    Updated to 2.15 but now have a random cursor
    11 Posts 5 Posters 4.0k Views 6 Watching
      sdetweil @scumbelly
      @scumbelly weird. most of my systems do not have a keyboard/mouse and do not have unclutter installed.
      no mouse appears over mm.
      if I plug in a mouse, no mouse appears over mm
      if I change the css, then the mouse appears
      main.css
      html {
        cursor: none
      comment out the cursor :none;
        scumbelly @sdetweil
        Your solution is certainly easier.
        Thanks for the information.
        Regards.
        • T Offline
          TDMPro2K
          HI Guys, Yeah it only showed since doing the update to the latest. I had no issue before.
          The unclutter worked and its not showing once again.
          @scumbelly Thanks for your help…
          • W Offline
            Wenike @TDMPro2K
            So, unclutter worked for me to hide the cursor but now I don’t have the normal RaspPi desktop and instead I’m in some Openbox thing. After some panic, I was able to figure out that I needed to right-click to bring up the menus (I use a Chromebook to VNC on and have a bluetooth keyboard/mouse combo that I use rarely if the Chromebook doesn’t work and the Chromebook has long-press to be right-click, which doesn’t translate very well outside of it). I’ve killed that autostart command and uninstalled unclutter (sudo apt-get --purge remove uncluter). How do I get it to stop going into Openbox and go back to using the desktop that I’m used to?
            • W Offline
              Wenike @Wenike
              @wenike Apparently, deleting that autostart file (or in my case, renaming it) caused it to be recreated and get the normal desktop back.
                MajorC Project Sponsor @sdetweil
                @sdetweil since updated to v2.15 I have the cursor, too.
                The main.css looks like:
                html {
                  cursor: none;
                  overflow: hidden;
                  background: #000;
                  user-select: none;
                Not sure what to do.
