Error in using python with child_process
node_helper.js
const spawn = require('child_process').spawn; const NodeHelper = require("node_helper"); var self; module.exports = NodeHelper.create({ start: function () { self = this; console.log("Starting node_helper for: " + this.name); }, getData: function () { const result = spawn('python', ['/home/pi/MagicMirror/modules/MMM-DustInfo/Naver_geo.py']); result.stdout.on('data', function(data) { console.log(data.toString()); recivedData = data.toString(); recivedData = JSON.parse(recivedData); }); result.on('close', (code) => { console.log(recivedData.station); station = recivedData.station; pm10 = recivedData.pm10; var recivedData = { station, pm10 } self.sendSocketNotification('TEXT_RESULT', recivedData); }); process.on('exit', function() { if (x) { x.kill(); } }); }, socketNotificationReceived: function (notification, payload) { if (notification === 'GET_TEXT_DATA') { self.getData(); } }, });my python file code
import requests import pandas as pd import json import urllib.request from bs4 import BeautifulSoup from haversine import haversine station_data = pd.read_excel("/home/pi/Desktop/Dust/station_list.xlsx") location_data = pd.read_excel("/home/pi/Desktop/Dust/location.xlsx") location_data = location_data.values.tolist() def search_map(search_text): client_id = 'vo9k89s848' #클라이언트 ID값 client_secret = 'MPooQfaCMH9eSMnT50RvNEYjChshVRHwq3qiBoQi' #클라이언트 Secret값 encText = urllib.parse.quote(search_text) url = 'https://naveropenapi.apigw.ntruss.com/map-geocode/v2/geocode?query='+encText request = urllib.request.Request(url) request.add_header('X-NCP-APIGW-API-KEY-ID', client_id) request.add_header('X-NCP-APIGW-API-KEY', client_secret) response = urllib.request.urlopen(request) rescode = response.getcode() if(rescode==200): response_body = response.read() return response_body.decode('utf-8') def station_info(): station_info = [] for i in range(489): info = search_map(station_data.loc[i]['측정소 주소']) info = json.loads(info) station_info.append([float(info['addresses'][0]['y']),float(info['addresses'][0]['x'])]) return station_info def curr_LocInfo(): curr_LocInfo = [] info = search_map("서울특별시 노원구 공릉로 232") info = json.loads(info) curr_LocInfo.append([float(info['addresses'][0]['y']),float(info['addresses'][0]['x'])]) return curr_LocInfo def Loc_to_xlsx(): station_x = station_info() station_x = pd.DataFrame(station_x) station_x.to_excel("C:/Users/sks12/Desktop/PythonWorkspace/Dust_Window/location.xlsx") def search_station(): station_Loc = location_data curr_Loc = curr_LocInfo() min = 10000 for i in range(489): distance = haversine((station_Loc[i][1], station_Loc[i][2]), curr_Loc[0], unit = 'km') if distance < min: min = distance globals()['station_index'] = i def Dust_info(): search_station() city = station_data.loc[station_index]['측정소명'] key = "mr81qR0Ed0RG4%2FUFpmXXLO0c7AO3HI6PC%2BVFgy%2BMO1yZ%2F7ciBAJejaPZ%2FmHi%2F30D4CYg7DKkGwpxHXTgHQDTSQ%3D%3D" url = "http://apis.data.go.kr/B552584/ArpltnInforInqireSvc/getMsrstnAcctoRltmMesureDnsty?stationName={}&dataTerm=month&pageNo=1&numOfRows=100&returnType=xml&serviceKey={}".format(city, key) res = requests.get(url) res.raise_for_status() content = BeautifulSoup(res.text, "lxml") dust = content.item pm10 = dust.pm10value check = pm10.get_text() if check == '-': dust = dust.next_sibling dust = dust.next_sibling pm10 = dust.pm10value pm10 = int(pm10.get_text()) # print("near station: {}".format(station_data.loc[station_index]['측정소명'])) # print("dust info:{}".format(pm10)) data = { "station" : station_data.loc[station_index]['측정소명'], "pm10" : pm10 } data_json = json.dumps(data) print (data_json) Dust_info()my module code
Module.register("MMM-DustInfo", { defaults: { updateInterval: 60000, }, requiresVersion: "2.1.0", // Required version of MagicMirror start: function () { // Log.info("Starting module: " + this.name); // requiresVersion: "2.1.0"; // this.loaded = false; this.scheduleUpdate(); }, getStyles: function() { return["MMM-DustInfo.css"]; }, scheduleUpdate: function () { setInterval(() => { this.getData(); }, this.config.updateInterval); this.getData(); }, getData: function() { console.log('GET_TEXT_DATA', this.config) this.sendSocketNotification('GET_TEXT_DATA', this.config); }, socketNotificationReceived: function (notification, payload) { if (notification === "TEXT_RESULT") { this.textDataRecived = payload; this.loaded = true; } this.updateDom(); }, getDom: function () { var wrapper = document.createElement("div"); if (!this.loaded) { wrapper.innerHTML = "LOADING"; return wrapper; } if (this.loaded) { var table = document.createElement('td'); var space1 = document.createElement('tr'); var space2 = document.createElement('tr'); var pm10Icon = document.createElement("tr"); if (this.textDataRecived.pm10 <= 30) { Icon_pm10 = "fa fa-smile-o"; pm10Icon.id = 'smile' } else if (this.textDataRecived.pm10 > 30 && this.textDataRecived.pm10 <= 80) { Icon_pm10 = "fa fa-meh-o" pm10Icon.id = 'meh' } else { Icon_pm10 = "fa fa-frown-o" pm10Icon.id = 'frown' } pm10Icon.className = Icon_pm10; var pm10Data = document.createElement('span'); pm10Data.className = "medium"; pm10Data.innerHTML = "PM10: " + this.textDataRecived.pm10 +" ppm"; var stationIcon = document.createElement("tr"); stationIcon.className = "fa fa-home"; var stationData = document.createElement("span"); stationData.className = "medium"; stationData.innerHTML = "내 위치: " + this.textDataRecived.station; table.appendChild(space1); table.appendChild(space2); space1.appendChild(pm10Icon); pm10Icon.appendChild(pm10Data); space2.appendChild(stationIcon); stationIcon.appendChild(stationData); wrapper.appendChild(table); } return wrapper; }, });and i got a error like this
[01.07.2021 23:12.25.107] [LOG] {"station": "\ub178\uc6d0\uad6c", "pm10": 31} [01.07.2021 23:12.25.342] [ERROR] Whoops! There was an uncaught exception... [01.07.2021 23:12.25.345] [ERROR] TypeError: Cannot read property 'station' of undefined at ChildProcess.<anonymous> (/home/pi/MagicMirror/modules/MMM-DustInfo/node_helper.js:23:28) at ChildProcess.emit (events.js:315:20) at maybeClose (internal/child_process.js:1021:16) at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)I want to display pm10 value and nearest dustinfo station using airkorea API
I’m really beginner please help me…
@doridol
In node_helperreceiveddata needs to be defined outside the on handlers. u could move the handling up to the on data, and remove the on close
@sdetweil Really really thanks!! I solved problem
