    MMM-RFID and MMM-Profileswitcher with RC522
    10 Posts 2 Posters 1.3k Views 2 Watching
    • K Offline
      Kavilan
      Re: Profile Switcher - RC522 RFID
      Hi all, I’ve been trying to get my RFID tag to switch profile and I have referred every solution so far I can’t seem to get MMM-RFID to detect my card in MagicMirror. When i run the test given it can read the card and the data but when i run npm start dev, I can’t see anything about notifcation getting sent when i scan my RFID. Any help is greatly appreciated.
        sdetweil @Kavilan
        @kavilan said in MMM-RFID and MMM-Profileswitcher with RC522:
        MMM-RFID
        did u do the steps in the doc to program the rfid tag?
        K 1 Reply Last reply Reply Quote 1
        • K Offline
          Kavilan @sdetweil
          @sdetweil Yeah I’ve done that and when I run the test read.py from MMM_RFID it shows the UID and the Data in decimals. sc.jpeg
          And this is the config.
            sdetweil @Kavilan
            @kavilan the code says it uses
            python MFRC522-python/Dump.py
            (from the module folder)
            to read the rfid chip on the pi
            • K Offline
              Kavilan @sdetweil
              @sdetweil When I run Dump.py I still am able to scan the RFID tag and the correct data is shown. SoI dont know why it doesn’t work when running MagicMirror
                sdetweil @Kavilan
                @kavilan ok, the just send a notice that an rfid was read…
                open the developers window, ctrl-shift-i on the MM keyboard and
                select the tab labeled console
                you should be able to see the events being sent out
                “RFID_UID”, payload
                and
                “RFID_DATA”, payload
                and any events in the config events list
                • K Offline
                  Kavilan @sdetweil
                  @sdetweil Yeah this is how I found out there are no events being sent out by MMM-RFID. I have two tags and I’ve tried both and nothing new shows up in the console
                    sdetweil @Kavilan
                    @kavilan when u ran the python pgm, did you use python or python3 as the command?
                    the module uses python
                    to change u can edit the rfid.js file and change this line
                       this.rc522py = this.spawn('python', ['-u', __dirname + '/MFRC522-python/Dump.py']);
                    to use python3
                       this.rc522py = this.spawn('python'3, ['-u', __dirname + '/MFRC522-python/Dump.py']);
                    • K Offline
                      Kavilan @sdetweil
                      @sdetweil I used python. Python 3 thrown error whenever used since all those codes don’t use () for print function.
                        sdetweil @Kavilan
                        @kavilan so it’s down to the output parser in the rfid.js
