)
                                      4 verbose stack at C:\Program Files\nodejs\node_modules\npm\lib\run-script.js:63:5
                                      4 verbose stack at C:\Program Files\nodejs\node_modules\npm\node_modules\read-package-json\read-json.js:116:5
                                      4 verbose stack at C:\Program Files\nodejs\node_modules\npm\node_modules\read-package-json\read-json.js:436:5
                                      4 verbose stack at checkBinReferences_ (C:\Program Files\nodejs\node_modules\npm\node_modules\read-package-json\read-json.js:391:45)
                                      4 verbose stack at final (C:\Program Files\nodejs\node_modules\npm\node_modules\read-package-json\read-json.js:434:3)
                                      4 verbose stack at then (C:\Program Files\nodejs\node_modules\npm\node_modules\read-package-json\read-json.js:161:5)
                                      4 verbose stack at C:\Program Files\nodejs\node_modules\npm\node_modules\read-package-json\read-json.js:382:12
                                      4 verbose stack at C:\Program Files\nodejs\node_modules\npm\node_modules\graceful-fs\graceful-fs.js:123:16
                                      4 verbose stack at FSReqCallback.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:73:3)
                                      5 verbose cwd C:\Users\Tecsis\MagicMirror
                                      6 verbose Windows_NT 10.0.19041
                                      7 verbose argv “C:\Program Files\nodejs\node.exe” “C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js” “start”
                                      8 verbose node v14.17.5
                                      9 verbose npm v6.14.14
                                      10 error missing script: start
                                      11 verbose exit [ 1, true ]
                                        sdetweil @angeldchaveza
                                        @angeldchaveza u are on windows. there are extra steps for windows.
                                        https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/141?page=15
                                        • A
                                          angeldchaveza @sdetweil
                                          @sdetweil said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                                          these were the steps i followed
                                            @angeldchaveza yes, but they changed.
                                            my link has the updated steps
                                            • 10
                                            • 11
                                            • 12
                                            • 16
                                            • 17
                                            • 10 / 17
